Results 1 to 10 of 10
    Aug 04 2016
    Detroit
    2013 Audi A5 B8.5 Quattro Upgrades - Questions, Answers, and Progress
    I'll start by saying I'm new to the forum and will have tons of questions. I recently picked up a 2013 A5 DSG and instantly got the itch to mod. So far the only mods I've done are powder coating the wheels and installing aluminum pedals. The next mods I'm planning are the RS grill, dual exhaust, and hopefully an RS shift lever. So some questions...
    1. Can I easily swap the current shift lever with an RS ball type shift lever without having to heat/twist the plastic rod since I have a B8.5?
    From this:
    To this:
    If so, does anybody have the proper part#?
    2. I have the Audi Connect stereo without GPS... it's pretty awful. I've added the Tune2Air so I can at least use BT and my phone but it's a mess with Android. Has anybody upgraded the audio equipment to the newer MMI setup in say a 2016 A5?
    Established Member Two Rings Endi's Avatar
    Oct 29 2013
    Audi A4 3.0 Quattro (B6)
    Des Moines, IA
    I don't have much info but I know it should be possible.
    AUDI S5 6SPD
    "If a man does not have the sauce, then he is lost. But the same man can be lost in the sauce. "
    - Gucci Mane
    Feb 27 2014
    Dubai
    Alpine does a fantastic upgrade which has all the functionality of the MMI and a lot more
    http://www.alpine.co.uk/p/Products/a...5141/x701d-a4r
    There is a UK user on here with the unit installed, He posed up some very cool pictures of the unit in use, it's way ahead of the MMI system.
    Gear knob on eBay
    http://www.ebay.co.uk/itm/Audi-RS4-B...IAAOSwyDxXh3V5
    Aug 04 2016
    Detroit
    That Alpine setup is insane and that's exactly what I need. Of course it isn't sold in the US... ugh.
    So will that shifter be plug & play? No mods necessary?
    Sent from my SM-G935T using Tapatalk
    2013 Audi A5 2.0T
    Feb 27 2014
    Dubai
    I would enquire with Alpine, there's no reason it won't work on a US car if you can load the correct maps.
    I'm not sure on the shift knob, I think there's a few guides knocking around, or contact the seller, he goes by the name Littledevil on the forum (real name Ales) he may have fitting instructions.
    Aug 04 2016
    Detroit
    Thanks James!
    Established Member Two Rings DburrellA4's Avatar
    Jun 20 2009
    2003 Audi A4, 2012 Evo X (RIP) 2013 Audi S5
    Bremerton
    I didnt even know the 13 s5 had the top knob picture, as mine is the bottom picture.
    Sent from my SM-G925V using Tapatalk
    2013 Audi S5
    Aug 04 2016
    Detroit
    Good to know. I only have an A5 and it has the handle in the first photo... so I'm looking forward to the upgrade. Looks way better!
    And if anybody has a good resource to get this setup to the US, let me know.
    Established Member Two Rings sly9's Avatar
    Sep 29 2015
    Columbus,OH
    I am B8 A5 and I DIY to replace my shift knob to RS ball one. but I heat and twist the rod.
    2010 Audi A5 2.0T Premium Plus Ibis White
    APR Stage II | APR Downpipe | H&R Street Performance Coilover
    Veteran Member Four Rings 14S4GWM's Avatar
    Mar 21 2015
    OP, you don't have the dsg trans you have tiptronic
