Results 1 to 3 of 3
    Oct 20 2015
    2013 S6, 1958 VW Fiberglass Buggy, 2003 TT 225 Big Turbo
    Owings Mills Maryland
    Launch Control/2 Step Set up
    Hey guys, im new to the forum and was hoping to find some help with setting up launch control/2step...
    Basic info:
    2003 TT 225. 6 speed, Haldex Quattro
    Stock AEB Head
    GT3076r turbo
    750cc Bosch EV14
    IE Rods
    Stock pistons
    Eurodyne ME7
    Currently running 93octane at 30psi.
    I am having issues with launching the car. With 2 step deactivated, it is very difficult to launch with out bogging. Even when dumping it at 6500-7rpm, it is hit or miss weather I get some wheel spin, or she bogs to about 2k...
    I activated the 2 step thinking this would be the answer. I set the rpm to 5000rpm. It builds about 7psi. When I dump/aggressively slip the clutch I can keep it in boost about 65% of my lunches with out bogging. If I work the clutch too much it will start to slip and if I dump to fast it bogs. I currently have a FX350 with about 4000 miles on it.
    My question is this. Can you manipulate the 2 step to build more boost? Also, I understand how bad this is on the exhaust valves, but is this only when on 2step for extended periods of time (more than a few seconds) or am I shortening the life everytime I use the 2 step?
    I have seen some awd 1.8t vidoes of cars make 15-20psi on 2 step and their cars are taking off like a bat out of hell. Anyone have any experience with this? Any input would be much appreciated.
    Active Member Two Rings Kyüshutsu's Avatar
    Jul 28 2013
    Minnesota
    Are the two step "bats out of hell" 1.8ts A4s or TTs? The TT Quattro uses Haldex whereas the A4 Quattro is a Torsen Center Diff. I believe the Haldex is only part-time AWD; only when the front is slipping does it send torque to the rear. The Torsen is permanent AWD that can also allocate up to a 2:1 torque ratio when a side is slipping.
    I'm pretty confident that is true but I'm sure others on here can chime in. In regard to your two-step setup, what are you using to set it?
    Jul 28 2013
    Minnesota
    Another thought I had is, with your BT set up when does your turbo typically full spool?
