Results 1 to 40 of 72
    Senior Member Two Rings shayan_a4's Avatar
    Jul 12 2014
    2014 VW GTI and 2014 mercedes SL550 2014 b8.5 audi a4, c7 A6
    woodland hills
    Quote Originally Posted by blbroo View Post
    I just put -20 washer fluid in the reservoir tonight and am going to try to put this on tomorrow.
    There are at least two guys running w/m on here
    Sent from my toolbox using triple squares
    also which kit did you get and where did you get it from?
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by shayan_a4 View Post
    I had USP price match this company.
    http://www.vr-speed.com/snow-perform...olkswagen.html
    The kit I got had the reservoir included and three nozzles, 100, 175 and 375. The product description states that it only comes with 2.
    The install wasn't technically very difficult, just a lot of manual work. I put the pump and solenoid under the front driver side fender, where my stock intercooler pipe sound box used to be. After I was done, I saw where a guy put all of the components near or in the cabin air intake, which is a neat idea, but might slow down air flow.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Veteran Member Three Rings Carlos74's Avatar
    Mar 30 2014
    Palatine, IL
    Did you have to buy the solenoid separately?
    How did you set up the line from w/w fluid tank? Any pics?
    Sent from my HTC One using Tapatalk
    APR l CTS l EUROCODE l ECS l 034 l PODI l GFB l MAGNAFLOW l H&R l SPC l STANCE l SPULEN l HANKOOK l NGK
    IG: c_lowsB8
    Oct 26 2012
    St. Louis, MO
    is anybody here running meth?
    Quote Originally Posted by Carlos74 View Post
    Yeah, I bought the solenoid separately. It is required if you are running the injection after the T/B.
    For the w/w tank, I drilled a hole and tried to push the hose up through the tank to attach one end of the bulkhead fitting that comes with the kit. I couldn't get it through from the top or bottom, so I used the fitting that came for the Snow tank and threaded it into the w/w reservoir, then used a lot of sealant around it.
    Have some pics that I will post off of my phone. I couldn't find any of my S/D cards for my real camera.
    I pulled the fender liner back and removed the pump from the bottom of the tank It is easy to remove, just pulls up and out. Then, I drilled the hole in a flat area right behind where the pump wires connect. I'm an idiot and filled up the tank the night before after purposely draining it for a few days prior, so I wasted a gallon of $2 washer fluid.
    Then ran the hose over the fender liner to the front side and connected it to the solenoid, then a short tube to the pump, then a section to the nozzle holder.
    Wiring was pretty easy. I used the same 12V that I used for the podi gauge switched source and a ground under the washer filler tube.
    I had to buy the throttle body adapter too. This one looks like it has the right screws, mine didn't.
    http://www.uspmotorsports.com/IE-2.0...tle-Plate.html
    Mar 30 2014
    Palatine, IL
    Great info! I appreciate it!!
    IG: c_lowsB8
    Veteran Member Three Rings ddun's Avatar
    Jun 06 2009
    Stanton, CA
    [url]http://www.vr-speed.com/snow-performance-20012-2-0t-stage-2-2-0t-fsi-boost-cooler-water-methanol-injection-kit-volkswagen.html[/url
    Oh that's my car, those pics still up? Haha
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by ddun View Post
    Still have it? Hopefully you've cleaned that dirt and dust. :-)
    I guess you never ran this with the K03, right? I put the 375 nozzle in this morning and bumped the meth level of my reservoir up. I can feel the difference and am wondering if there is enough of a bump from the k03 100 file to warrant $150 and 40 miles to the tuner.
    Sep 09 2010
    Destin, FL
    That's a damn smart place to put that, I'll keep that in mind if I do this down the road.
