Results 1 to 6 of 6
Thread: alignment specs
    Feb 24 2004
    Minneapolis
    alignment specs
    So a buddy with a B6 wanted alignment specs. Sent him a page from my Bentley but I don't understand it. For example, what is -33’ camber on the front? Obviously it’s not degrees. The last alignment I got thinks -0.6˚ is the camber setting.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Feb 24 2004
    Minneapolis
    Sorry, I didn't Google well. The apostrophe is a minute, or 1/60 of a degree. So:
    -33' ÷ -60’ ꞊ -0.55˚, or rounded to the -0.6˚ I saw on the last alignment I had done.
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    I think someone forgot geometry 😊
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Its interesting that they specify the front camber since its non-adjustable.....i guess just to make sure its not totally fd....
    Stage 1 more than you RS3
    Nov 15 2011
    Montreal | I sell in USD
    If I may, you should post the whole sheet for future reference
    *****I sell in USD*****
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Denio24 View Post
    I think someone forgot geometry ��
    Yea but I haven't forgotten the way our student teacher looked sitting on the desk while talking about isosceles triangles.
    Quote Originally Posted by o1turbo30v View Post
    As I understand it, camber is adjustable. But not caster. You adjust camber by moving the sub-frame. But only to the extent that you adjust the two wheels relative to each other. If I'm wrong, I probably got confused thinking about Ms. Adolsek's legs on that desk.
