I have been working on my a/c for several days now and no luck getting it to work. I still have the three fault codes posted below and I am hoping someone has seen this sequence before and can tell me what to do as I am sick of trial and air. The compressor was not getting power but I unplugged it and plugged back in then BOOM, the clutch engaged. I thought it was that so I then had y shop try to re-charge and after confirming no leaks, the re-charge stopped at .64 oz. Upon returning home, I re-scanned and still have the same three codes. I'm assuming I need to replace the high pressure sensor but even if it is faulty wouldn't it still take a full charge. We also re-filled through the low pressure so how would the sensor effect this in anyway. Any insight would be much appreciated!! Codes are below.
Address 08: Auto HVAC Labels: Redir Fail!
Control Module Part Number: 8T1 820 043 T HW: 8T1 820 043 T
Component and/or Version: KLIMA 1 ZONE H06 0150
Software Coding: 64002000
Work Shop Code: WSC 02391 823 56573
VCID: 4281773FDD7DA73138B-8017
3 Faults Found:
00256 - A/C Pressure/Temperature Sensor (G395)
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 66
Mileage: 115158 km
Time Indication: 0
Date: 2015.07.02
Time: 19:56:06
Freeze Frame:
Temperature: 42.0°C
Temperature: 91.0°C
Load: 0.0 %
Absolute Pres.: 0.4 bar
RPM: 0 /min
Speed: 0.0 km/h
Current: 0.000 A
Temperature: 39.0°C
00457 - Control Module for Network (J519)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 4
Reset counter: 106
Mileage: 115172 km
Time Indication: 0
Date: 2015.07.02
Time: 21:32:56
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 106
Mileage: 115172 km
Time Indication: 0
Date: 2015.07.02
Time: 21:32:56
Freeze Frame:
Temperature: 31.0°C
Thank you!!!
