Results 1 to 11 of 11
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    1.8T - TONS of vacuum - valve cover and crank
    Never come across this:
    misfires, rough idle.
    Main manifold vacuum (at fuel pressure regulator): around 15 inHG.
    Tried to get oil cap off: need screwdriver
    Vacuum at oil dip stick: 10 mmHG! Loud sucking noise when pulling dip stick out.
    Vent line from hockey puck: 10mm HG vacuum. Big time sucking.
    What is going on?
    Pretty much running intake vacuum on valve cover and crank.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Check PVC and crankcase breather tube. at 15inHG idle, it seems that you have a vacuum leak going on (unless it's super hot and have the A/C going). Vacuum at idle should be closer to 20 inHG.
    USP CLUB MEMBER #34
    Feb 20 2010
    Brighton, MI
    15 to 20 inHG manifold vacuum is on the low side.
    But in this context of no meaning, since CRANK and VALVE COVER have 10-15 inHG.
    THAT is the abnormally (and potentially also influences the manifold vac).
    15-17-20 manifold vac is academic at this point. For arguments sake: assume it is 20.
    Also note: engine smoked. NO leak.
    05 Golf TDI
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Leak or check valve issue.
    With motor running oil cap should not be hard to remove.
    Go over all your lines.
    I refreshed all mine 4 years ago.
    Easier than waiting for surprises to pop up here and there.
    ECS has a kit. Or buy what you find is broken.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Jun 08 2008
    Calgary AB Canada
    Its the check valve attached to the block under the intake manifold.
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Feb 20 2010
    Brighton, MI
    The one coming off the block, then into a T. Fairly big line, check valve pressed INTO the line?
    05 Golf TDI
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by vtraudt View Post
    That would be the one. The PCV valve. What model year? It determines which PCV valve is required.
    Feb 20 2010
    Brighton, MI
    AWM engine
    05 Golf TDI
    Dec 28 2006
    Western Maryland
    AWM engine
    Clicky click®
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Never come across this:misfires, rough idle.
    This is basically the diagnostic checklist for PCV.
    Feb 20 2010
    Brighton, MI
    DIFFERENT CAR, Different Engine !!!!
    But: Also TONS of vacuum on valve cover.
    2006 A4 2.0T
    Getting codes:
    008825 - Leak in Air Intake System
    008583 - Bank 1; System too Lean at Idle
    000768 - Random/Multiple Cylinder Misfire Detected
    This PCV looks different, but also has hockey puck; I once smoked (leak tested) a 2006 2.0T and it leaked badly (cracked puck).
    On this one, I can also feel vacuum (was once told on Passat CC engine that vac on the little hole of the hockey puck indicates bad bladder in valve).
    Is high vac (and lean etc.) coming from this PCV valve?
    On 2010 Passat CC, I only replaced (offered aftermarket) the hockey puck lid/bladder/spring. Also available and possible for 2006 2.0T?
    Or do I need complete unit?
    06F 129 101P
    With unknown service/maintenance history, pulley the HPFP cam follower; looks good (will replace with latest version).
    http://www.uspmotorsports.com/Engine...CF4BoChLbw_wcB
    05 Golf TDI
