Hey all, I'm having a low boost issue on a 2002 A4, completely stock. I've already performed multiple boost leak tests and have found not a single leak (surprised). I also found that my lines from the breather tube were all filled with crap and actually clogged completely so I replaced everything including the breather pipe and ran another boost leak test and still no leaks. Pretty sure the pancake valve is good since I can take the oil cap off and oil dipstick out without issue. I haven't actually properly tested the diverter valve yet, I did take the line off that connects under the plenum to the solenoid and sucked on it and put my tongue on it. It held vacuum. I plan to actually take the DV off this weekend and properly test it though.
The most boost I will see in any gear and any load is 6'ish and the car is very sluggish. I'll usually hover around 5 though and even lower at times in higher gears. I've pulled codes and there is not a single code stored. The only thing I can think of is the DV is bad. Any other thoughts as to what could be wrong? I've read that limp mode will put you at about 5psi but I dont have any codes either. I also have seen in my research that there is a hose you can disconnect from the N75 valve that will bypass the controller and run strictly off of wastegate pressure. Haven't tried that yet either. Can someone direct me as to which line I remove and do I have to cap the line or the port at all?
I've owned a B6 previously and I dont remember it being nearly this sluggish although to be fair it would actually hit full boost.
