I've put the subject as "Another Brake-bleeding thread" because I searched the topic and can see it's been discussed before, but there seems to be a lot of different answers and I'd really like some clarification and help!!
First, the car:
Model: Audi S4
Type: B5 Avant
Year: 2001
ESP: Yes
Brakes: Standard rear, Porsche 993TT "Big Red" calipers up front.
Back-story: I took the car around Castle Combe a couple of months after I bought it and cooked the brake fluid completely, presumably because it hadn't been done in a while. Got it home and went to change the brake fluid, found the bleed nipples on the front calipers were shot. Tried to fix them, failed, bought new calipers.
Work so far: I've completely drained the brake fluid using a venturi type vacuum bleeder as I didn't want any remnants of the destroyed brake fluid mingling with my nice, new and very expensive Castrol SRF racing fluid. I then filled the reservoir with some cheap standard dot-4 and used the vacuum bleeder to drag it through to all four corners to flush the system, then completely drained it again. The only exception was the clutch, I managed to strip the brake fluid from the brake system but the reservoir level was still slightly above the clutch pick-up line so I left it, the clutch was (and still is) working fine and I don't want to bleed that at this stage. I'm working on a driveway and although I haven't made a concerted effort yet I'll find it VERY difficult to get all four wheels (or even two) off the ground at once because the car is so low, at the moment I'm working on one corner at a time (yes, I'm bored of removing and re-fitting road wheels)
Current situation: I used a pressure bleeder at just over 20 psi and bled the brakes at all four corners, ignition and engine were off. I found mixed opinions about the order to bleed them in so I did Passenger Rear, Drivers Rear, Passenger Front (inner then outer) and lastly Drivers Front (inner then outer) ... at each nipple I got firstly air as expected, followed by bubbly brake fluid, then the bubbles cleared and I got good, smooth, clear fluid out of all six nipples.
At the test drive however it was obvious that there is still a huge airlock somewhere in the system, the pedal is solid when the engine is off but when the engine is running it'll go almost to the floor. Driving it is scary to say the least, it WILL stop, but there is zero "feel" to the pedal.
Now, I've looked on this forum and found a lot of similar posts, and also had various "experts" giving me advice on Facebook too, but a lot of the information is conflicting. Here's a summary of what people are saying:
- I've done it lots of times and never had a problem (this seems to be mainly people who don't drain the fluid past the ABS pump)
- You don't need the ignition on
- You need to bleed with the ignition on
- You need to bleed with the engine on
- You need to bleed in the "correct" order, furthest from reservoir to closest
- You need to bleed in the "wrong" order, closest to the reservoir to the furthest
- You don't need VAG-COM
- You DO need VAG-COM
- When using VAG-COM you open the Passenger Front nipple and fire the pump
- When using VAG-COM you have to flash it once with each nipple open
So based on that lot what I'm really wondering is what on earth I do next... I have ordered Ross-Tech VCDS (VAG-COM) anyway as I think it's going to come in useful in the future, but when it arrives and I go back to bleed the brakes again what IS the procedure? So far as I can gather I pressure-bleed the system again, probably from closest to furthest this time, and quite possibly with the engine running, and then plug in VAG-COM, open the Passenger Front nipple and flash the ABS pump... but what then, do I keep flashing it until I see the air that WAS in the ABS pump come through the nipple? Or do I flash it once and then use the pressure bleeder to push the bubble through? Has anyone actually had this problem on this model of car before and successfully fixed it without paying the Audi garage £235 for the privilege, and if so how?
Sorry it's such a long post for what is a fairly simple question, but I think part of the problem on the threads I've seen so far is a lack of information to start with, hopefully that's not the case this time!!
Thanks in advance!
