Originally Posted by
piotrowr
When I had my car in at an indy shop for service they told me my control arm bushings are starting to go bad. They said not urgent but will need to replace the control arms soon at a cost of about $700 for parts and labor. They did point out that at 45K miles this does seem premature. It's a 2010 so am curious if it had the upgraded control arms with harder bushings already or will dealer address with TSB?
Late-style lower control arms have a 75mm bushing. If you have those, then you have updated factory control arms. If your car still has early-style 65mm bushing lower control arms, I'd recommend trying to get the arms covered by the TSB. The year split for old vs. new isn't clear-cut IIRC, but you should be able to call a dealer with your VIN and figure out what it came with.
We've seen the uppers start to go bad around 50,000 miles, but I don't believe there is a TSB or update for those. Hope that helps!
- Laszlo
