Just picked up a 2006 B7 Avant. First automatic car in...umm...a decade, and it has a pretty retched vibration at idle/very low speed. Goes away in neutral. Figured it was motor mounts, so I switched those (snub/driver/passenger—all stock replacements) out today and there was only a slight improvement (passenger mount was definitely blown, driver's was on its way). When in park and physically looking at the engine, it definitely appears to be vibrating some. Should I look into the transmission mount or is there another typical culprit?
Other small issues that may be worth noting (ie, possibly a torque converter issue):
- When I shift the car into reverse, there is a tangible delay, maybe three seconds, before it pops into reverse...I'm tempted to even call it a clunk, but it's not quite there.
- The car also slightly jerks when I come to a full stop. It appears to be the car going from second to first gear, as when I put it into "S" mode and downshift myself, it doesn't act the same.
