Results 1 to 11 of 11
Hybrid View
    Senior Member Three Rings Marshall_Placid's Avatar
    Aug 11 2012
    2013 RS5, 2012 A6, 2010 Q5 (SOLD!)
    Vancouver, BC
    Lowering the S3 Questions
    I appreciate anybody's input on the matter of lowering my 2015 S3.
    Info:
    2015 S3 with magnetic ride
    Questions:
    I understand that with my magnetic ride option, I can only use springs, not an entire coilover system.
    For springs, how long do they last?
    I've heard they last on average about 4 years.
    If this is the case, how would I know when to change it?
    This might be an absurd question to ask, but I'm a total newbie at lowering cars:
    Is there any chance, however remote, that my car's suspension would suddenly fail and while driving, my car would stop dead in its tracks?
    Also, I understand that when I lower the car's wheels and tires will have an even larger negative camber.
    To offset this, if I understand correctly, I would use a "camber adjustment kit".
    Is this correct?
    If so, would that negatively affect my car's safety by using an adjustment kit to reduce the negative camber (caused by lowering the car with the springs)?
    If I implement the springs system now, am I able to take it back out, 4 years later, and use my stock springs?
    I know the S3 is 25mm lower than an A3.
    What is a safe, yet desirable, height to be lowered?
    I mean, I don't want to scrape the bottom every time I drive over a small bump in a parking lot.
    And, by lowering a car, using springs only with magnetic ride (not an entire coilover system), how much HARSHER is the ride going to be?
    And finally, what springs do you guys recommend and why?
    Thank you guys!
    It is much appreciated.
    2013 RS5 - Misano Red - 20'' x 10'' BBS CX-R w/ 275/30 P-Zero Run-flats, B & O, Driver Assist, Navigation
    2012 A6 3.0T - Ibis White - S-line - 20'' x 9'' Stock 7 Rotor Wheels, P-Zero, Bose, Driver Assist, Navigation
    Established Member Two Rings R3_TDI's Avatar
    Feb 04 2015
    Wiesbaden
    Ok with mag ride you can install coilovers, there is an adapter piece you need to install to fool the electronics. I like coils and I'm pretty low the only time I have to watch out is when there are ridiculous speed bumps or pot holes the size of the moon..... And since I'm stationed overseas whenever I drive on base.
    This is my car on coils
    This was before
    And this is with the car full of people and a trunk full with luggage
    Since I've lowered the car I have only scraped 3 times.... But in Germany the road are pretty good.
    Sent from my HTC One using Tapatalk
    Apr 16 2009
    S.cali
    Quote Originally Posted by R3_TDI View Post
    By doing that mag becomes completely disabled?
    Feb 04 2015
    Wiesbaden
    I'm not if it's disabled but if you want to know more ask Timba-Inc i think he has one on his s3
    Junior Member Two Rings
    Jan 18 2015
    CA
    i did spring only once. never again.
    the ride quality becomes terrible.
    and if you lower more than 1" your camber is not ideal. need camber kits.
    not enough dampening and interior and other parts shakes and rattle.
    do it right go with coil or replace the shocks matching ones.
    yeah $1000+ vs $300
    but imo do it right the fist time.
    Apr 16 2009
    S.cali
    Seeing all your lowered S3 is becoming a bad influence in buying my S3 early then I want too...haha
    How much do KW DDC coils run for generally speaking?
    Aug 11 2012
    Vancouver, BC
    Thanks guys for the invaluable information.
    Will definitely consider seriously getting the coilover system instead of just the springs.
    Jul 01 2015
    Temecula
    There are some on this forum I see successfully lowered with springs only. H&R. Feedback seems to be good.' Those lowered with springs have the Mag ride suspension though. All my cars I have lowered have always been coil overs.
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    I have my S3 on ST XTA, and very pleased with my purchase. I have around 6,000 miles on them.
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Mar 02 2016
    Orange County
    Quote Originally Posted by JGreen76 View Post
    Hi, how did you get the camber plates on xta to work? I'm installing right now and a little lost as to how would I make the camber plates visible in front?
    Sent from my SM-G935T using Tapatalk
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    The ST-X and ST-XTA are both great and have a 5 year warranty.
