Results 1 to 19 of 19
    Aug 07 2015
    Audi Navigation Plus System Update....
    Hi guys....
    Any one knows how to update the audi Navi plus?
    And if u have to buy a cd then did anyone try this site?
    http://www.audinav.com/audirnse.html
    They r selling a DVD for 50 dollars. .....
    Thx guys...
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Just plug in a newer map DVD (making sure it's for the RNS-E and not MMI), if there is newer software on it then it will update automatically.
    $50 suggests to me that is a copied DVD and not an Audi original, which may give problems when reading it on very cold or very hot days.
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    They release new discs each year for the RNSE. im assuming the last RNSE disc would be 2012 because after that everything was MMI.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Aug 07 2015
    So is it worth the update or better getting aftermarket android systems that going for 300-500
    Aug 07 2015
    By the way wen I turn on my system it says audi mmi....it's on 08 s4
    Aug 07 2015
    How much is original audi DVD from dealer by the way???
    Veteran Member Four Rings blai76's Avatar
    Aug 25 2011
    planes, trains and automobiles.
    San Francisco, CA
    Quote Originally Posted by FastEddie View Post
    They continue to release RNS-E updates still. This year's for example:
    I personally have the 2013/2014 OEM disc as well in my MKII.
    Bob
    2008 B7S4tip Avant, 1998.5 B5A4tip 2.8L V6 (retired)
    Aug 25 2011
    San Francisco, CA
    Quote Originally Posted by Ivan10S4 View Post
    Totally subjective here. If you can't stand audi navigation and music interface, or you must upgrade all amps and speakers because you are an audiophile, then aftermarket/android is the only way to go. If you hate non-oem look and dash kits, then stick with your RNS-E and update the disc if needed. All you gain on the RNS-E MKI from software update is the up-to-date map from the year disc you purchase, so don't bother unless you really need the new maps. I don't believe any additional functionality from a software update, other than a new image during boot, but I am sure someone will speak up and keep me honest, if I am wrong about that.
    2008 S4 came with either a symphony system, or the RNS-E MKI unit. You have the RNS-E MKI unit. On the RNS-E, the initial display shows MMI because that is the Operating System (software) that resides on the RNS-E (hardware).
    Something like $250+ USD. You can find original discs for cheaper on ebay some times. I purchased my 2013/2014 OEM disc in original case shrink wrapped and never opened, for $100 straight up from a guy on ebay.
    Bob
    Apr 01 2012
    Queens
    Nice blai good to know!
    Jan 14 2007
    Hampshire, U.K.
    Wrong, there are 2015 DVDs.
    Aug 07 2015
    Hi guys.....
    Will this dvd work?
    http://i.ebayimg.com/00/s/NTAwWDQ5Nw==/z/WdcAAOSwu4BV0r69/$_1.JPG
    Thx
    Aug 07 2015
    Or this?
    Both same year but one says audi mmi and other says audi rense
    http://i.ebayimg.com/00/s/NjAwWDYwMA==/z/uJsAAOSwyQtVzWsx/$_1.JPG
    Thx
    Aug 07 2015
    Quote Originally Posted by blai76 View Post
    Where did u get it from?
    Aug 07 2015
    I called audi dealer and asking me for 499 plus tax for the upgrade dvd.....
    Now that's pathetic as I can get an aftermarket all in 1 system for that price......installed.....however am trying to save money.....and found those dvds on ebay for 40 dollars include shipping but I wanna make sure they will work.....
    Jan 14 2007
    Hampshire, U.K.
    Hi guys.....
    Will this dvd work?
    Thx
    That's an MMI DVD, not an RNS-E DVD so it won't work.
    Jan 14 2007
    Hampshire, U.K.
    Or this?
    Thx
    That picture is too small to read.
    What you need is an RNS-E DVD which has a part number that starts 8P0.
    Aug 07 2015
    The second one says this part number
    Model
    8P0919884_CA_NAR
    And wen u zoom on the cd......it says rnse however it's not 2015....
    On the cd it says 2013-2014 version
    Jan 14 2007
    Hampshire, U.K.
    Model
    8P0919884_CA_NAR
    That sounds like the latest DVD part number http://audiforum.us/threads/audi-nav...-numbers.6857/
    The 2014 DVD was 8P0 919 884 BP (don't worry whether the second group is 919 or 060 that only indicates whether the DVD was supplied new with a vehicle or sold as a part through a dealer).
    Aug 07 2015
    Quote Originally Posted by PetrolDave View Post
    Great am gonna order 1 as its only 40 dollars include shipping
    Thx for ur help bud
