Originally Posted by
robr4793
Avus my car is doing this and it is due to me having removed the intake flaps completely after my carbon clean. I awaiting my appointment for a tune. Seems like u are having some sort of flap problem also
Yeah, I was doing a lot of research last night, and I remember someone saying his car was also cutting out at 6500rpm, I didn't know my car was doing this, until this morning I gave it a good run and sure enough, it cut out right at 6500rpm.
No doubt this is related to the flap sensor, EPC, flaps and what have you committee.
The only thing I need to double check before taking my car to shop is making sure I have no vacuum leak, I was working underneath the car this past weekend doing oil changes and removing a busted under tray that a vacuum line coming off it's likely, and also that the white plastic flaps on the front of the IM are not broken.
Also, need to pull the codes...
