Page 6 of 169 FirstFirst ... 456781656106 ... LastLast
Results 201 to 240 of 6744
  1. #201
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Maybe it's time for a fluid flush? Has that ever been done? I did one once, but used a fluid that wasn't intended for cold weather. The car was a bitch to shift in cold winters.
    If you're talking about transmission fluid yes I did it about 20k ago. Used redline synthetic so I might just do it again soon just to see.
  2. #202
    Veteran Member Three Rings Reckon's Avatar
    Jul 16 2015
    St. Petersburg, FL
    Quote Originally Posted by jokingjimmy View Post
    Same button to turn off the door chime :) (on a per door open basis lol)
    This I did not know. So I hit that if a door is open and the chime will stop? Nice!
    2014 Estoril Blue Audi SQ5 Prestige
    2017 Ebony Black Jaguar F-Pace Prestige
  3. #203
    Jul 16 2015
    St. Petersburg, FL
    Quote Originally Posted by cchoi83 View Post
    Same here. My seat heaters work completely independently of my HVAC. I think it's safe to say that this was a change made on our B8.5s.
    Also the same for me...no issues with HVAC when using the butt warmers.
  4. #204
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by Reckon View Post
    Yup. Rocker switch on the wiper stalk does it, too. Also silences the "lights are on" buzzer.
  5. #205
    Jul 16 2015
    St. Petersburg, FL
    Nice!
  6. #206
    Mar 12 2013
    NB Canada
    Quote Originally Posted by Senseless View Post
    When navigating, the small info screen, which is directly behind the steering wheel, replaces the digital speedo info with the navigation info, which I don't want. Is there a way to keep the digital speedo up all the time?
    Not sure you can keep up all the time default. However the bottom button on the lever on the right of the steering wheel, click it 4 times (may be 3 times) and you will have speed displayed on that screen. Used to bug me too.
  7. #207
    Mar 21 2015
    ^Day late
  8. #208
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    & dollar short. lol sorry couldn't resist
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
  9. #209
    Dec 18 2009
    Toronto/ON, Canada
    Hey Guys,
    Question about Oil Change.
    MMI is reporting my oil level is at half. Did my last oil change as part of the 85K service at 83K(KMs). I am at 93K(KMs) right now. Am I OK to just top up until the next scheduled service or should I just do an oil change ?
    I personally do not like driving with low oil level even if the computer says 'OK'.
    I have read that it is better to perform an oil change in between the Audi recommended service schedule and I was planning on doing one at 95K, but I am pretty busy this whole month and won't have time to do an oil change till probably January.
    So can I drive with the level at where it is until I can change it next month or is it recommended I top up for the time being ?
    Thanks
  10. #210
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Is there any way to lock the car when exiting? This is the first car I've ever owned where I can't open the door, hit the lock button, then close the door.
    I hate having to close the door, then hit the button on the handle once it's closed (sometimes it's not that responsive).
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
  11. #211
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by rraj2k9 View Post
    Hey Guys,
    AMI is reporting my oil level is at half. Did my last oil change as part of the 85K service at 83K(KMs). I am at 93K(KMs) right now. Am I OK to just top up until the next scheduled service or should I just do an oil change ?
    Thanks
    You can keep driving it. Assuming the MMI readout is correct (which is highly debated), when it reaches the 'Min' level that represents being approx. 1 quart low. You do not need to add any oil until you reach that point. I would imagine that by the time you reach 95km you will still be at around the half way mark on the MMI readout, unless you are romping on it in which case you can expect to see some additional oil consumed.
    SOLD 2015 Daytona Gray S4
  12. #212
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Hey Guys,
    Thanks
    buy a dipstick so you can really know . I would add oil . Not sure what "half down means" 1/2 quart? Dipstick would be only way to know.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
  13. #213
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    "The S4 DOES NOT have auto-defrosting side-view mirrors?!" That is the question I asked myself this morning as I tried to merge on the highway and realized my side views were completely fogged over. I figured it would make total sense that Audi would not include an auto-defrost feature since they also took away power folding.
    It turns out that the selector knob needs to be set to the center position to turn on defrosting feature. Another head-scratching moment in the S4...
  14. #214
    Aug 22 2014
    bloomfield,ct
    Quote Originally Posted by The Fat Kid View Post
    and turned to RT mirror position if you want mirror to turn down to the ground(if you have so programmed it)
  15. #215
    Mar 10 2015
    New England
    Quote Originally Posted by jygesq View Post
    That was one of the first things I did when I picked up the S4, and the reason why I was so confused this morning when they were not defrosting. The POWER-FOLDING side-view mirrors on my B6 A4 still auto defrosted when the right mirror was selected
  16. #216
    Oct 14 2012
    Empty...for now...
    SE PA
    It's very annoying. All winter I leave the mirror position selector in the center position so they always defrost, and then when I get home, where I always back-in park, I have a moment of rage every day when I put the car in reverse and the passenger mirror does not dip.
  17. #217
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    Quote Originally Posted by SteveYem View Post
    first world problem
  18. #218
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    That's annoying. I read my manual a while ago, but I just assumed they defrosted when the rear defroster was on.
  19. #219
    Mar 10 2015
    New England
    Quote Originally Posted by DBL R View Post
    first world problem
    Oh, you are that guy... You should really spend your time on SuperTopo instead of Audizine; you will fit right in over there
  20. #220
    Mar 10 2015
    New England
    Quote Originally Posted by jsh139 View Post
    The kicker is that the manual also indicates how to operate the power-folding feature.
  21. #221
    Apr 14 2015
    United States
    any pictures of how to get the rear view mirror off to get to the power plug
  22. #222
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
  23. #223
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    Great; thanks for the tip!
  24. #224
    Feb 20 2006
    NC
    how do i activate the headlight washers?
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
  25. #225
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Lights have to be on.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
  26. #226
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by scottycs View Post
    I'm pretty sure they activate automatically when you use the windshield washer, but only if the headlights are on.
  27. #227
    Mar 21 2015
    That's the ticket. Don't do it after you wash your car or you'll be pissed.
  28. #228
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Yeah no worries here. No headlamp washers on my 2010. Although I had them on my B7 and they were a pita.
  29. #229
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Is the steering wheel off-center? Or am I?
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
  30. #230
    Senior Member Three Rings JMUNFORD's Avatar
    Sep 26 2012
    B9 S4, B5 S4, Grand Cherokee Trailhawk
    Tampa,Fl
    Can you keep the back up camera on while moving forward ?
  31. #231
    Aug 15 2015
    Cincinnati, Oh
    I'm thinking the same thing...I was going to bring it up when I took it in for my 35k service.
  32. #232
    Senior Member Three Rings Moto One's Avatar
    Mar 26 2010
    C5 Z06 (going on 17 years)
    Tahoe/Truckee
    Witch way is it to San Jose? (USA)
    Mark
  33. #233
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by Moto One View Post
    Mark
    It's thatta way!
    2021 Audi S4, P34 Intake
  34. #234
    Aug 12 2015
    Atlanta
    Anyway to turn the seat belt indicator off? I know I could in my Raptor.
  35. #235
    Mar 21 2015
    Quote Originally Posted by Southern4 View Post
    Carista
  36. #236
    Dec 03 2008
    2018 SQ5
    Only with vag com, but yes. You can disable chime and indicator.
  37. #237
    Dec 03 2008
    2018 SQ5
    Carista
    I Forget about that app...
  38. #238
    Mar 21 2015
    It is nice and convenient but it seems like the support has been lacking lately. Todor seems to be fading away. They were on it for a while and making great improvements.
  39. #239
    Veteran Member Four Rings IceFour's Avatar
    Jul 20 2013
    Union City, California
    Doh!
    Sent from my Nexus 6 using Tapatalk
  40. #240
    Dec 18 2009
    Toronto/ON, Canada
    I was referring to the oil level indicator in the MMI. Which shows the oil level at the half way mark.
    So I decided to top up the oil until the next oil change.
    Question I have is, when I opened the oil cap I do not see a straight opening to pour the oil into. Am I OK to pour the oil and it has some valve the oil flows through or when I open the oil filler cap should I see a straight opening ?
