Results 1 to 7 of 7
    Registered Member Two Rings corrado driver's Avatar
    Apr 07 2004
    98 Audi 30v A4, 90 Corrado G83, 95 Nismo Altima bluebird
    Stonington CT
    water in back driver floor
    Has any one else ever had this problem? I want to know if any one has a fix for this. I don't know where it is coming from? but there is a lot of water..
    I hate the rain
    Please help larry
    Drive hard and wear a helmet
    Senior Member Three Rings qtek16's Avatar
    Jul 18 2004
    01 s4, 11 Yukon Denali, 08 TBSS, 94 300zx, Sold 01 A4
    my trunk is leaking all they at the end facing the outside.....that sucks too
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    the drain plug is probably missing. Right next to the lift point at all 4 corners of the car.
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Established Member Two Rings clouie's Avatar
    Dec 25 2004
    98.5 a4 1.8tqm
    Sacto, CALI
    check the plug on the driver side under the hood near the ecu
    vtec just doesnt satisfy my boost addiction =\
    out with the old: 98.5 audi a4 1.8tqm..totalled
    in with the new: 05 asm rsx type-s
    <img src="http://img.photobucket.com/albums/v284/aznguykris/resizeaudi.jpg" alt="r.i.p 2" height="150" width="300"></img>
    Apr 07 2004
    Stonington CT
    checked under the hood but drain plug I think is there I will check when I get out. You were talking about the big square one right?
    Apr 07 2004
    Stonington CT
    thats in the back floor mostly if that help sorry should have told you that from the get go
    Larry
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Drive hard and wear a helt
    WTF is a helt???
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
