Results 1 to 16 of 16
    Senior Member Three Rings Arsenal2012's Avatar
    Aug 20 2015
    Chicago
    Im not an engineer im a mathematician. What do you think about this exhaust crossover
    Its a mixture of an H pipe and an X pipe.
    How do you feel about it?
    Will I get a mixture of both the low end and high end?
    The drawing is on the right, dont mind the other stuff.
    Aug 20 2015
    Chicago
    I guess im just not sure if i would be better off doing the top two tubes straight at 0*-180* or angled at 1*-179* and the bottom tubing at a straight 180*-360* or angled at 181*-359*.
    Or even if...
    I should have a portion of the top tubing inserted into the main tubing to collect some of the exhaust flow.
    I will post diagrams or images of what I am reffering to in a few hours.
    Aug 20 2015
    Chicago
    Quote Originally Posted by Arsenal2012 View Post
    Or even if...
    So here are the ideas I mentioned in my last post that I am kicking around in my head and apparently by myself on this forum
    Mar 24 2013
    Oakdale, CT
    Why not just a normal x-pipe?
    -Adam
    Aug 20 2015
    Chicago
    Well why not a Ford or Chevy?
    Why not follow a man named Hitler or Christ?
    Why not tread the same path?
    Why, because im looking for a balance as stated above in my original post.
    Just because you have black and white paint does not mean you cant mix them and make grey?
    I have been having the idea of building a couple designs with pvc and water testing them for flow. I just have not had the time yet to do so.
    Senior Member Three Rings Der Typ's Avatar
    Mar 04 2015
    Clawson, MI
    Calm down, aluthman only asked a question. No need to get all defensive.
    I like the idea, that you want to try something new, but I don't think that you will see any gains. The x-pipe is already superior to the h-pipe and gives you the low-end gains.
    But you could actually give a call to an exhaust shop or two and see what they think.
    I know that JHM was experimenting with exhaust systems, but could get better results than the Fast Intention ones, so they stuck with it. Maybe talk to them and see what their finding were in that field.
    If you get some results on the water flow tests, let us know.
    Good luck!
    May 21 2015
    Burlington . CANADA
    Lol waste of time
    '15 Q5 TDI
    Technik
    S-Line/Monsoon/Blk Opt/B&O/KW V2/pano roof/H&R spaced/sq521"conti wrapped
    Aug 20 2015
    Chicago
    Quote Originally Posted by R y an View Post
    Lol waste of time
    Your post is a waste of time.
    Me replying to this is a waste of time.
    You offer no elaboration to your comment, have you ever had an original thought?
    Am I speaking to the inventor of fluid dynamics, did you graduate from MIT with an engineering degree and you actually know what you're talking about?
    SMH your comment is as pathetic as your breaths of air ya troll.
    Back to the topic, please comment if you have any real insight, I would love to hear!
    Active Member Two Rings Oblivia's Avatar
    May 06 2013
    Expedition, F150, M35X
    Tacoma, Washington
    I like your idea of experimenting. You can learn some from using fluid flow, but remember the dynamics will be much different for air (a compressible fluid) vs water (essentially a non-compressible fluid). What would be neat would be to mod the main exhaust lines with flanged "stubs", two each. Then you could make several simple bolt-up test rigs to install and check the performance. Compressible fluid flow in a closed piping system (open at the far end) is not easy to simulate, especially since the input (motor) is affected by the flow. Wave propagation, harmonics, resonance, etc. are difficult (but not impossible) to predict in an exhaust system, even with a good CFD (computational fluid dynamics) program. Also, other variables you might want to consider in your testing would be cross-pipe diameter, cross-pipe lengths, and shape of the Y's at/near the junctions. All will likely have an influence on the outcome. I'm interested to see if you have made any progress on your testing. Best of luck!
    How fast is fast?
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    bcuz reinvent the wheel.
    not sure what OP is trying to do, but it looks more like bridge support beams instead of exhaust pipes lol. maybe its his new calling is in architecture
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Senior Member Two Rings mufflerman's Avatar
    Jan 08 2009
    '01 S4 Avant 6 speed, '13 RS5, 993, '99 360 coupe 6 speed
    Sacramento
    We have a lot of customers with ideas that are similar and have paid us to try things like this. My input is that if there are gains to be had they are nominal and potentially cost prohibitive. My advice would be to just go the tried and true X-pipe, it works very well and has a proven track record.
    Aug 13 2016
    New Jersey
    I'm not a engineer but I play one on TV
    Sent from my iPad using Audizine mobile app
    Mar 24 2013
    Oakdale, CT
    It all looks like an X-pipe that was purposely made worse.
    -Adam
    Active Member Two Rings Miami4me's Avatar
    Jan 03 2017
    Miami
    I'm neither an engineer nor a mathematician. As a lawyer, the closest I come to exhaust problems is when someone dies from carbon monoxide exposure. I like the idea of pushing the envelope, though. My comment is that most of the designs seem to increase the volume between the main pipes. As such, I would think they would lower the exhaust pressure. I'm not sure what effect that would have. My understanding is that H pipes equalize standing waves, though that could just be Milltek marketing. I have a Milltek catback setup on order, so I hope to have more firsthand knowledge soon. I had Fabspeed X pipe cats on my prior Porsche 997S, and absolutely loved the performance and sound.
    I'd be curious to know what effect the increase in intrapipe volume has. Keep the ideas coming. There's no substitute for empirical knowledge, so don't be afraid to experiment. Mathematics, I'm told, is theoretical physics.
    Active Member Two Rings S5boxster's Avatar
    Sep 14 2016
    986 boxster
    Nj
    I messed around b8s5 exhaust and other car exhaust. The diagram looks great. But it work like a h pipe cuz the straight would push more exhaust gas as it's more free than the redesigned x. in normal xpipe exhaust gases cross over for a smoother flow of exhaust gas, which help reduce drone and more top end gains and a proper low end gains. H pip naturally has more low end gains but under load will work like a straight pipe and less top end gains. My thoughts on your redesign.
    Sep 14 2016
    986 boxster
    Nj
    Quote Originally Posted by S5boxster View Post
    I would do xpipe for more exotic (euro)sound
    h pipe more muscular sound on a V8 motor.
