Perfect world scenario didn't go as planned when it came to get ting the ABZ started..... two year-old birthday party and spending time with family. On the other hand, the little time I did have I had to partially remove engine to reroute harness and gain extra slack. Wrapped harness again and attached to keep it in place. Took care of some plumbing as well.
I just need to remove the 55pin connector and associated excess. ABZ plenum connectors will be simple and easy to deal with
Combed through layout to match drawings. Note, it isn't precisely accurate.
AUDI B5 (ACK) .....verified with drawing and current configuration of my 1997 A4 2.8 V6 Quattro w/ 5-speed 01A.
T10M/(x) – BLACK PLENUM CONNECTOR (10-point)
1. Empty
2. GREEN/BLUE: ECU TO CLUSTER
3. WHITE/GREY: OIL PRESSURE SWITCH (F1)
4. BLUE/WHITE: ENG OIL TEMP SENSOR (G8)
5. BLUE/RED: REVERSE LAMP/Connector (REVERSEL AMP) IN INST PANEL WIRING HARNESS SEE T10/5.
6. BLUE/YELLOW: ENG COOLANT LEVEL WARNING SWITCH (F66)
7. BLUE/BROWN: ENG COOLANT TEMP TO INST CLUSTER
8. Empty
9. BROWN/RED: VEHICLE SPEED SENSOR (VSS) G68
10. YELLOW/RED (Switched to RED/YELLOW): ECU TO DIAG FOR FUEL SYSTEM.
T10/(x) – TAN PLENUM CONNECTOR (10-point)
1. Empty
2. es/ge to ws/ge, es/ge to white/yellow: ECU to Diagnostic pump fuel system.
3. YELLOW: Auto check system: Automatic transmission only*
4. BLUE: Generator to Instrument panel.
5. BLACK/BLUE: (A70) Conn (15amp, fuse 231) in instrument panel wire harness. See T10m/5.
6. BLACK/YELLOW: ECU to Conn (30 pin, Idle boost) instrument panel
7. YELLOW/BROWN: ECU to Malfunction Indicator Lamp, CEL.
8. BLACK/GREY: ECU to A/C control head.
9. WHITE/BLUE (switched to BLUE/WHITE): ECU to cluster
10.
T6Z/(x) – RED PLENUM CONNECTOR (6-point)
1. BLACK/BLUE: (A20) Wire Conn (15amp) in instrument panel.
2. EXTRA NOT IN SPEC
3. RED/BLACK: Starter to PNP
4. RED/GREEN: Oxygen Sensor to fuse
5. RED: ECU to fuse
6. Empty
T10Z/(x) – YELLOW PLENUM CONNECTOR (10-point)
1.
2. GREEN/BLACK (Switched to GREEN/RED): From ECU to Instrument Panel, K Diag. Connector.
3.
4. Empty, S/B RED/BLACK.
5. BROWN: Engine coolant to cluster temp
6. RED/BLUE: ECU to fuel pump relay.
7. GREEN/BROWN: ABS to ECU
8. GREEN/YELLOW (Switched to BROWN/WHITE): Fuel pump relay to fuse to ECU
9. S/B GREEN/BLACK, but its BLACK/GREEN: ABS to ECU
10. BLACK/VIOLET to VIOLET/BLACK:ECU to center console.
AUDI D2 (ABZ) per drawing. Will verify harness later.
T6A/(x) – VIOLET PLENUM CONNECTOR (6-point)
1. From Z29 (Oxygen Sensor Heater O2S) as BROWN/RED to Connector T6a/1, to ECU pin E4 as BLUE/RED.
2. From Z30 (Oxygen Sensor Heater O2S) as BLUE/GREY to Connector T6a/2, to ECU pin E8 as BLUE/VIOLET.
3.
4.
5. From V144 (Leak Detection Pump) pin 3 to D80 (87A for EVAP solenoid, along with N80/N212/N156)
6. From V144 (Leak Detection Pump) pin 2 to ECU pin D8
T6E/(x) – TAN PLENUM CONNECTOR (6-point)
1. From A2 (Plus15 terminal) fused S6 (10A) to F125 (multi function trans switch) pin1 as BLACK/YELLOW.
2. From J17 (FP Relay) 29/S to ECU pin A4 as BROWN/GREEN.
3.
4.
5.Instrument panel ground connection (E113) to T6e/5 as BROWN, then to J217 (TCM) as BROWN/WHITE.
6. From cluster to A76 (K-wire with ABS/TCM/AC) to T6e/6 connector as GREEN/RED, to ECU pin A7 as GREEN/BLACK.
T10/(x) – BLUE PLENUM CONNECTOR (10-point)
1.
2. From G22 (Vehicle Speed Sensor) Pin 2/G to T10/2 as YELLOW/WHITE, to then G21 (Speedometer) as YELLOW/WHITE.
3. K (Data Link Connector(DLC) Rapid Data Transfer to K-Diagnosis wire in instrument panel (A76) as GREEN/RED, to T10/3 as GREEN/RED, to J217 (Transmission Control Module(TCM)) pin 88 as GREEN/RED.
4. From 87A fused S3 (20A) to Z19 (Oxygen Sensor Heater) as BLACK/RED.
5.J217(TCM) to T10/5 as YELLOW/ GREEN, then to T10g/7 as YELLOW/GREEN
6.
7.
8. From F125 (multi function trans switch) pin 8 to back-up lights as BLUE/RED.
9.
10.
T10A/(x) – BLACK PLENUM CONNECTOR (10-point)
1. RED: BATTERY to E20 (Plus connection (30), in Motronic Multiport Fuel Injection (MFI) wiring harness) to T10a/1 Conn to D50 (Plus connection (30) in engine compartment wiring harness, to Fuse for control module – Auto transmission, which goes to ECU as RED/GREEN to pin D9 (need to verify).
2. E45/5 (Cruise Control Switch) to T10a/2 as BLACK/WHITE to go through Z40 (Plus connection (15) in cruise control wiring harness and split to J217 (TCM) & F125 (Multifunction Transmission Range Switch as BLACK/BLUE.
3. From G82 (Engine Coolant Temp Sensor on Engine) pin 2 as BROWN to T10a/3, then to E123 (Trip Odometer Reset Switch and L&R (K65&94) turn signal.
4. From A2 (Plus15 connection) fused S115 (20A) to 15 pin on ignition coil 2,4,6, BLACK/GREEN.
5. From S3/15 as BLACK to T10a/5, to split in two as BLACK/YELLOW to J217 (TCM #54&55).
6. From G82 (Engine Coolant Temp Sensor on Engine) pin 1 as GREY/YELLOW to T10a/6, then to G3 (Engine Coolant Temperature Gauge) & J218 (Instrument Cluster Combination Processor) as GREY/YELLOW.
7. E105 (BROWN ground connection in instrument wiring panel left) to F8 (Kick Down Switch) to T10a/7 as BROWN/WHITE, to ECU as BROWN.
8.
9.
10. From F1 (Oil Pressure Switch) to T10a/10 as WHITE/BLACK, to then K3 (Oil pressure light) as GREY/BLACK.
T10B/(x) – YELLOW PLENUM CONNECTOR (10-point)
1. BROWN: From 102 (Ground on Trans) to E113 (ground in instrument panel)
2. RED/BLACK: from Break Light switch to T10B/2 connector to ECU.
3.
4.
5.
6. J217 to T10b/6 as BROWN/RED, then to T10g/6 as BROWN/BLACK
7. J217 to T10b/7 as YELLOW/BLUE, then to T10g/8 as RED/ GREEN
8.
9. Y6 (Transmission Range (TR) Selector Lever Display (from red 26pin connection)) as YELLOW to T10B/9, then to ECU as BLACK/WHITE. Shorter explanation: From J219 (TCM) to Y6 (Gear Selector)
10.
T10C/(x) – GREEN PLENUM CONNECTOR (10-point)
1.
2. J217 to T10c/2 as RED YELLOW. Then same color to T19g/3
3.
4.
5.
6.
7.
8.
9. From J104 (ABS) pin 47 to ECU Pin A12****?????
10.
