Results 1 to 7 of 7
    Established Member Two Rings Venkalth's Avatar
    Jan 20 2019
    Volkswagen Caravelle 1991, 57kW; Audi A4 B5 1997 1,8T 110kW
    Estonia
    Stock battery specs/requirements
    Battery dead on my 97 A4 1,8T. Which is the stock battery specs i should go for. I am also willing to splurge for a battery a bit more powerful. Which one should i go for provided it fits? No fancy audio equipment or such on the car. Googling this issue brought up a bunch of battery sizes and in various different specs. Which one should i go for...
    Nov 13 2009
    Victoria, B.C., Canada
    Stock replacement size is an H6. Different cold cranking amps are available in this size. You just have to choose the brand you want. Most of the batteries in Canada are made by one or two manufacturers, just relabeled. There are also different styles of batteries in the same form factor; AGM (absorbent glass mat) vs your typical flooded battery. For my next battery, which is very soon, I’m going with an AGM. I’ll go with whatever brand is on sale at the time.
    Doug
    Jan 20 2019
    Estonia
    Okay, so i bought a brand new battery. It started right up but according to my multimeter it says that charging voltage is 13,5Volts. Is that normal for this car or is the battery getting under-charged? Alternator issue?
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Usually, the gauge sits right on the 14v mark. I would drive it and see if the issue corrects itself.
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
    Jan 20 2019
    Estonia
    13,7Volts according to my multimeter after a 40km drive. Is this normal?
    Sent from my VOG-L29 using Audizine mobile app
    Apr 26 2010
    North Jersey
    Quote Originally Posted by Venkalth View Post
    Sounds about right. I wouldn't worry about it.
    Jan 20 2019
    Estonia
    Yeah probably fine but since my battery died out of nowhere randomly with no previous issues or struggle of starting i figured it might have issues further. Now that i think about it, i had the lights and radio on. Put a load on the battery.... Thanks for the advice nonetheless.
