Results 1 to 10 of 10
    Senior Member Two Rings tomahawk297's Avatar
    Jul 25 2014
    Mississippi
    Question Both CV axles replaced...still clicking noise?...
    So joints on both of my cv axles went out so i bought the replacements from Autozone and installed them. I'm not sure if it's still the CV axles but a clicking noise is still there just as before when my joints were bad. Could it be that the replacement axles are faulty or should i be looking elsewhere? The clicking sounds pretty much the same as before i replaced the axles only a bit milder. Please help, because i'm lost! Thanks for any input.
    Nov 25 2011
    2018 F80 M3 ZCP, 2007 RS4
    Its probably the autozone axles. Get some low milage used ones from ebay then return the autozone axles
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    The first question is what are you doing when you hear the clicking? Turning? Driving in a straight line?
    Senior Member Three Rings nan07's Avatar
    Jul 07 2011
    Frisco, Texas
    my autozone axel lasted me about 4 years then i got another from them for free, gatta love lifetime warranty hahaha
    Jul 25 2014
    Mississippi
    Quote Originally Posted by miA4 View Post
    All of the above. Pretty much whatever i'm doing, there's clicking every couple seconds.
    Jul 17 2015
    miami
    Your best bet is to get it on a lift, or jack stands, and get it in gear and single out the sound. Don't start throwing parts at it like I read a lot of people doing here.
    Jul 25 2014
    Mississippi
    Will have to do this tomorrow because the clunking is worse than i initially thought, it almost sounds like everything is loose underneath the front end.. And now the CEL is on and i have loss of power but i'm pretty sure the problems aren't related... yay..
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Get the ones from O reilyes they are remanufacutured ones. Autozone used to sell remans not anymore if they are gold plated on the part that goes into the transmission where the 6 triples square bits are then it is china it is crap and it will vibrate.
    Sent from my C5306 using Tapatalk
    Ivan
    Jan 08 2015
    Arlington,Texas
    Hub Bearings
    I had the same issue and it ended up being my hub bearings.
    Jul 25 2014
    Mississippi
    So i took the wheel off and noticed that the driver side rotor was loose, it turns out the small bolt that holds the rotor on is missing. Would this cause my front end noise? I would think that the lug bolts would hold the rotor on, but what do i know. Any advice is much appreciated.
    EDIT: So apparently the rotor retainer missing isn't a problem. While accelerating with the wheels in the air, i'm hearing tons of scraping and clanking at higher RPMs. Also, (likely due to me desperately needing an alignment for months and being careless enough to not go get one) the inside of my front tires are completely bald and the rest of the tire is almost full tread.
