Results 1 to 32 of 32
    Veteran Member Two Rings AFbb2001's Avatar
    Mar 14 2005
    2001 Audi S4
    Chicago
    Best Spring/Shock combo
    What does everyone think the best spring/shock combo is?
    2007 Audi RS4, Daytona Grey and stock for as short a time as it takes me to decide on parts.
    2001 Audi S4 TIP, full AUTOSPEED stage 3, IPT Fully built trans, GIAC Tip Chip, piggie pipes, UUC VM3, custom exhaust manis, ASP TSB, OEM RS4 front bumper, carbon fiber M3 lip spoiler, Stasis Streetsports, RS4 engine mounts, IPP SMIC's....
    Feb 20 2005
    S4 CABRIOLET,Porsche Cayenne, MB ML320E
    montreal
    h andr race/bilstein grooved
    Veteran Member Four Rings fixn2xlr8's Avatar
    Apr 11 2005
    Winston-Salem NC
    Best for the money IMO. Thats what I got.
    Mar 31 2005
    Charlotte, NC
    i hear h&R race and koni adj. yellows. whats the difference between these and the bilsteins?
    Estoril Turbo M3: GT35r, Vac forged pistons, Eagle H-Beams, ARP 2000 11mm, Head studs, Main studs, ARP2000 Rod bolts, Cutring head gasket, Fully balanced and blueprinted bottom end, Torque plated, refreshed head, Tec 3 R, 65# siemans, walbro fuel pumps, H&R coilovers, UUC swaybarbarians, 700+ BHP
    sold: 430hp EVO
    sold: 400hp stealth TT
    Sold: Audi S4
    Veteran Member Four Rings ny02s4's Avatar
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    Bilsteins are NOT adjustable as far as stiffness. Whereas the Konis are. But the only thing with the Konis is that you cannot adjust them once they are installed(no acess to the upper portion of shock). Its kind of like a one time thing so technically either is a good choice for a shock. Oh and the Bilstein's offered at ECS tuning have the optional "grooved" body to allow you to sit the spring a 1/2" lower or higher to even out the drop.
    My question here is does KYB AGX have a shock for the S4? cause if they do then you can simply reach behind the wheel and turn a dial to the settings you like. My old car had these and it was perfect for when id have a full car of people going out for the night or for when i wanna mess around on some turns.
    Ant
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Registered Member One Ring QuickTip's Avatar
    May 06 2005
    Norcal
    May I suggest the Eibach Pro System. I originally had the H&R/Koni setup, and the car sat way too low for me, even at their highest setting. Plus the ride was harsh..
    The matched Eibachs gave me a much nicer ride quality (closer to OEM), perfect ride height, and they're affordable.
    I picked them up through Tire Rack. They don't currently list them on their site, but I'm sure if you gave the the part number [1546.780], they could quote it.
    Feb 12 2004
    LA
    had the h&r/bilstein combo and it was way too soft ... now i have vogtland/koni and it is great .... way better than the h&r/bilstein setup
    Mar 22 2004
    B6 S4 6MT
    Los Angeles, CA
    I can vouch for that. Bilstein is a bit soft. But anything harsher would be almost annoying.
    Registered Member Three Rings jkimspe's Avatar
    Nov 02 2004
    socal
    thats the setup im planning to get
    New - 02S4 homebrew stgIII(asp stgIII as of 5/17/08)
    Gone - 00S4 - 3-, lvl10 tip
    Wicked Motorsports :thumbup:
    AudiMods :thumbup:
    PureMS :thumbup:
    Eurotech Motors :thumbup:
    Veteran Member Four Rings imola_Jon's Avatar
    Dec 05 2004
    2k S4
    NoVa
    ^me too, once PureMS has them back in stock. Anybody know where else to find them for a good price?
    "Power without control, isn't."
    Veteran Member Three Rings Speedymon's Avatar
    Aug 27 2005
    2004 S4
    San Antonio, Tx
    I like the OEM setup are far as ride quality. It just sits too high and weight transfer is a bitch.
    Imola_Jon's supervisor...
    Active Member Two Rings Rican_S4's Avatar
    Mar 10 2005
    NC
    I love my MTM/Koni setup.
    Feb 12 2004
    LA
    with the vogtland/koni setup...ride feels almost as comfortable as stock but more responsive and way less body roll. i also forgot to mention that i had a floaty feeling with h&r/bilstein setup at high speeds which was one of the main reasons for switching to the vogtland setup
    contact mike for any questions as he is very very informative and knows what he's talking about
    Active Member Two Rings knl66's Avatar
    May 07 2005
    2002 allroad MT6, no mods
    Nunda, NY
    I'm with you speedymon, just ordered mine last week from purems.com...Damned backorders! I have a 98 non s4, I just want more aggressive handling but daily driver comfort, guess I'll have to wait and see if this does the trick.
    Registered Member Four Rings LEDFoot's Avatar
    Nov 01 2004
    '99.5 A4 1.8T | '99 Jeep GC 4.7 | '00 S4 (in the shop for a few weeks :( )
    dfw, Tx
    what's the drop on a vogtland/koni setup?
    I don't want too much of a drop, needs to be < 1 inch.
    Vart tog vägen vägen, varför är vi på en åker och åker?
    //Martin
    May 07 2005
    Nunda, NY
    From the posts i've seen, 1.4 inches front and rear.
    I little more than I want too, but for the price and quality, what the hell. I'm dropping from stock (without sport suspension) so it'll look like more whatever I do.
    I've got room to go down.....
    Nov 01 2004
    dfw, Tx
    prolly less of a drop for the S4?
    //Martin
    Feb 12 2004
    LA
    think it was around there....if you want less than an inch you're going to need to go with coilovers. the vogtland was definitely less of a drop than with the h&r's. also the h&r's seemed to sag more and more with time
    Senior Member Three Rings ItsJ's Avatar
    May 26 2004
    BMW 335i
    U.S.
    is the grooved feature absolutely necessary. can i get a nice drop just with the bilstein shocks and hr sport springs.
    thanks
    Current: 2008 BMW 335i
    Past Audi:
    -2002 Audi TT
    -2002 Audi S4
    -2001 Audi A4
    Feb 12 2004
    LA
    oh you'll get a really big drop with the h&r/bilsteins. mine kept getting lower and lower as time went by....absolutely hated it especially with the crappy roads here in LA
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    how did that setup feel compared to stock though? im lookin for a nice low stance but better handling compared to stock.
    thanks,
    Ant
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    May 10 2005
    '02 S4 Sold
    LongIsland, NY
    mike from where? maybe ill go with the Vogtland springs instead of H&R now...
    Ant
    2008 Grand Cherokee
    2002 Audi S4 - Sold
    i will be back!
    Nov 30 2004
    chicago
    Just found these and I am working my way to them. Motons Rock!!!
    http://www.arlanmotorsport.com/about...audi_moton.asp
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    thanks
    No its not necessary at all. Its just in case you want the car to sit even lower.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Feb 12 2004
    LA
    thanks,
    Ant
    yes better handling as anything is better than stock. again the setup felt very floaty on the freeway almost to the point where it didn't feel safe during high speed sprints.
    mike kim @ pure motorsports
    Feb 12 2004
    LA
    or in my case...sit higher
    Veteran Member Three Rings One Nice Audi's Avatar
    Feb 19 2004
    Massachusetts
    I have H&R with Bilstein. I have 1 notch lower in the front so the ride is even out.
    Here is how it look with 19s.
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    Would they be Race or Sport springs?Once again..I LOVE you car!
    Senior Member Two Rings batmannie's Avatar
    Sep 15 2005
    2001.5 audi s4
    huntington beach
    i have the same setup
    Established Member Two Rings route66's Avatar
    Mar 09 2005
    Santa Barbara
    H&R sport and Bilstein sport is what i am running, very happy but after reading this thread i wonder about the floaty fealing others talk about.
    Feb 19 2004
    Massachusetts
    Sport.
    Veteran Member Three Rings fubacari's Avatar
    Jul 13 2004
    ???? coming soon
    phila
    Re: Best Spring/Shock combo
    what is your budget?
    also, when you mean "best," r u referring to performance outright or combination of (compromise between) performance and ride comfort?
    take care.
    '07 A3 2.0T S-line, ibis white/black, AWE Tuning S3 K04 kit and some other goodies
    '06 M3 Coupe, silver gray/black, VF570 supercharged with a few more goodies
    ??? coming soon
    '07 X3 3.0si, monaco blue/gray (hers), a few mods
