Results 1 to 21 of 21
    Senior Member Two Rings Lanorg's Avatar
    Apr 22 2013
    Floor jacks, torque wrenches, and winter tires
    K04 reinstall - correct washers to use?
    Was searching the forums and didn't come across any exact list of what washers to use when reinstalling k04 turbos (coolant and oil crush washers).
    Been looking at the ECS tuning washers, but want to make sure I order the correct ones: http://www.ecstuning.com/Audi-B5_S4-.../Turbocharger/
    Anyone have a list of the washers needed for coolant and oil lines?
    May 09 2012
    Virginia
    Any of those kits will work. You can probably find them cheaper elsewhere though. You need 8 coolant washers (12x18) and 4 oil line washers (14.2x17.9x1.5). You may also need sealing washers (4) for wastegates. Just go with a kit, it will be easier.
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    I believe Europa's turbo install kit lists the part numbers for the components.
    Apr 22 2013
    Thanks guys. Just the info I was looking for
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Most of the kits I have seen were missing the thicker coolant spacer washer and 4 of the oil crush washers for some reason.
    This is what you need to do all of them.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    May 09 2012
    Virginia
    Quote Originally Posted by zillarob View Post
    The kit from JHM is the only one I came across with the thicker washer and everything else.
    Nov 16 2010
    WetSide, WA
    Not sure why people leave those washers out so often.
    Maybe the oem turbos came with the spacer and the oil line adapters already installed so you wouldnt need them?
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    do you know the thickness for the n0138182 by any chance? thanks for the list!
    Registered User Four Rings UroTuning's Avatar
    Aug 23 2007
    Tampa Bay, FL
    Im sure we could help you source those if youd like
    Veteran Member Three Rings S4gasm aka LOTR's Avatar
    Sep 30 2006
    01 S4 Santorin 6 Spd
    Missoula, MT
    THIS!!! Came in here just to say this, if OP wants to see the FUn you can deal with when getting the wrong kit, check out my build thread.
    If i had to redo it again, I would have gone with either 034 kit, or JHM, they seem to be the only ones who comprehend what is actually required, including the thick single washer.
    http://store.034motorsport.com/turbo...-full-kit.html
    https://jhmotorsports.com/shop/catal...27t-p-322.html
    01 S4/ Stg 3+/K24/+stuff
    08 A6 Avant/ S-Line/ 3.2/ bone stock
    Build Thread - http://www.audizine.com/forum/showth...ld-91-craptane
    Jul 01 2014
    'murca
    how essential is the OD of these washers? I'm trying to put together a list of alternative sources for washers, most can be had for much cheaper than what they're being sold at.
    Sep 30 2006
    Missoula, MT
    Quote Originally Posted by erykv1 View Post
    Considering the alternative is another motor pull, I wouldn't risk it. At $70 it's a small piece of mind. I had an issue when I got the wrong kit with my K24's, tried to source the washers locally, by the time I spent driving to every damn parts store in the area, wasted gas, time, and effort, it was well worth the $70 to just click it and be done.
    Sep 07 2012
    Tucson, AZ
    I actually just ordered a bunch through amazon for the future. 30 of each washer for like $5. These washers are not made of gold lol. Another option is a Goodyear or other hose fitting store near you. They usually have quite a few metric copper washers in the right size for our turbos. I even got some 8mm bolts from Goodyear pneumatics for the boost line off the compressor housing after accidentally snapping a stock one.
    Jul 01 2014
    'murca
    Quote Originally Posted by LightningLou View Post
    Did amazon have the 14.2x17.9x1.5? thats the only one I couldnt find. There are tons of 14x18 floating around but I'm not sure if that slight difference in size will cause a problem like what S4gasm aka LOTR said.
    Pulling the motor again would definitely suck if it doesnt seal properly, but at the end of the day a copper washer is a copper washer.
    Established Member Two Rings VTurbo's Avatar
    Aug 03 2011
    URS6 Avant
    Greensburg, PA
    Thank you for the question, I was just about to ask this. Also thanks to the gurus for answering! JHM it is!
    Sep 07 2012
    Tucson, AZ
    The 14x18x1.5's will work fine. After all, the bolts are 14mm OD anyways.
    http://www.amazon.com/gp/product/B00...ilpage_o00_s00
    Jul 01 2014
    'murca
    Wonder if it being copper will be different than al. Copper is a little harder than aluminum property wise.
    Sep 07 2012
    Tucson, AZ
    No problem at all. I actually prefer the copper over the aluminum.
    Nov 16 2010
    WetSide, WA
    Alum or copper is fine, the important part is that they are annealed, dead soft, and fit.
    When you hear people talk about that motor pull for a 25cent washer, these are them.
    Listen to s4gasm, do not fk around with these!!! Get them from the dealer or another proven source.
    I usually buy 5-6 sets at a time from the dealer. They dont seem to be one of the things they rape you on.
    Jul 01 2014
    'murca
    I agree with everything you say, and you guys have helped me tons during my B5 journey.
    But assuming the washer is correctly sized and the mechanical properties / material composition are the same, I don't think it matters which source it comes from.
    Lol, lets hope I don't eat my words.
    Nov 16 2010
    WetSide, WA
    You are right, but this is not worth risking being wrong
    A set of these from the dealer, that you know will be right, is less than $20.
    Some of the turbo install kits from reputable vendors are a very convenient way to go. Just need to make sure you are getting everything.
