Results 1 to 10 of 10
    Established Member Two Rings Blau Flash's Avatar
    Mar 04 2005
    '05 Nogaro S4
    Under Your Bed
    To those with Teon's. I need help
    In order to raise the car a bit, do you have to take off the struts? Or can it be done right on the car with the wheels off?
    Established Member Three Rings db boy007's Avatar
    Sep 22 2004
    2004 Porsche C4S-2003 Audi Avant
    Palmdale California
    Front ,you can do it on the car,with wheels off and both side off the ground on stands. But the BackRear is another story in itself, the coilover will have to come out for you to lower or raise.
    Veteran Member Two Rings
    Dec 18 2004
    Cali
    db boy007: Ouch are you serious? You need to take out the back in order to lower it? Is this only on the Cabs or for all? :(
    There goes my idea of lowering it a bit more for kicks.
    Agent 0: Are you thinking of raising it? Why?
    '98 Acura Integra Type R #1144
    180hp/130tq @ the wheels
    '05 Audi S4
    hp/tq TBD
    Veteran Member Three Rings Sia Bani's Avatar
    Jul 27 2005
    2007 M Coupe
    Palo Alto
    Haw, lower for kicks. If not for yours, then for my kicks. ;-)
    Mar 04 2005
    '05 Nogaro S4
    Under Your Bed
    my 235 BFG KDW/2's are too fat and they rub big time. The tire itself looks like at least a 245
    I decided to go against raising it, it really wont doo much with et32....
    Getting slimmer Nitto555's tomorrow, if that doesn't work. I'm gonna have to trade these wheels.
    Sep 22 2004
    Palmdale California
    teins
    Yes you will have to take the coilover out of the car in order to turn the two rings with that special tool. My son Nevaeh Speed, has done this for me on this cab and also on the Avant I traded in. No fun doing either.
    Mar 10 2004
    '05 S4
    FL
    You can do both front and rear on the car normally. Front just take the wheel off.
    For the rears, just unbold the top control arm and sway bar, then you should have enough slack to move the adjuster.
    Mar 04 2005
    '05 Nogaro S4
    Under Your Bed
    thanx everyone the problem was solved the other way: switched tires
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Re: teins
    When did you get a cabby?????
    So freakin hot
    Sep 22 2004
    Palmdale California
    Re: Re: teins
    So freakin hot
    About 3 months ago. Needed the extra power.
