Page 1 of 33 12311 ... LastLast
Results 1 to 40 of 1312
    Senior Member Two Rings UberBrute's Avatar
    Jan 05 2014
    E91 BMW 328xi 6MT
    Connecticut
    Engine rattling noises at cold start - V6 3.0 TFSI
    A few months ago my car started making a rattle for 2-3 seconds on cold starts (usually in the morning). I looked around and didn't find much in terms of tsb's or anything really. Earlier today "Race Shooter" posted a link to a website that will show you tsb's. I checked there and found one for engine rattle on cold start. Here is a link to the post from "Race Shooter".
    http://www.audizine.com/forum/showth...1#post10900711
    and here is a link to what it sounds like, not my video but same issue and found through another audi forum during my searching, https://www.youtube.com/watch?v=AS8k3Saet7Q
    Long story short, the upper chain tensioners need to be replaced with a newer design. This TSB is new as of March 2015. It states in the tsb that no damage can happen, but who knows given audi's track record with cam chain tensioners..
    Any have this done yet?
    Technical Service Bulletin
    15 Engine rattling noises at cold start - V6 3.0 TFSI
    15 15 26 2039995/1 March 3, 2015.
    Model(s) Year VIN Range Vehicle-Specific Equipment
    All 2011 - 2014 All V6 3.0 TFSI
    Condition
    Rattling noises are heard from the timing chain drive for about 1-3 seconds after the first engine start of theday.
    Technical Background
    The noises are caused by one of the upper chain tensioners. The noises do not lead to damage.
    Production Solution
    Improved chain tensioner.
    Service
    1. Verify condition by observing engine sound during cold start.
    2. If the rattling noise comes from the area of the timing chains (back of the engine) for 1-3 seconds after the first start of the day, replace both upper chain tensioners of bank 1 and bank 2 with the optimized chain tensioners.
    Technical Service Bulletin Warranty
    Claim Type: Use applicable claim type. If vehicle is outside any warranty, this Technical Service Bulletin is informational only.
    Service Number: 1536
    Damage Code: 0010
    Labor Operations: Chain tensioner remove+reinstall (See Elsa for SRT specific to model) 1536 20XX XX TU
    Diagnostic Time: GFF No allowance 0 TU
    Road test prior to service procedure 0121 0002 10 TU
    Road test after service procedure 0121 0004 10 TU
    Technical diagnosis at dealer’s discretion
    (Refer to Section 2.2.1.2 and Audi Warranty Online for DADP allowance details)
    Claim Comment: As per TSB #2039995/1
    All warranty claims submitted for payment must be in accordance with the Audi Warranty Policies and Procedures Manual. Claims are subject to review or audit by Audi Warranty.
    Required Parts and Tools
    Part Number Part Description Quantity
    06E109217AH Chain tensioner bank 2 1
    06E109218AJ Chain tensioner bank 1 1
    Additional Information
    All parts and service references provided in this TSB (2039995) are subject to change and/or removal. Always check with your Parts Department and service manuals for the latest information.
    SOLD 2013 Audi S4 | 6MT | Estoril Blue Crystal | Premium Plus | MMI Nav Plus | Sports Differential | Carbon Atlas Inlays | Alcantara inserts | 19" Peelers |
    Established Member Two Rings cchase231's Avatar
    Dec 02 2014
    SE Michigan
    looking for more info on this as my car has been doing this more frequently as of late. Has anyone had to do this? Is there really no concern about damage? The noise is embarrassing and definitely doesn't sound harmless.
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    I have it. Seems very common. I have a little bit of concern and I'm curious how receptive dealers have been to fixing this.
    I also wonder if the other 3.0T powered vehicles have the same issue.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Dec 02 2014
    SE Michigan
    how often is happening for you? When did it start? I am not finding a whole lot of experiences with this issue on the web.
    Oct 02 2013
    Redstone, CO
    My 14 has been doing that for some time. Only on cold starts. The car behaves normally otherwise but I makes the exact same sound. I never thought much of it. 34000 miles.
    2014 S4 Estoril Blue, Black Opt, 19" Rotor, Side Assist, Carbon Inlay, B&O Sound, MMI/NAV, Rear Camera, Advanced Key, Supercharged badges, H&R OE, Track+ Spacers, 10/15mm, otherwise stock.
    Jun 06 2016
    Atlanta, GA
    I think have it a little bit. Almost like a vibration that lasts ~1 sec on cold start first thing in the morning. It does not seem to be as pronounced on the afternoon start when getting ready to leave work.
    I was just planning on having the dealer look at it during my 45k oil change. Will provide them with the TSB for reference.
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    I did it, its a BIG job and they will only do it after keeping the car for a night to verify the symptoms as a result of the labor required.
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Senior Member Two Rings dyl0n's Avatar
    Dec 14 2014
    New Orleans, LA
    I've had it done. Took them a few days (parts and stuff) but I had a loaner. I could not believe how quiet the car was actually supposed to be when it started. Even when the rattle didn't happen, it was still louder than it is now on starts.
    I definitely recommend getting it done.
    B8.5 S5|P+|DSG|Sport Diff|APR Stage 2+|APR Stage 2 Intake|ST Coilovers|20x9.5 RS5 OEM Rotors|AP Racing 370mm BBK|Pirelli P-Zero 275/30|Ecodes|B&O
    AWAITING BOOST SEASON
    Jun 06 2016
    Atlanta, GA
    Quote Originally Posted by QuattroRocket View Post
    It's not an engine out repair, correct?
    2013 S4, Ice Silver Metallic, Sports Diff, B&O, ECS Kohlefaser Luft-Technik
    Oct 20 2008
    Denver
    '14 here, definitely started about a month ago. from the TSB it's only audible and no damage correct? so even if the upper tensioners aren't replaced it won't affect anything?
    Dec 02 2014
    SE Michigan
    Quote Originally Posted by AudiTFSI3o3 View Post
    This is what I would really like to know. My car is out of warranty and I'm looking at close to 3k to do it. The indy and dealer said it the noise is cause for concern, but this tsb says otherwise. The all of sudden increased frequency that it has been happening for me has me a little concerned.
    Jul 10 2015
    SATX
    My car has done this since I have owned it starting at 11,000 miles.
    Now I have to weigh the risk/benefit of them breaking my car while applyig this fix.
    Oct 20 2008
    Denver
    Quote Originally Posted by cchase231 View Post
    TSB's and recalls can be performed outside warranty so shouldn't be a problem going to Audi either way.
    speaking of which, just broke 40k on my '14 lol
    Dec 02 2014
    SE Michigan
    I don't think TSBs are covered out of warranty. If you look at the TSB it says outside of warranty it's for informational purposes only. From what I gather after a few conversations a TSB is not an admission that there is a flaw in operation, just a guide for the tech. A recall on the other hand is always covered since they are admitting something is faulty.
    Dec 14 2014
    New Orleans, LA
    Correct. Try to get all the TSBs done you can under warranty. This was a $1800 job if not under warranty.
    Aug 11 2015
    Alberta
    Part of the reason I haven't done this is the TSB says it's not damaging, and I don't want to drop the car off for a few days and/or have the dealer say they couldn't replicate or find a way to void my warranty anyways.
    Veteran Member Three Rings JWreck's Avatar
    Jul 28 2014
    Cedar Park, TX
    Dealer has my car for a transmission replacement; I'm asking them to look into this as I have the same annoying noise.
    2019 RS5 Sportback | Nardo | Nappa | Dynamic | RS Driver Assist | Black Optics | Dynamic Steering | B&O
    2017 AMG C63S | Gone
    2014 S4 P+ | Gone
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    And I thought the 2.0T (EA888 Gen-1 and Gen-2) was a timebomb with its timing chain tensioner issues......now I have to worry about my S4 and the wife's 2.0T VW CC.......I just bought the tensioner update kit for that last week.....what's with VAG and bad tensioner designs ????????
    Dec 02 2014
    SE Michigan
    Quote Originally Posted by cjw View Post
    Based on my recent experience that is exactly what they will do.
    Jun 06 2016
    Atlanta, GA
    Quote Originally Posted by S4'ed View Post
    "timebomb" is a bit strongly worded. Most cars have a bit of chain rattle on cold starts.
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    I wondered about the little bit of rattle on cold start. Guess I can get it looked at.
    Dec 02 2014
    SE Michigan
    Quote Originally Posted by dyl0n View Post
    Just got a quote from a dealer, $3200 with possible overages. Both the dealer and the indy said it should be addressed, but the tsb states no damage is done? Not sure what to think here.
    Dec 14 2014
    New Orleans, LA
    They did say on the A7 they had to pull the motor out to fix it. However on my S5 they said they did not have to.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    There are over 100,000 3.0Ts running around. I get there was a TSB for it, but it is not a common issue by any means.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 02 2013
    Redstone, CO
    I took my car in for the 35k service yesterday. I am confident my car makes that noise on occasion. I mentioned it to my SA. He was receptive to looking at it and put it in the notes but mentioned that he believes the noise is somewhat normal. He said they'd look into it but I didn't get the impression that it would be taken very seriously. Well this morning he called to say that they agreed and would be replacing the tensioner. He also mentioned that its a big job and would take a couple days to finish. I'm leaving town for work for the next 5 days there's no real issue for me. I'll update this thread when I return but I'd suggest you mention this to your SA and have it looked at.
    When my cars are under warranty, I don't let anything slide. If theres a noise or I have a complaint, I put it in writing.
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    My car definitely made the same noise. I mentioned it to my SA at 45K service, they verified and fixed it, tensioners as well as camshaft sensor. It took a few days mainly due to waiting for parts arrival. And it didn't have to pull the engine out. Car now starts with 0 noise, and runs smoother as well. If you are under warranty definitely get it fixed ASAP.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Used to have the same problem back with the old 3.6 VRs on start up due to oil starvation.
    Sooner or later that tensioner will just grenade. I wonder what's the difference between the revised tensioner and the superseded one
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Dec 07 2014
    Mn
    Bringing mine in for this next week. I suppose will also be testing TD1 since I'm pretty sure they will hook it up to the machine.
    Sent from my LG-H901 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Oct 20 2008
    Denver
    welp, dropped the car off Wednesday morning to diagnose some fueling issues as well as the TSB for the tensioner rattling. They gave the car back to me this morning saying "it's normal." Lazy much?
    Jan 09 2016
    That is BS, find another dealer
    Veteran Member Three Rings VeNoMS4's Avatar
    Feb 02 2016
    Peoria, Arizona
    Agreed. I could not replicate this noise when i was at the dealership and this noise only started after i did my 55k mile service at the dealership. Finally i found a video that i can show and will see what my dealership says.
    Oct 02 2013
    Redstone, CO
    Update,
    My car is going back to the dealer for a CEL. Long story short...they replaced the tensioner and fuked the car up. They kept it for a week because of CEL. Tonight, I got another CEL with less than 30 miles on the odometer since I picket it up. This repair is a big one and I think my dealership was frankly caught off guard by it. The original repair took almost a week and then during the test drive the CEL happened. After an additional 4 days to clear up the CEL I was told the car was ready. Tonight I got the CEL again. I'll take it in Monday and leave it.
    If I could do this over again, I'd live with the rattle. Now that I'm going down this path and still under warranty I'm going to be very far up my dealerships ass until they get this right.
    Nov 08 2008
    Los Angeles, CA
    When you say cold start, do you mean only in a cold environment? Just curious if folks are seeing this in warmer climates as well, such as starting your car first thing in the morning in California or Florida?
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by A4Ultrasport View Post
    I'm in Arizona and I get this.. Although a lot less now that it's really hot here but I still get it here and there. Contacted dealership
    Sent from my Nexus 6P using Tapatalk
    2011 S4 -Ibis White // GIAC Stage I // GIAC DSG tune // AWE Track Cat back // Injen SP Intake // VMR V710 19x9.5 //
    Jun 28 2016
    US
    Quote Originally Posted by Thurston View Post
    is this a pretty serious surgery we are talking about? Things seem like theyre never the same after an audi mechanic works on my car; i can't imagine with a serious operation but maybe i'm just feeling the glass half empty this morning.
    It's an engine out of the car sort of thing I believe. It's too tight to get to the back of the engine where the timing chain is with it so close to the firewall and they need to take the trans off anyway.
    Dec 10 2011
    CLT | MKE
    I don't think that's the case for the upper guides/tensioners described in this TSB.
    Several people have commented that their engine didn't need to come out.
    Sent from my iPhone 6 using Tapatalk
    -Hayden
    Aug 25 2013
    florida
    i doubt its cold weather related, mine does this on the first start every time in florida.
    2014 sfeux p+ 6mt bo nav w/o sd
    Senior Member Two Rings trevor51590's Avatar
    Dec 18 2007
    '21 S4, '21 Q5
    Definitely have this in my car. It's after the pressure in the engine has normalized following engine shutdown (not sure exactly, haven't timed it yet). I have this with mine as well, going to ask the dealer about it along with some other TSBs.
    '25 RS6 Performance | Daytona Gray/Congac/Black Dinamica | Executive | Black Optics | RS Sport Exhaust | RS Driver's Assist | B&O
    '21 Q5 Premium Plus | Navarre Blue | Nav
    '21 S4 Premium Plus | Daytona Gray | S Sport | 034 Stage 1
    --Gone but not forgotten--
    '23 RS5 Sportback | '18 A4 Premium Plus | '18 Q5 Prestige | '13 S4 Premium Plus | '11 S4 Premium Plus | '06 A4 2.0TQM | '99.5 A4 1.8TQM
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    This sound like the hydraulic tensioners just need time to pump up and provide proper timing chain tension on cold starts. Like hydraulic lifters in the valve train. Car sits, lifters deflate then takes 2-3 second on cold start for them to pump up and do their thing. Should be pretty harmless unless it does for any extended period of time, just annoying. They need a better lifter design. On my motorcycles I used to install manual tensioners for this issue. For the guy getting check engine lights, the tech probably messed up cam timing trying to fix the tensioner. All that time he was probably trying to get it right, taking it apart, putting it back together seeing its still off a tooth, rinse and repeat. This is precisely why I do all my own work. Pull the code yourself and see what it is. My bet is a P0011 or some variation of it.
    Established Member Two Rings Vdubz's Avatar
    Mar 19 2016
    Greensboro, NC/ Long Island,NY
    I get this in mine as well. '14 with 24k on it. Bought it a few moths ago. Still has warranty and Audi care. Brought it in to stealership for the rattle and bc of vibration in slow speed turns. I was told the vibration was normal and all Quattro systems do that. The noise from the engine was said to be normal and he had an S5 that had 15k on it and it did the same thing. His was sitting since he drove it in and sat for the day. He started it and claimed all the 3.0T's do that. I hate when they. Low smoke up the customers ass. The link for the tsb brings me to a site to search for tsb's and I don't see that one come up. Does anyone have a direct link? I traded in a trailblazer ss because of a similar noise and it drove me crazy. That was piston slap and it lasted slightly longer Than this but it is a little embarrassing to hear.
    Sent from my iPhone using Craptalk
