Page 65 of 66 FirstFirst ... 155563646566 LastLast
Results 2,561 to 2,600 of 2612
  1. #2561
    Veteran Member Three Rings musanoadsaba's Avatar
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    All resistors will run hot as you likely know. Those ones you are showing have nice connectors though. No soldering. I use Morimoto's blue resistors.
  2. #2562
    Established Member Two Rings jcmii's Avatar
    Dec 08 2010
    Quote Originally Posted by musanoadsaba View Post
    Ok thanks. Iíll check the morimotos or just find a good place to mount these. They were just so hot after about a minute.
  3. #2563
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    Quote Originally Posted by jcmii View Post
    Agree, very hot you version resistors, you can also check VLEDís resistors (one of many brands out there), great and low temp and I got 28 of them and no issue with way higher quality product compared to illustrated.
  4. #2564
    Jan 27 2013
    Quote Originally Posted by Seattle squash View Post
  5. #2565
    Dec 08 2010
    Great! Iíll check VLEDS. The fog bulbs are from them as well. Thanks.
  6. #2566
    Jan 27 2013
    What did you do to your B7 RS4 today?
    I saw that, and got them as well for quite some time. I just called them and said I was to do full LED conversion and they sent me every bulb and all required parts/resistors. All the right parts showed and over a year now, no issues and look sharp and all red and amber colors are perfect which was something I looked when I picked the products. Just mentioned the rest, if you take that route and I did as I donít like any of the current LED tail lights (full lens assembly options) available now, and like the upgraded LED functionality with the retained OEM look.
  7. #2567
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    Where did you mount your fog resistors?
  8. #2568
    Dec 12 2016
    Southeast
    Working on doing brakes. Which bolts to remove front calipers? The radial mount hex bolts that hold the caliper to the bracket or the 21mm bolts that hold the bracket to the upright?
    - - - Updated - - -
    PS - on previous cars, it's the radial mount - but I've only seen one DIY for this and they refer to the 21mm bolts...but not sure why.
  9. #2569
    Jan 27 2013
    Underside of crash bar or side of radiator if I remember right, all with double sided tape and held well
  10. #2570
    Senior Member Four Rings ven0m's Avatar
    May 10 2015
    Slovenia
    I installed my (ebay 1$) fog resistors 4 years ago at the back metal-plate of the fog lights. Still working today.
    Jeremy Clarkson: "So when you were saying that it wonít slide, what you meant was, ĎI canít slide it.íď
    James May: "Yes."
  11. #2571
    Dec 08 2010
    Nice. Iím doing that.
  12. #2572
    Jan 27 2013
    Quote Originally Posted by ven0m View Post
    Venom, you win! Clean and bumper on... had to do so many so I had it all apart anyways, but for fogs only - I like that!
  13. #2573
    Established Member Two Rings AA 954's Avatar
    Jan 17 2018
    B7 RS4, Mk5 R32, Mk6 GTI (sold), Mk7 Golf R, Ď18 Tiguan & Mk7.5 Base Golf
    Weston, FL
    Looks great, what leds did you use?
    Yes, I like VW's lol
  14. #2574
    May 10 2015
    Slovenia
    Ey bud! Yeah, I know what you mean; I remember doing the DRL's, also had to pop bumper off. The fogs were not so bad.
    Quote Originally Posted by AA 954 View Post
    LED's used were these, with the resistors in the picture. https://www.ebay.com/itm/153301473981
    Nothing high-end, I was basically doing a trial-and-error with multiple LED types of ebay. And these were the first installed and never changed after that for past 4 years. Still got the rest of the LED's saved since then. Hah!
    James May: "Yes."
  15. #2575
    Oct 17 2009
    2007%20Audi%20RS4
    Nesbit, MS
    Ven0m, do you happen to remember which resistors on eBay you used? Prices seem to be all over the place, and I'm guessing a resistor is a resistor is a resistor. How complicated do they need to be?
  16. #2576
    May 10 2015
    Slovenia
    Quote Originally Posted by smoverstreet View Post
    Sure, same ones as these (1.5$/piece) and correct a resistor is a resistor.
    https://www.ebay.com/itm/202303860084
    Or you can get them with the H11 fittings for the fogs
    https://www.ebay.com/itm/371312708866
    James May: "Yes."
  17. #2577
    Oct 17 2009
    2007%20Audi%20RS4
    Nesbit, MS
    Thank you so much. Christmas gift is in the mail!
  18. #2578
    Dec 09 2018
    Jag XJR100, BMW M3, Z4M, 911 C4S
    Raleigh, NC
    Quote Originally Posted by 65vetteC6 View Post
    No you don't, 1 case out of thousands and he hasn't even opened the engine. Highly doubt a guide snapped, maybe a dead tensioner.
    Guides were ok for the most part but the adjusters on bank 1 were maxed out, replacing everything timing related since I have the motor out for peace of mind. Parts are only a couple grand so not going to break the bank.
    It looks like someone had previously been inside and replaced the one guide on top between the two adjusters. Clutch was pretty much at the end of its life so its good its getting replaced.
    The cams on bank 1 were looking a little worn so I'm going to replace them as well, does anyone know where to source a used set? I can get them new pretty easily but if I can even buy a used head I'd be fine with that to take off what I need.
  19. #2579
    Dec 08 2010
    I installed resistors that look very similar venOms and used the VLEDS bulbs and it works perfectly. I attached them to the back of the fog like venOm did and so far itís perfect. Iíll take them out in a few weeks to make sure Iím not melting anything but, it was a great idea. Thanks VenOm.
  20. #2580
    May 10 2015
    Slovenia
    Visiting our local ski slopes with the old lady!
    Glad to help brother!! Let me know if anything is smouldering in the back. Mine have been sitting like that since the first install and the above picture was taken on the 19th March 2015. Still working, hah! Best 1$ ever spent
    My daily activity is more car/house related. Buttoning up the new driveway with new garage door. (complete house refurbish ongoing)
    And a good wash of the winter crud of course!
    Also installed 22 new windows (it's a bit big house) with RF controlled shutters, so was a busy weekend wiring everything and getting the system up and running. But I now have a 40 year old house where I can flip the lights and window shutters via my phone. [:P]
    James May: "Yes."
  21. #2581
    Dec 12 2016
    Southeast
    Quote Originally Posted by Bronco212003 View Post
    Did some stuff to my RS4 today, was able to do some carbon cleaning replaced some o-rings, deleted the intake flaps and new spark plugs. Also replaced my headlights and upgraded to some JHM intake spacers and a JHM tune. :)
    How did you like the JHM Tune?
  22. #2582
    Veteran Member Four Rings Pilfer's Avatar
    Dec 13 2012
    To the Bay Area
    KW V3ís and 034 sway bar. Throttle body is being replaced as well. Interested to see if Iíll rub at this height.
    997.2
    Mk 7 R
  23. #2583
    Dec 05 2006
    So. Cal.
    what's your tire size and are you running spacers?
    Keyboard is on its way out. Please ignore any grammatical errors.
  24. #2584
    Senior Member Three Rings bluebull's Avatar
    Aug 29 2014
    LS460L + F250 SuperDuty
    Portland, OR
    Engine blew at the end of October.
    -Bought a new(used) motor from germanstyle.
    -New AMD stage 1 clutch and flywheel
    -AMD tune.
    -Repainted the front and rear bumpers. Body matched the reflectors and silver pieces of the bumpers.
    -New Titanium Grill without the RS badge.
    -Gloss black wrap on the window trim
    -19 x 9.5 VMR V710ff wheels
    -JHM short shifter
    Also replaced a bunch of stuff when changing out the motor. It all cost way too much, but it runs better than ever. Iím hoping this thing is worth free for a long time.
    Attachment 97211Attachment 97212Attachment 97213
    Hope to see you at Leavenworth...
  25. #2585
    Dec 13 2012
    To the Bay Area
    Spacers yes, 10f 12r. Iím using oem tire size ps4s.
    997.2
    Mk 7 R
  26. #2586
    Dec 08 2010
    Quote Originally Posted by bluebull View Post
    Iím definitely gonna try. Last year kids had a soccer tournament.
  27. #2587
    Jan 17 2018
    Weston, FL
    Finally installed the Floor Mats !
  28. #2588
    Established Member Two Rings borisf's Avatar
    May 04 2018
    07 Imola Yellow RS4
    Those Look awesome!
    The Piping look looks excellent. Care to share where others can possibly get these?
    07 RS4
    93 RX7
    18 Tiguan MQB
  29. #2589
    Jan 17 2018
    Weston, FL
    Quote Originally Posted by borisf View Post
    Those Look awesome!
    Yes they do, quite a few styles to choose from too, Iíll PM you with more details. If anyone else is interested just google autostyle in the UK
  30. #2590
    Veteran Member Three Rings ginch's Avatar
    Jun 30 2011
    calgary, alberta
    I like everything about those mats minus the chrome foot rest thing on the drivers side mat. That looks cheesy to me!
    2008 Avus silver RS4
    1996 993 C4S
    2017 Tacoma TRD Sport, Quadcab shorty, 6 speed, Wife's daily!
    Gone
    2016 Reflex silver Golf R, 6 speed
    2008 Phantom black RS4
    B7 S4 Avant
    1993 964 C2
    2004 Reflex silver .:R32
  31. #2591
    Jan 17 2018
    Weston, FL
    Quote Originally Posted by ginch View Post
    I get it, I will probably be driving around with my shoes off for now
    The beauty of these as they are custom, Iíll be ordering another set without the heelpad with a few different combinations...
    Ď07 Avus Silver RS4 - just stocking up parts for the transformation
  32. #2592
    Mar 02 2015
    1970 Daytona Yellow LT1 Corvette, 2010 Wolfsburg Ed Jetta 2004 Harley Fatboy
    Maryland, United States
    I got a set of these mats and actually a trunk liner as well while I was in England. I called them up before I went over for a vacay ordered them to be made and picked them up when I got there. Haven't taken them out of their wrappers yet actually! Keeping the rubbers in the car till salt and snow season is over.
  33. #2593
    Jan 17 2018
    Weston, FL
    Quote Originally Posted by blubusdrvr View Post
    Great to know, I wasnít aware they offered a trunk liner too...
  34. #2594
    Mar 02 2015
    Great to know, I wasnít aware they offered a trunk liner too...]
    I'm not sure it actually is. I just asked if they could make me one and I guess they figured it out. Not sure it was worth the extra $. Not sure I'll ever replace the WeatherTech one for the nice one. Where would I put car parts?!! Ha.
  35. #2595
    Jan 17 2018
    Weston, FL
    Installed an OEM modified FB Steering Wheel, very happy with the end result and product
  36. #2596
    Veteran Member Four Rings AJacksA4's Avatar
    Nov 26 2011
    Paddy Wagon
    Santa Clara
    Got some new wheels to burn off my old rubbers that were sitting for too long. 19x10.5 et22
  37. #2597
    Dec 05 2006
    So. Cal.
    Amazing look.
    Are you rubbing
  38. #2598
    Nov 26 2011
    Paddy Wagon
    Santa Clara
    Amazing look.
    Are you rubbing
    Thanks! No, no rubbing at all. My fronts are rolled though. I would be if they weren't
  39. #2599
    Dec 05 2006
    So. Cal.
    What size tires you running
  40. #2600
    Aug 29 2014
    Portland, OR
    Quote Originally Posted by AJacksA4 View Post
    Wow... love it!
    What happened to the work Kawami wheels, are those them refinished ? I would like to get my hands on a used set
