Results 1 to 14 of 14
    Jul 03 2015
    Walnutport
    09 A4 won't start
    09 Audi A4 2.0t 96k miles
    Pulled into gas station to get some stuff when I came out I have a car that won't start. Towed it home. No symptoms leading up. Car will begin as usual when I push ignition Rpm goes to 200rpm and car cranks but never turns over. I just changed spark plugs, checked all fuses. I can hear fuel pump priming and smell gasoline out of exhaust. I looked at 100x threads and was hoping someone else had hands on insight.
    Thanks
    Josh
    Aug 07 2014
    2020 Q8 Prestige,2023 S5 Prem+
    Stanwood, Wa.
    Sounds like it's time for a new battery.
    Jul 03 2015
    Walnutport
    If I take it out and get it tested at AutoZone etc will that give me the information I need?
    Thanks for quick reply
    Jul 03 2015
    Walnutport
    Battery was not problem. Bought brand new battery and same thing
    Mar 26 2012
    Charlotte, NC
    ignition module?
    Do a full scan with VCDS
    Jun 26 2009
    Bremerton WA
    N80 valves can cause issues like this but usually they will start but run really rough. Its possible after topping off gas if the n80 is stuck open it creates an overly rich condition that may not start. in the photo if you can remove the hose just above the green connector and plug it with a screwdriver. That will seal off the intake from the gas fumes. You will get an evap error code from this. This picture is taken just behind the throttle body.
    Jul 03 2015
    Walnutport
    Changed crankshaft position sensor and that wasn't problem. Going to vagcom scan tonight hopefully someone can help with results
    Jun 26 2009
    Bremerton WA
    Any updates?
    VMR 710's, APR software, Eurocode HFC
    Jan 22 2014
    crewe cheshire
    Starter motor rock the car forwards and backwards in second gear then try to start it
    Jul 03 2015
    Walnutport
    Car was towed to Audi yesterday. They said a piston dropped and engine needs replaced. There's no other fix. I questioned them because they said it no longer cranks. They said there was a lose timing chain tensioner and from cranking so many times piston fell. Sounds like bs to me???? They said they're unable to turn motor forward manually and used bore scope. Any thoughts before this one bites the dust???
    Jul 03 2015
    Walnutport
    By the way my car went through all phases of oil consumption including the rebuild. During rebuild they also cracked my turbo. Any way this might have to do with the rebuild???
    Veteran Member Three Rings S-Liner's Avatar
    Oct 21 2014
    Illinois
    Quote Originally Posted by Jpitten View Post
    Nice
    Not long after having phase II consumption done last year, my car developed a no start condition. Battery was replaced, starter was changed. It seemed as if the problem was never going to be solved.
    After a couple days troubleshooting, they finally ended up replacing my main engine wiring harness. I suspect it may have been pinched during phase II, which lead to high resistance readings in an area of the harness.
    '10 A4 Avant Prestige Plus S-Line w/sport pkg
    My Oil consumption results..."Oil consumption measurement found to be using 3.26 quarts per 1000 miles"
    Jul 10 2009
    northeast
    my car was towed to the Audi dealership as well because it wont start. i had a "crankshaft position camshaft position correlation Bank 1 sensor A" error code and "cylinder 3 misfire detected" code. they want to charge me $1,300 just to take apart my engine to see why the car wont start. does this sound right? thanks
    Jun 26 2009
    Bremerton WA
    Look up P0016, that is the code for crank/camshaft correlation. You have likely lost timing chain tension and had the chain skip teeth. Very likely you have bent valves due to valve to piston contact. its very likely that after they open the block up a new head, timing chain, and tensioner. If you are in this deep and haven't had the pistons changed to the newer version it might as well be done too. I would have it towed to an independent mechanic and look for a lightly used long block from a 2012 or newer. The $20 to $50 an hour shop labor fee difference here can make a big difference when you are looking at 20 hours of work or more. If you are really lucky then only the timing has jumped and a new chain and tensioner can be fitted. Even this will run around $1000.
