Results 1 to 40 of 79
    Registered User Four Rings CTS Turbo's Avatar
    Nov 12 2008
    01 S4, 04 A4, 15 GTI, 15 S3
    Vancouver
    The Official CTS Turbo B8 A4 Product Info and Announcement thread!
    Hello Audizine! CTS Turbo is proud to offer a large assortment of products for the B8 A4. Instead of starting new threads to announce something or if you guys have questions, we will continuously monitor this thread to show off new products and answer your questions.
    Regarding Pricing, Sales, Install costs, Specialty installs, please call us at 604-530-3092 or send us an email to [email protected]
    ctsturbo.com is our website, We have a massive online store to take care of all your shopping needs.
    Take a look at our Authorized Dealers map to see which dealer is closest to you. If you are in the area feel free to drop by our head office in Langley B.C. Canada.
    B8 A4 Front Mount Intercooler Kit $849.99
    Click here for ordering
    The new CTS Turbo B8 A4 FMIC kit will enhance the performance and power of your vehicle substantially by maintaining lower charged air temperatures even under the most extreme abuse. Boasting a high density bar and plate intercooler core (rated for 600HP) the CTS FMIC kit is ideal for modified B8 A4's with K03, K04 or even big turbo applications. Smooth transitions in our hand crafted intercooler piping ensure quick boost response and optimal flow while the aluminium piping ensures maximum heat dissipation. Fitting an intercooler this size is no easy task, but our design requires absolutely no trimming to the bumper or bumper reinforcement.
    Product details:
    - High density bar and plate intercooler core
    - Core dimensions 20" x 11" x 3"
    - 2.5" hand fabricated, powdercoated aluminium piping
    - Stainless steel T-bolt clamps and 4 ply silicon connectors
    - Bead rolled pipe ends to prevent hoses popping off
    B8 A4 Catch Can Kit $449.99
    Introducing the all-new CTS Turbo oil catch can kit for B8 Audi A4 TFSI and B8 Audi A5 2.0TFSI (TSI motors).
    The oil catch can is used prevent oil vapors entering the intake manifold and clogging up the intake valves on direct-injection motors. Oil deposits on intake manifold and valves cause reduced performance, bad fuel mileage and could damage the fragile intake “flaps” and motor.
    Kit Includes:
    CTS Turbo billet aluminum valve cover breather – CNC machined for beautiful finish
    CTS Turbo Billet aluminum catch can with billet oil-level dipstick
    -10 AN Black-Series braided hoses
    Clamp-on style catch can mounting bracket
    Modular intake manifold plug
    Hose-Wrangler clamp
    Kit Fits:
    · 2008+ B8 Audi A4 2.0 TFSI
    · 2008+ B8 Audi A5 2.0 TFSI
    Click here to see a video of one of our kits being emptied
    All installation hardware is included as well as o-ring for the rear PCV breather.
    Keep your B8 Audi A4 or A5 running smooth, clean and enjoy the peace of mind that comes with knowing that the PCV system on your car is now free of issues.
    FREE SHIPPING ON ONLINE ORDERS!
    B8 A4 2.0 BorgWarner K04 Turbo Upgrade Kit $2399.99
    The heart of the CTS Turbo B8 A4 2.0T turbo upgrade kit is the Borg Warner K04-0064 turbocharger. This turbocharger is commonly used in OEM applications such as the Audi S3 available in Europe. The highlight of this Borg Warner turbocharger in our kit is the 'forged mill' compressor wheel, which brings numerous benefits to the enthusiast. The technology used in the production of these turbos provides us with a variety of benefits, reduced compressor wheel weight (faster spool), increased strength, and greater surface area of the compressor wheel. Because of the 'forged mill' technology Borg Warner can increase the effective surface area of the compressor wheel, which results in greater air flow than conventional cast compressor wheels.
    In addition to the Borg Warner K04-0064 the CTS Turbo B8 A4 2.0T turbo upgrade kit uses a set of custom silicon hoses to relocate the factory diverter valve. Our diverter valve relocation uses the same principles as the OEM Audi S3, Audi TTS and Golf R. In addition to the diverter valve relocation our kit includes a new diverter valve housing to relocate the diverter valve, associated OEM gaskets, nuts, studs and hardware and test pipe to connect to your factory downpipe. This kit is by far the best 'bang for the buck' modification available for B8 enthustiasts with the 2.0T engine.
    B8 A4 Silicone Intercooler Hose kit $199.99
    CTS Turbo now offers a full silicone intercooler hose set for the B8 Audi A4/A5 2.0T FSI. The hoses that come stock with your car age and deteriorate over time. This will lead to inevitable boost leaks leading to loss of power and increased wear on the turbo. CTS Turbos hoses are far more durable and are guaranteed to not crack. Our super rigid construction eliminates hose expansion and deformation under high boost pressure. Included in the kit is our Billet Aluminum 2.25" Turbo Outlet Adapter.
    A recommended addition to this kit is our B8 A4 Turbo Inlet Hose. Click here for more info. Seen below.
    B8 A4/A5 Silicone Turbo Inlet Hose $69.99
    Turning up the boost in your car increases wear on your stock rubber turbo inlet hose. Eliminate cracking, stretching and deformation with this CTS Turbo B8 A4/A5 Silicone Turbo Inlet Hose. Increased rigidity and higher flow mean less restriction and more power.
    This is a recommended addition to our B8 A4/A5 Intercooler Hose Set seen here. Seen above.
    B8 A4 Test Pipe/HFC $174.99
    The CTS B8 A4/A5 2.0T test pipe is the premier test pipe for your Audi A4 or A5 2.0T. Our test pipe is designed to seamlessly fit in place of your restrictive stock catalytic converter, which is situated immediately after the turbocharger. Our test pipe features 3" stainless steel piping, smooth mandrel bends, two 02 sensor bungs with an option for a third. Substantial power gains, improved exhaust flow and a more throaty sound are the main benefits from installing our test pipe. Upon inspection you will notice a flare which is nearly 4", this flare then tapers to 3" and is designed to allow for optimal flow as the exhaust gas transitions from the turbocharger to the test pipe. In addition to being one of the best bang for the buck performance upgrades for A4/A5 owners our test pipe is also very attractive piece. Each 3" test pipe is mandrel bent, hand tig welded and comes with the standard CTS swag (lanyard and plate frame). Do you need an additional 02 bung for data logging? Well that's no problem! Tig welding additional 02 bungs can be done for an additional charge.
    Product Details:
    T304 stainless steel construction
    Mandrel bent stainless steel
    Fully tig welded design
    Optional third 02 bung
    Install hardware included
    Throaty sound
    Great power upgrade
    B8 Audi A4/A5 Downpipe $399.99
    The CTS B8 A4/A5 2.0T downpipe is the premier downpipe for your Audi A4 or A5 2.0T. Our downpipe is designed to seamlessly fit in place of your restrictive stock downpipe, which is situated immediately after your Catalytic converter/Test Pipe/HFC. Our Downpipe features 3" stainless steel piping, smooth mandrel bends, and a stainless steel flex section. Substantial power gains, improved exhaust flow and a more throaty sound are the main benefits from installing our downpipe. In addition to being one of the best bang for the buck performance upgrades for A4/A5 owners our test pipe is also very attractive piece. Each 3" test pipe is mandrel bent, and hand tig welded.
    Product Details:
    Versatile flex section
    Throaty sound
    Great power upgrade
    Muffler Delete $129.99
    CTS Turbo is proud to release our high flow Turbo Muffler delete for 1.8T and 2.0T engines equipped with IHI Turbochargers (see application guide below). The CTS Turbo Muffler delete is a one piece design CNC constructed from T6 6061 aircraft grade aluminum and hard anodized to reduce wear. Our Turbo Muffler delete replaces the restrictive, power robbing OEM Turbo Muffler, which is designed to reduce turbocharger harmonic noise. Our kit installs in 30 minutes with hand tools, seals using the included O-ring seal with standard hand tools and looks stealthy like the OEM unit. For those of you that want optimal power and boost response the CTS Turbo Muffler delete is your answer.
    Application Guide:
    Audi - S1 EA888 Gen 3 - 2.0 TFSI
    Audi - A3 & S3 (MK3) - EA888 Gen 3 - 1.8 TFSI and 2.0 TFSI
    Audi - A4 / Allroad (B8 & B8.5) - EA888 Gen 2 & 3 - 2.0 TFSI
    Audi - A5 (B8 & B8.5) - EA888 Gen 2 & 3 - 2.0 TFSI
    Audi - A6 (C6 & C7) - EA888 Gen 2 - 2.0 TFSI
    Audi - Q5 - EA888 Gen 2 & 3 - 2.0 TFSI
    Audi - TT / TTS (MK3) - EA888 Gen 3 - and 2.0 TFSI
    VW - Golf / GTI / R (MK7) - EA888 Gen 3 - 1.8 TSI and 2.0 TSI
    CTS TURBO 2.0T BOV (BLOW OFF VALVE) KIT (EA113, EA888.1) $269.99
    CTS Turbo is proud to release our 2.0T Atmospheric BOV KIT for EA888.1 equipped vehicles. The CTS Turbo 2.0T Atmospheric BOV KIT (EA888.1) is made of billet construction and completely serviceable. Our kit is designed to work with all of the factory electronics, will not cause any check engine lights and is plug and play with no wiring extensions required. The CTS Turbo 2.0T Atmospheric BOV KIT (EA888.1) replaces the factory plastic unit which has been prone to failure from torn diaphragms, cracked plastic, and electrical malfunctions. Our piston design ensures long life, easy installation, complete serviceability, great sound and great value. This valve is quite compact being slightly shorter than the stock unit and fits nicely even in the tight engine bays of today's VAG cars.
    Fitment:
    Audi A3 8P (EA113 & EA888.1)
    MKII Audi TT (EA113 & EA888.1)
    MK5 GTI (EA113 & EA888.1)
    MK5 Jetta (EA113 & EA888.1)
    MK6 GTI (EA888.1)
    MK6 Jetta (EA888.1)
    EOS (EA113 & EA888.1)
    Tiguan (EA888.1)
    B6 Passat (EA113 & EA888.1)
    Passat CC (EA888.1)
    Beetle (EA888.1)
    Audi S3 8P (EA888.1)
    Golf R (EA888.1)
    B8 Audi A4 (EA888.1)
    B8 Audi A4 (EA888.3)
    B7 Audi A4 (EA113)
    Product Features:
    T6061 billet aluminum construction
    Black anodized stealth finish
    Fully compatible with OE electronics
    Fully serviceable piston design
    No additional wiring required
    Substantial reliability improvement over OE
    Compact design fits into tight spots easily
    CTS TURBO 2.0T DIVERTER VALVE KIT (EA113, EA888.1) $269.99
    CTS Turbo is proud to release our 2.0T DV (DIVERTER VALVE) KIT for EA113 and EA888.1 equipped vehicles. The CTS Turbo 2.0T DV (DIVERTER VALVE) KIT is made of T6061 billet construction and is completely serviceable. Our kit is designed to work with all of the factory electronics, will not cause any check engine lights and is plug and play with no wiring extensions required. The CTS Turbo 2.0T DV (DIVERTER VALVE) KIT replaces the factory plastic unit which has been prone to failure from torn diaphragms, cracked plastic, and electrical malfunctions. Our piston design ensures long life, easy installation, complete serviceability, great sound and great value. This valve is quite compact being slightly shorter than the stock unit and fits nicely even in the tight engine bays of today's VAG cars.
    Fitment:
    MK6 GTI (EA888.1)
    MK6 Jetta (EA888.1)
    Tiguan (EA888.1)
    Passat CC (EA888.1)
    Beetle (EA888.1)
    Golf R (EA888.1)
    B7 Audi A4 (EA113)
    Product Features:
    CTS B8 A4 TFSI Crank Pulley Kit
    The CTS Turbo crank pulley is lightened to reduce parasitic drag on the engine. This results in faster revving and more horsepower.
    Included in the kit is the lightened crank pulley, replacement OEM bolt and a shorter belt.
    The pulley is made from T6 6061 aircraft grade aluminum and hard anodized to reduce wear. Gains of 5-7 horsepower can be expected.
    NOTE: VW TOOL T10355 IS REQUIRED FOR INSTALLATIO
    Veteran Member Four Rings jaycurn's Avatar
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Looking good! It's November... Any Black Friday deals coming up at the end of the month for new B8 owners?!?!
    Nov 12 2008
    Vancouver
    Quote Originally Posted by jaycurn View Post
    Yes, we will be having a Black Friday sale. Not many people around here look in these threads, but they should. This is something we've been working on for B8 that can house a turbo substantially larger than a K04:
    Sep 01 2012
    Edmonton
    Quote Originally Posted by CTS Turbo View Post
    Good job on coming out with new products. I believe alot of people aren't checking out the CTS threads has been because of the lack of response from you guys.
    2018 RS3 Panther Black
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Anychance you can ball park or even give a hint at what kind of price tag will be attached to this? I'm planning a k04 but if this is going to be considerably more powerful and not cost me a kidney I may hold out.
    My 2009 A4 Prem+ Build thread
    Nov 12 2008
    Vancouver
    Quote Originally Posted by Lambda13 View Post
    Target price for the hardware will be just below $3000.00, keep in mind software and fueling would be additional. As you can see this setup has internal DV/BOV right now, internal WG, and the idea is plug and play with an OEM+ look.
    Jul 07 2012
    Boston, MA
    Can you elaborate on this? What would be needed?
    Veteran Member Three Rings Spm58's Avatar
    Nov 03 2014
    Long beach, ny
    Any new info on this nice turbo setup at all?
    2015 sepang blue s4• Ecs luft-technik carbon Intake
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Any updates on this project?
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Veteran Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    In the woods
    Quote Originally Posted by blbroo View Post
    +1
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    I've been messaging them over the last couple weeks. Expected timeline late summer, will be able to use factory location downpipe and FMIC. So, could be big savings for those of us who have already put in a HFC and FMIC. It's expected to work with Garrett Turbos.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by cybernet99 View Post
    Any idea who they are working with to tune it?
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    Twin scroll perchance?
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    hopefully with a good tuning solution?!^^^
    |CURRENT|01.5 S4|
    |TOTALLED|09 B8 A4 QUATTRO|EURODYNE|FRANKENTURBO F23L|
    |PAST TURBOS|IHI JH5|PROTOTYPE BW K03 BILLET WHEEL|
    - OEM IHI K03 APR STAGE 2+ V1.0-1/4 MILE TIME [email protected](-85DA)
    Nov 12 2008
    Vancouver
    Quote Originally Posted by Alex1188 View Post
    Yes, hopefully.
    Quote Originally Posted by Dub_prime View Post
    No need
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Yes, hopefully.
    No need
    Oh my....
    Nov 12 2008
    Vancouver
    Looking for a deal on Black Friday? Check out our upcoming sale flyer! Something you want, but don’t see on the flyer? Drop us an email! The sale isn’t just limited to the flyer, there are many more items not listed on the flyer that will be on sale too!
    Mar 10 2013
    Yes, hopefully.
    i wouldnt mind eurodyne, but would be nice if you guys could provide something, or partner with someone. Never the less, im very excited to see this out! I would rather buy your guys stuff over anyone else, as i have learned, through buy from others, that your company in my opinion produces the higher quality stuff.
    |CURRENT|01.5 S4|
    Oct 26 2012
    St. Louis, MO
    Is this tuning option being tested in Southern California by chance?
    May 21 2015
    Nissan R32 GTR, Ducati 659
    Melbourne, Victoria, Australia
    Please tell me its a EFR6758
    Nov 12 2008
    Vancouver
    Quote Originally Posted by Shaph View Post
    We have not decided if we will offer this with EFR, however it has been designed to accept EFR bearing housings. We will certainly offer this setup with Garrett GT/GTX hardware. This is a ways away, but we get a lot of moaning and complaining that we don't work on 'platform x, y, z' etc. anymore, so now we hope to get no moaning from the B8 guys
    Senior Member Two Rings Boosted_b8.5's Avatar
    May 22 2013
    2003 Honda civic ex turbo ! 330whp 293wtq !
    Los Angeles / ca / Hollywood
    Keep it coming. Everything looks great! Any charts or graphs to back up the intercoolers performance ?
    2013 B8.5 A4 PP+ // WRAPPED IN MATTE METALLIC BLUE//RS4 GRILL // S-LINE EXTERIOR // GROUND FORCE GF07 19' // MICHELIN SUPER STREETS // VAGGED // LED INTERIOR //COLOR MATCHED FOGS// TO BE CONTINUED !!
    May 21 2015
    Quote Originally Posted by Boosted_b8.5 View Post
    I dont think an Intercooler really increases Power, however they eliminate heatsoak and decreases lag.
    May 22 2013
    I know I wanted to see facts that it reduces lAT's.
    May 21 2015
    Would it line up with stock cat (or HFC) and your inter-cooler? Either way id love the EFR6758 or GTX3067
    Nov 12 2008
    Vancouver
    That was the plan Shaph, plug and play for the most part. However, some of the responses we get here aren't conducive for us to develop products for the platform.
    We don't have any details posted, but we did have a customer post up an extensive review of the FMIC kit including that info. I believe he was from Arizona, he posted more info than most people really have interest in. I don't know where that thread is, but it could easily be found by searching AZ.
    Quote Originally Posted by McFuzz View Post
    heh - you guys had to change the music on that catch can draining video, didn't ya?
    Serious question tho: when did the design of the catch can change to remove the drain plug on its bottom? The one I just received does not have one and I was told to drain it through the AN fittings...
    Drain plug was eliminated, it was redundant and a pain to use. It's much easier to remove the catch can from the bracket and drain it through one of the AN ports. We have had a number of customers strip out the bottom of the catch can because they either tighten them too much or they don't use the correct sized allen head socket.
    Quote Originally Posted by WAF View Post
    Thanks, but that's usually not how it's done. Your third party, it's like asking a sub-contractor what the general contractor is doing. I don't have any questions as this will be the same situation as last K04 kit that I was going too buy. No tuning provided, no chance on me dealing with that especially when another company is offering it. I was going to buy the catch can but same thing as there was a few questions on the kit and no response..... All these CTS power threads/exhaust threads are great if they are used to inform the customer and answer any questions or issues on install etc. These threads are currently as follows... CTS AD for sale, questions from member, no response, CTS AD, questions, no response, CTS AD. Please correct me, and prove me wrong but that's the way I see this.
    If we sat on the forums all day answering questions we wouldn't have time to develop products. I think people would prefer to have products being developed for their car, rather than having someone trolling the forum answering questions that could easily be found. We're a small company, people in general need to have patience these days, we're not Amazon. We could can the engineering team and hire a gang of forum trolls, but that doesn't benefit anyone wanting to further the B8 platform.
    Modded Euros is one of our largest distributors, they can have the experience to answer questions about our product line.
    Quote Originally Posted by ModdedEuros View Post
    Another cool product you guys are rolling out
    @WAF - if you or anyone else need any CTS help, don't hesitate to drop us an email at [email protected] and we can answer any questions. The CTS guys I can tell you are cranking very hard on dev and manufacturing to keep up with demand.
    Thanks for the support and chiming in Modded Euros
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    This is pretty much gold right here... I can fully appreciate this kind of logic!
    Aug 15 2014
    Thats a crap answer, sorry. Plenty of forum vendors on here take the time to answer questions and frequent the forums several times a day. Step it up.
    Still excited to see what you guys are doing. I ran a CTS BT kit on my mk4 and loved it.
    For Sale: Mini Part Out
    Nov 12 2008
    Vancouver
    The CTS Turbo Holiday Sale is just around the corner! Check out our upcoming sale! Something you want, but don’t see on? Drop us an email! The sale isn’t just limited to the items detailed on the flyer, there are many more items not listed on the flyer that will be on sale too! Upto 25% off on selected items, and free domestic shipping on most items!
    Senior Member Two Rings McFuzz's Avatar
    Jun 20 2014
    CA Bay Area
    Aug 23 2014
    Philadelphia, PA
    Sep 01 2012
    Edmonton
    Apr 05 2014
    Edmonton, Alberta, Canada
    subbed.
    2009 Mercedes-Benz C63 AMG. Agency Power Headers, Eurocharged Tune, High flow air filters, secondary cat delete 490RWHP
    *SOLD*2010 A5 S-Line, Deep Sea Blue 6 Speed M/T
    Unitronic K04 Turbo, Vossen CV3 Matte Graphite, H&R Spacers, ECS Vent Boost Gauge, Injen CAI, CTS Turbo Test Pipe, Forge BOV, Tint.
    Sep 01 2012
    Edmonton
    I'm not asking for a troll. So when i PM you guys and don't get an response numerous times contact one of your dealers even though i've bought your products through you directly? It would be a waste of time bothering a vendor which is in the US that i wouldn't order from cause of shipping costs, but if that's the process no problem.
    Sep 01 2012
    Edmonton
    Quote Originally Posted by Shimmy View Post
    Hold Shimmy on I'm the bad guy for asking on product info and reasonable customer service. I agree with everything you said.
    Apr 05 2014
    WAF Who do you deal with in edmonton for performance parts
    Sep 01 2012
    Edmonton
    Quote Originally Posted by talkinghamster View Post
    PM sent.
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    PM sent.
    I'm curious now too.
    Sent from my Nexus 5 using Tapatalk
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Veteran Member Three Rings Jester2893's Avatar
    May 29 2012
    You guys all know they have an email right? Every time I have emailed I get an email back same day or the following, not sure about the whole ordeal about "forum response." Regardless I am excited to see more information about this setup and what exactly options will be for it.
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by Jester2893 View Post
    Agree. Audizine isn't their website. They do have a website with contact info though. If they didn't respond there, that would be poor.
    Does fueling for this new kit mean S3 injectors? What other internal components?
