Page 3 of 3 FirstFirst 123
Results 81 to 96 of 96
  1. #81
    Active Member Two Rings 1stS4's Avatar
    Oct 13 2018
    Lancaster
    Great thread i really appreciate all the info. To start off, this is my first Audi so i have alot to learn any help would be great. I'm having some issues connecting the dots for the sq5 bbk. Im seeing posts with pictures of the sq5 caliper 345mm brembo (part # 8R0-615-107-A, brembo) on the s4 for the bbk project. So i know the q5 brembos fit but i also saw some places about the 380mm rotors from the sq5 on the b8. Will these 380mm calipers(part #8R0-615-124) from the sq5 bolt on the b8 s4 as long as i have wheel clearance? Which i believe i do, currently running 19x8.5 ultraleggeras, and i saw a picture of someone w 380mm and leggeras. I'm trying to message him but i can't find the same post in the forums. If these are the correct calipers, once last questions what is everyones preference here the brembo 345 or the oem 380?
    Side note if this is the wrong place to post this im sorry but felt it would see the most attention here.
  2. #82
    Nov 15 2016
    Coolant
  3. #83
    May 18 2019
    Colorado
    What about Integrated Engineering performance parts?
  4. #84
    Aug 20 2010
    MASS
    Rbbgv
  5. #85
    Established Member Two Rings Goldfinger978's Avatar
    Feb 05 2012
    San Diego, CA
    Some good stuff in here! 👍🏻
  6. #86
    Feb 05 2012
    San Diego, CA
    “B8 S4 Interior LED Install“ links you to a stinky A/C post btw.
  7. #87
    Oct 20 2015
    Southern%20Hemisphere
    Crank pulley weights in grams
    OEM
    IE 188mm
    034 190mm
  8. #88
    Veteran Member Three Rings Snowmonkey's Avatar
    Apr 27 2018
    Kansas
    Quote Originally Posted by byront8 View Post
    OEM
    IE 188mm
    034 190mm
    Im confused about those numbers. Why were bolts and balancer (?) included in the IE weight but not in the 034 weight?
    2013 Phantom Black S4, 6MT, APR Stage 1, Carbon Intake, Canyon Run CR-15, aFe Pro 5R, Sport Diff, B&O, Nav
  9. #89
    Oct 20 2015
    Quote Originally Posted by Snowmonkey View Post
    You need the balancer for the IE pulley to work - its an overlay pulley which utilizes the OEM pulley for the Aux belt and the bigger overlay for the larger crank ratio.
    The 034 pulley is a complete 1 piece machined unit.
    Bolts might add around 80gms at most.
  10. #90
    Apr 27 2018
    Kansas
    ahhh, i didnt know the IE wasnt a 1-piece
  11. #91
    Junior Member Two Rings
    May 25 2017
    Bartlett, IL
    Great info! Thanks
  12. #92
    Jun 28 2020
    1983 Datsun 280zx / 1973 Dodge Dart GT
    Texas
    Thank you for a great starter page and reference points for all of us new S4 owners. I'm looking at upgrading the OEM 6MT shifter in the near future; the prior owner was not kind and shifts are notchy and down right impossible to catch sometimes. I will use your post for pointers and links for the JHM or ECS shifter installation tips.
    Cheers.
  13. #93
    Active Member Two Rings FAKES4's Avatar
    Oct 14 2017
    New york
    Hey, here's a list of the mods on my s4 2014. I keep getting this code, already changed both O2 sensor. Happens when I'm going into boost. Epc light will pop up, when I pull over turn off and on, light is gone. Any advice ? Thanks in advance.
    Sent from my GM1917 using Tapatalk
    Fake S4
  14. #94
    Oct 14 2017
    New york
    Quote Originally Posted by FAKES4 View Post
    Car is for sell at the moment as well, if anyone is interested. NYC area.
    Fake S4
  15. #95
    Established Member Two Rings onelowboi's Avatar
    May 31 2019
    bay area
    did you ever check spark plugs/ignition coils? happened to me then i switched them out
  16. #96
    Veteran Member Three Rings mahhdd's Avatar
    Nov 08 2020
    Atlanta, GA
    May want to consider adding this: https://www.audizine.com/forum/showt...leed-your-3-0T
    2015 Sepang Blue S4, 6MT, Sport Diff, Ceramic Coated
    034 Stage 1 Tune, Intake, UCA & LCA Kit, Springs, End Links, Drivetrain Mounts/Inserts, RSB, and HPFP Piston, Bilstein B8 Shocks/Struts, P3 V3 Gauge
    MercRacing S6 HX, CWA 100-3 Pump, JXB Shifter, Mount, Extended Slave, and Reinf. Linkage, USB Stainless Steel Clutch Line, ECS Resonated Valved Exhaust, Engine & Trans Skids
