Page 59 of 65 FirstFirst ... 9495758596061 ... LastLast
Results 2,321 to 2,360 of 2586
  1. #2321
    Feb 17 2004
    Round Rock, TX
    Quote Originally Posted by steve-0101 View Post
    Where did you get your lens covers? Mine are in bad shape and Iíd love to refresh them.
    www.vxtuning.com has them for $110/pair on sale
    WTB: 2.7T-swapped B6 Ultrasport Avant 6-sp
    2007 RS4 Sprint/Ebony, Ti, 115k
    UM tuned/JHM/034/Bilstein/Milltek/oCarbon
  2. #2322
    Active Member One Ring sialan's Avatar
    Jul 31 2017
    Snoqualmie
    Threw on the summer wheels! 20x9.5 +35 with 10mm spacers, no rubbing. Went with 245/30 all around.
  3. #2323
    Established Member Two Rings thesecretkode's Avatar
    Jun 26 2016
    Boston, MA
    Quote Originally Posted by Chuuey View Post
    You'll have no issues. I am on a 19x10 et20 255/35 and do not rub at all with some minor camber and the front screw removed.
    I'm going with a 19x10 ET20 275/35 on my next setup. I'm gonna rub, aren't I? I'm planning to roll the front fenders a bit a dial in some camber in preparation.
    Present:
    '07 RS4 - Mugello Blue
    [kw v3/jhm 91/hotchkis f+r sways/adv.1 adv.10 mv1/40% tints/tubi rumore/ecs h-pipe/apikol rear diff mount/034 torque, engine, trans mounts]
    '18 S5 Sportback - Glacier White
    '06 S4 25quattro - Avus Silver
    IG: rs.kode
    Club: Audi Sport Boston
  4. #2324
    Senior Member Three Rings bluebull's Avatar
    Aug 29 2014
    LS460L + F250 SuperDuty
    Portland, OR
    Quote Originally Posted by thesecretkode View Post
    Depends on ride height, spring stiffness, tire brand, etc
    Iíve posted my settings and donít rub, but...
  5. #2325
    Jun 26 2016
    Boston, MA
    Quote Originally Posted by bluebull View Post
    Could you remind me what your settings are?
    I'm on KW V3s, (ride height unknown but not terribly low), tires are Firestone Indy 500
    Present:
    IG: rs.kode
  6. #2326
    Jun 26 2016
    Boston, MA
    Oh I'm also -1.8 degrees of camber all around. No adjustable control arms.
    Present:
    IG: rs.kode
  7. #2327
    Aug 29 2014
    Portland, OR
    19x10 rotiform et29 275/30-19, Michelin ps4s, Ohlins TTX-36 set on street mode compression/rebound, 1100lb rear eibach springs, 750lb front eibach springs (I think), 25.5Ē ground to fender (GTF) height, Stern front adjustable CA's set at stock OEM camber, non-adjustable rear camber,
    What's your spring rate pounds?
    Use tape measure to measure GTF on a flat surface...
    -m
  8. #2328
    Jun 26 2016
    Boston, MA
    -m
    Spring rate specs seem to be very difficult to get from KW. I've heard around the ballpark of 550F/700R. But from the comparative fitment measurements I've done, the wheels will fit as long as I roll the fenders.
    I can get you the GTF numbers once I get my car back from the body shop in a couple weeks...
    Present:
    IG: rs.kode
  9. #2329
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by sialan View Post
    and that's the bet picture you can throw up? I can't see S***
    Keyboard is on its way out. Please ignore any grammatical errors.
  10. #2330
    Jul 31 2017
    Snoqualmie
    Haha...well, I deserve that one! Here's a few more.
  11. #2331
    May 04 2007
    Northeast
    Feels good to finally have the time to take care of these things:
    - New oil cooler w/ JHM oil cooler lines
    - Coolant flush w/ expansion tank
    - Power steering flush
    - New washer fluid reservoir, original one was looking gross
    - R8 oil cap, coolant cap and black washer fluid cap
    - Wrapped the front grill in black vinyl, original was a little chipped
    - New engine felt insulation
    - New lower intake guides
    - New front lower grills
    - New foglights
    - New headlight clear corners and headlight lenses
    - New carbon oil cooler splitter
    - Hotchkis front and rear sways
    - 034 lower front end links
    - ECS engine mounts
    - New battery
    - New A/C switch and freon
    - New starter
    - New/used wheels that are currently being refinished and powder coated
    - Detailing everything while itís apart
    I think thatís it, everythingís almost done!
    Glut / Capristo / Baby Seats
  12. #2332
    Feb 17 2004
    Round Rock, TX
    Quote Originally Posted by GrandMarkie View Post
    ECS engine mounts
    curious your impression on these - they're the red/black poly mounts?
  13. #2333
    Senior Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    - New foglights
    - ECS engine mounts
    - New battery
    - New starter
    Wow!!! Solid list. Let me know when you wanna sell.
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
  14. #2334
    May 04 2007
    Northeast
    Yep, those are the ones. Can't complain. No added vibration, seems to feel a little more solid/connected to the road, but not a major improvement. My OEM mounts were fine, I was replacing the starter and thought i'd do these while I was in there.
  15. #2335
    May 04 2007
    Northeast
    Quote Originally Posted by my_RS4 View Post
    It's always for sale, for the right price...which people usually roll their eyes at me when I tell them what i'm looking for.
  16. #2336
    Apr 15 2016
    Beach Cruiser
    Venice
    Nice.. Yup, everything has a price. Maybe when I get a sweet offer on mine, I'll come knocking on your door.
  17. #2337
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Ticked 46k miles on a nice drive through the canyons.
  18. #2338
    Dec 05 2006
    So. Cal.
    What did you shoot that with? Phantom? Mavic?
  19. #2339
    Jul 28 2007
    V8's
    In an Audi
    Mavic, great little toy for the size and price.
  20. #2340
    Established Member Two Rings AA 954's Avatar
    Jan 17 2018
    B7 RS4, Mk5 R32, Mk6 GTI, Mk2 Tiguan & Mk7 Golf R
    Weston, FL
    - New foglights
    - ECS engine mounts
    - New battery
    - New starter
    Great list!
    Where did you buy the headlight clear corners and headlight lenses?
    Was the process to change these complicated? Any pics on how you did this by any chance?
    Yes, I like VW's lol
  21. #2341
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by 65vetteC6 View Post
    I want a Mavic. Have a Phantom 4 Pro right now but it's just too big to take anywhere. The mavic could just go in my bag and I'd be able to shoot at a moments notice. Also, I have yet to use the follow me feature as I'm afraid to lose it. lol
    That's a great shot.
  22. #2342
    Feb 17 2004
    Round Rock, TX
    Quote Originally Posted by AA 954 View Post
    Great list!
    https://www.vxtuning.com/shop/replac...-b7-a4-s4-rs4/
    you'll want to add headlight sealant and clear turn signal lenses. Plenty of headlight / clear corner DIYs floating around.
  23. #2343
    Jan 17 2018
    Weston, FL
    Great, thanks!
  24. #2344
    Jul 28 2007
    V8's
    In an Audi
    I have only used the follow me once in a field, same concern as you. I would definitely suggest picking one up, I got this on Prime day with an extra battery for $400 last year, made the choice easy.
  25. #2345
    Active Member Two Rings WanderLA's Avatar
    Feb 09 2018
    '07 RS4, '17 Guilia, '14 Pilot
    This is why I ultimately decided to go with the Mavic... It's in the same bag as my main camera and all my lenses.
    IG: @wanderlosangeles & @fasttaxi_rs4
  26. #2346
    Aug 29 2014
    Portland, OR
    You are not alone ... I get the same treatment
  27. #2347
    Senior Member Three Rings torquesteer's Avatar
    Mar 02 2012
    RS4 & RSV4
    Lowered it on KW height adjustable springs like everyone else with a functional DRC
    - Quan
  28. #2348
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    B7 RS4 - STG III B6 A4 - Mini R56 S
    Austin, TX
    paint correction, ceramic tints, ceramic paint coating, and xpel film done by xpel austin...awesome group of guys!
    also, picked up euro rs4 window switches and a new set of pedals since mine are beat...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods:
    RNS-e MKII : Milltek : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s
  29. #2349
    Mar 02 2015
    1970 Daytona Yellow LT1 Corvette, 2010 Wolfsburg Ed Jetta 2004 Harley Fatboy
    Maryland, United States
    Please tell me that hood is partially popped! My gap isn't great but that makes my intestines hurt. (Nice looking paint though)
  30. #2350
    Apr 15 2016
    Beach Cruiser
    Venice
    What did you do to your B7 RS4 today?
    Quote Originally Posted by torquesteer View Post
    Nice & looow. Curious..you roll your front fenders?
  31. #2351
    Nov 25 2006
    Austin, TX
    Quote Originally Posted by blubusdrvr View Post
    lol, yea it was popped so they could show me how they wrapped the film under the hood...
    B6 Mods:
    RS4 Mods:
  32. #2352
    Mar 02 2012
    RS4 & RSV4
    No, but I'm thinking about doing it. The rear is rubbing a bit more than what I'm expecting. Either that or bring the rear up higher.
    - Quan
  33. #2353
    Jan 17 2018
    Weston, FL
    Stock tires? Spacers or is it just the ET of those rims that make it look flusher? I also want to lower with the KW kit but debating on changing the tires to 275ís on the stock rims in case it rubs...
  34. #2354
    Jan 17 2018
    Weston, FL
    Quote Originally Posted by jonan View Post
    Thanks for the info on the Pedals, just ordered mine
  35. #2355
    Jun 15 2017
    Wisconsin
    Huh? Didn't realize there was any difference.....
  36. #2356
    Apr 15 2016
    Beach Cruiser
    Venice
    You'll be fine. Ran 275/30 PSS on stockers w/ 10mm spacers. Fronts were rolled.. rubbed minimally in rears on major dips. With no spacers, will NEVER rub.
  37. #2357
    Jan 17 2018
    Weston, FL
    Thanks for the info and great pics, will first try the tires and see how it looks
  38. #2358
    Feb 17 2004
    Round Rock, TX
    Quote Originally Posted by Kenny147 View Post
    he meant Euro 8P S3 switches
  39. #2359
    Senior Member Two Rings Malv1's Avatar
    Nov 23 2012
    1995 Volvo 850 T-5 R
    Rochester Hills, MI
    What is the advantage to these switches? Why change to them?
    - 2014 Glut S4 DSG. Stock
    - 2007 Imola RS4. Milltek catless, non resonated exhaust, APR tune, RS5 20" Rotors... SOLD
  40. #2360
    Dec 09 2016
    Charlotte NC
    They look better, the stock ones are known to peeling so instead of replacing with stock ones again might as well upgrade!
    2008 black rs4
    2001 nardo miata
    Charlotte, NC
