Originally Posted by
daught
Damn. The conical wheel bolts that my car came with protuded 17MM.
The ronals I got for winter came with ball seat that protuded 21MM.
A wheel shop told me not to worry if the bolts are a bit shorter. Is that true? Will the short bolts be an issue?
I don't know about metric threads, but with common inch threads, in steel 1.0 times the diameter of the screw is considered "full" engagement. For aluminum it's 2.0 times the diameter. And in case anyone cares, it's 1.5 times the diameter in cast iron. That's as strong as bolt/threaded hole will ever be.
14mmX1.0=14mm. Any more thread than that is just showing off. Oops, gotta add for the rotor thickness that's sandwiched between the wheel and the spindle, guessing 5mm. That makes Skyler's 19mm right on the money.
Your 17mm bolts are only 2mm too short. You'd need an engineer to tell you exactly how much peril you would be putting yourself in, but I doubt it's enough to worry about.
