Results 1 to 30 of 30
    Veteran Member Three Rings Cactus00S4's Avatar
    Aug 29 2004
    in my car
    can my motor handle???
    my motor has almost 137k on it, runs good, no smoke besides shit from my test pipe, but how can i tell if it can handle a big turbo set-up, i want to get one so bad but im worried, anyone help me out on how to check it before i buy a kit?
    thanx
    barry
    Cactus Green S4 Stage 3-
    Veteran Member Four Rings 01'A41.8T's Avatar
    Mar 06 2005
    F82 M4
    PA & AZ
    For how many of those miles were you the owner?
    WE REMEMBER the AZ crash of Sept. 06'. We lost a lot of good posts out there...
    Veteran Member Three Rings RAyala2.7T's Avatar
    Mar 08 2005
    Austin, TX
    compression/leakdown test will give you the answer
    Rob - 2000 Audi S4 VAST Stage III
    Active Member Four Rings ECA4's Avatar
    Feb 14 2004
    New Jersey
    You shouldn't have a problem, as long as the car was treated well it whole life then you should be fine. If worst comes to worst you could eventually just rebuild the motor and run one of the quickiest A4's around
    Veteran Member Four Rings bOOOOstedAudi's Avatar
    May 27 2004
    C6 A6 S-line 3.0T Quattro, BT B7 A4 2.0T S-line Quattro
    Sacramento, CA
    do it who cares
    May 27 2004
    Sacramento, CA
    wait i didnt even mean to sUBMIT THAT
    go with the compression test
    Mar 06 2005
    F82 M4
    PA & AZ
    Originally posted by bOOOOstedAudi
    do it who cares
    HAHA best advice ever!
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    do it who cares
    embrace that, I do. post everything before you have a chance to think about it.
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    ^^^That usually ends in a confrontation with other members^^^ (for me that is)
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    I did a K04 at 160,000 miles
    Aug 29 2004
    in my car
    i had it for the 37k the other 100k i dont know about, i mite do the compresson test, anyone help me out and let me no what it should be???
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    I remember a guy going APR stage 3 with around 90 some K.
    789whp
    Veteran Member Four Rings SeanF's Avatar
    Sep 13 2004
    Concord (LMS area), NC
    how do you test the compression on the motor?
    2007 Black Mica Mazdaspeed3 GT, w/ navigation
    Built, Blown, and Squeezin' on a 3071r
    Feb 12 2004
    Toronto GTA
    I always say, thats like a woman giving birth at 45, there a certain chance the kid will come out retarded.
    Veteran Member Four Rings Hassmeister's Avatar
    Feb 12 2004
    2015 GOLF R APR Stage 2
    A basic understanding: Link
    Click here for AMSOIL - Superior Protection!
    Wholesale pricing and delivery to your door - ask me how!
    do it who cares
    ah..words of wisdom right there..thats my logic behind pretty much everything
    contact via email please.
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    older motor=more reason to replace stuff
    Oct 09 2005
    sc
    just think of it as replacing an old turbo for preventive maintenance. the stock one is sure to go some time.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    best analogy ever.
    Jim
    I Do Werk.
    Aug 29 2004
    in my car
    well my turbo is only couple months old, was suposed to be a k04 but i got screwed by the shop
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    TighTT on audiworld has 155k on the odometer and has a PES T28 setup and his car is running strong.
    2018 Navarra Blue S5 Sportback
    2001.5 Blue Raspberry S4 Avant w/ hybrids on E85
    Past Audis:
    2015 Glacier White Allroad 2.0T
    2012 Ibis White S4
    2001.5 Nogaro Blue AWE/GIAC Stage 3 S4 16,500 mi
    Fast Intentions Wide Mouth DPs and custom 3.5" exhaust
    2000 Silver A4 Avant 1.9tqm 217k mi.
    2000 T28 A4: SOLD
    Mar 02 2004
    Orange County
    if you want a much more accurate understanding of engine health use leak down testing. I have seen bad motors with "good compression"
    Past Audis:
    2012 Ibis White S4
    2000 T28 A4: SOLD
    Feb 16 2004
    audi is chit
    well good compression, bad leakdown is most certainly ringwear that is masked when there is oil. i forgot what it means but i think its the first ringland is gone but the 2nd and oil rings are keeping compression when the oil is present on a low pressure compression test. a leakdown more accurately simulates true compression pressures. if that made no sense it's 2am
    Veteran Member Four Rings BranCKY3's Avatar
    Mar 08 2005
    Greenville, SC
    Wow what happened? Did you get a refund or what?
    2016 Audi S3
    Deactivated Four Rings derek2079's Avatar
    Aug 02 2004
    UT
    i would do it. Worst case scenerio your motor is shot and you replace it. and you can find a motor with low miles for around a grand these days
    Feb 16 2004
    audi is chit
    where?
    i have a long block id be willing to part w/ if the price was right...
    might turn into a short block after a while though..i want to take the head off and port it
    Mar 09 2004
    nw michigan.
    i had always planned on buying a spare engine to play with. if the BT ever popped the engine i would swap in the project block.
    Jim
    I Do Werk.
    yea..i kind of like knowing i have a spare block just sitting in my garage
    Mar 02 2004
    Orange County
    do we share the same brain? quit hacking into my head!
    Past Audis:
    2012 Ibis White S4
    2000 T28 A4: SOLD
