Page 1 of 7 123 ... LastLast
Results 1 to 40 of 280
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Some Guy's Mediocre S4 Build Thread
    Hey y'all
    So I've been on the boards for a while and I figured it was time for me to start a build thread. One year ago on this day, I brought home my 2004 Silver B6 S4. I'd spent almost a month searching for one that had been perfectly maintained, loved, and most importantly, had alcantara seats :). While I wasn't able to find one in Imola, my dream color, I did find one that suited me perfectly.
    Since then, I've done a decent amount to the car. First order of business was plasti-dipping the rear valence and all four front grilles because I couldn't stand how they all didn't match each other. Shortly after, I installed a FI nonres catback. After spending a few weeks with it, I decided that it didn't make quite enough noise so I decided to buy and install some XS-Power 2.5" downpipes with HFCs. I understand that they're a controversial company and many would not support them but for the price, they were the best option at the time and I'm still very happy with them. The sound is just perfectly refined and it really wakes people up when I get on it. Makes the car an absolute joy to drive around.
    I threw on a Cupra-r lip and an Apikol snub mount as a small weekend project and have since adjusted it a little more forward.
    The next big project was installing some used H&R coilovers I was able to buy. Since the install, I've loved them. The car handles very well and I haven't really noticed any sacrifice in ride quality.
    HUGE shoutout to my main man Josh (Evildsmer) for helping out whenever I need it. He's the Imola
    Car's been through a lot of weather and there hasn't been a moment when quattro hasn't impressed me
    However, the mod that has impressed me most is definitely my RD install. It's an Escort 8500xi. Every time I drive, it has never missed a cop and most of the time, I'm amazed at how quickly it works. I love it!
    Put some Klutch KM20 wheels on the car about a month ago.
    And last but not least, I got a JHM tune about a week and a half ago. Here's a picture of me flashing it in my garage. The flashing process itself was pretty difficult in terms of getting everything set up but Jake@JHM never hesitated to help me out and it got all taken care of. The tune's pretty much totally adapted now. I've noticed that the throttle response is amazing now and the launch assist definitely works, however, living at 5300ft of elevations doesn't exactly let me get the most out of this engine so it's not like it's a rocket ship or anything. I'm still very happy with it and I can't wait to see how it drives at a lower altitude with 93 octane.
    In the next couple weeks, I'll be doing timing and a myriad of other mods and maintinence. Here's a full list of the items I just ordered:
    • Crank Seal, Front or Crankshaft Seal
    • Crank Seal, Rear or Rear Main Seal
    • JHM Timing Chain Service Kit (JHM-OEM) for B6-B7 S4 - INTERMEDIATE
    • Oil Change Kit (JHM) Motul X-cess 8100 (5w40)
    • 034 Density Motor Mounts w/ Resistors
    • PCV
    • Fuel Injector O-rings x16
    • Fuel Injector Pintle Caps x8
    • JHM 6-Rib Kit
    • JHM Intake spacers
    • JHM Oil Cooler and Auxiliary Radiator Delete Kit
    • 034 MAF Hose
    • Valve Cover Gasket Kit
    • Valve Cover Bolts
    • Right Cam Chain Tensioner Gasket
    • Left Cam Chain Tensioner Gasket
    • Throttle Body Gasket
    • Oil Cooler O-ring
    • Oil Check Valve Service pieces
    • Power Steering Cooling Pipe to Reservoir hose
    • Power Steering Cooling Pipe to Steering Gear hose
    • 034 Trans Mount
    • Bosch 4-electrode (Platinum) Spark Plugs x8
    • Updated OEM COil Packs x8
    • Trans Fluid, PS FLuid, Coolant, etc.
    • Cabin Filter
    • Apikol Rear Diff Mount (Street)
    • 034 Density Line Adjustable Upper Control Arms
    • 034 Zero-gap Snub Mount Bracket
    • Driveshaft Flange Gaskets x2
    • Assorted Sealants
    • Evolution Imports Thor Skid Plate
    If anyone sees anything that's missing from that list, please definitely let me know about it! I'll update the thread as I go with those mods.
    Dec 07 2009
    East Coast
    Damn that's quite an overhaul
    Forget the B8, keep the V8!
    Sep 15 2013
    2017 S3
    Now for a follow-up post about the negatives I've been encountering with the car.
    First con is the usual chain rattle, I'm getting the timing kit so that should take care of it.
    Next has been my power steering. It's been leaking so I ordered both return lines in the hope that they'll take care of the issue.
    And thirdly, there's been an intermittent ABS issue. It only happens when the car's been warmed up for a while. It happens when I let the car idle stationarily for a while. Usually it happens at a red light.
    What happens is that the ABS and ESP lights will both turn on at once. The speedometer will stop working and will only read 0mph no matter how fast I go with the car. In addition, the steering becomes wayyy more sensitive and light and and I barely have to turn the wheel to control the car. Finally, the last symptom is that while I'm driving down the road in say 3rd gear, if I let of the accelerator, the car will buck as if all the brakes are engaging partially at once or as if the clutch is being released abruptly. It's all very strange and I hate it when it happens
    I decided to replace my wheel speed sensor in the front but the issue still came back afterwards. I bought an ABS module and the harness that connects the ABS module to the wheel speed sensor in the hopes that the two will fix my issue. I'll be installing them tomorrow so I'll update the thread if it works. Fingers crossed.
    Quote Originally Posted by Mr.Wrong View Post
    Thank you! I'm hoping that all this maintenance will help the car keep running smoothly for a long time
    May 20 2010
    Nice! Love the pics.
    After you install the ABS module, you need to go into VCDS and run some of the ABS tests to get the brake fluid to fill the circuits and bleed out the air.
    Sep 15 2013
    2017 S3
    Yep, I'm definitely aware but thanks for the reminder. I also have to recode the new module to match the car which seems like it's gonna be a bitch but I gotta do it I suppose
    Dec 02 2009
    M3
    Dubai
    Great project. I have a similar list of parts on my Imola S4.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Looking good dude!
    Sep 15 2013
    2017 S3
    Looking good dude!
    Thanks for all your help Jake!
    Aug 31 2011
    Lathrop
    Quote Originally Posted by pwest15 View Post
    No problem! Thanks for the order!
    Sep 15 2013
    2017 S3
    Quote Originally Posted by evildsmr View Post
    He's obviously never ridden in the back of his car! :D
    You know what... The back seats are for plebs anyway
    Jake, you're beautiful
    Veteran Member Four Rings evildsmr's Avatar
    Sep 13 2012
    04 Imola V8, '21 Army Green Taco
    Denver
    *Gargle Gargle*
    Aug 31 2011
    Lathrop
    Sep 13 2012
    Denver
    Aug 31 2011
    Lathrop
    I can't even right now.
    Sep 15 2013
    2017 S3
    I'm so just warming up!
    You need to calm down man. I'll bring you a cake tomorrow
    Don't worry Jake, I'll do a starbucks run and get you a frappucino
    Aug 31 2011
    Lathrop
    Java Chip would do wonders
    Sep 15 2013
    2017 S3
    You're such a white girl Jake
    Sep 13 2012
    Denver
    Oh Jake.....
    Dec 07 2009
    East Coast
    Sep 15 2013
    2017 S3
    On the real, has anyone ever seen this kind of ABS problem come up? Like ever?
    Nov 03 2008
    new jersey
    Looks good! I plan on purchasing the JHM tune very soon. Would you be willing to rent out your cable?
    Sep 15 2013
    2017 S3
    Quote Originally Posted by microracer24 View Post
    Ah man, if I owned one I totally would but I borrowed it from a friend of mine here in Denver. He does happen to be selling it on our local classifieds if you'd be interested in that though. http://www.audizine.com/forum/showth...h-Tuning-Cable
    Feb 12 2015
    Minnesota
    I have the same ABS Issue with my 04 S4, I have a known bad battery and terminal 30 faults, voltage related issues can set these lights off.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Veteran Member Four Rings jolio1994's Avatar
    Sep 06 2011
    Little Egg Harbor, NJ
    After about a mile of driving, my TC light will start flashing and cutting power to the car, after about a mile and a half, it stays constantly on and drives fine. I usually just turn it off as soon as I get in the car and it's not an issue. That's why you always see it off in any of my videos.
    As a second note, I'm selling the car later today so it's not on my to-do list. Subbed to this thread, because I've always been curious as to what caused it.
    Build looks good man! Love the direction this is going!
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    G85 yaw sensor problem?
    That caused similar problems with TC & ABS on my 8L S3.
    Sep 15 2013
    2017 S3
    Quote Originally Posted by PetrolDave View Post
    Yaw sensor is a curious thing to investigate. Could be it too. I'll be replacing the ABS module later today in hopes that it solves the issue but it's good to have other things to investigate if the issue persists. Thank you!
    Quote Originally Posted by Dpkhym2 View Post
    Hmm, could this be caused by the alternator as well? Replacing the battery later today anyway so we'll see but I don't think it stems from the overall power source
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Good start, looking forward to following your progress.
    Senior Member Two Rings Fritz_S4's Avatar
    Aug 06 2013
    Snowy heaven
    I have the same ABS/TC issue, says rear left speed sensor is giving implausible signals... also I can tell when it's about to start because the car shakes a bit as if the ABS is kicking in right before the light comes on. Will follow and see how far you go before solving this...
    In my case I doubt it's the module as I can communicate with it properly even when the lights are thrown. Also my speedo keeps working even when the lights come on. Mine are much more random than yours and will come on right when I start the car sometimes, as I'm driving other times, coming to a stop, idling, when it's raining, if a midget gets a boner, if its too cold out, if I get on it for a while, if I don't get on it for a while... so maybe it's not the same thing at all in the end
    Jan 14 2009
    Audi's
    Car's coming along nicely
    Sep 15 2013
    2017 S3
    Quote Originally Posted by ieatfishburitos View Post
    Thanks! Every tie you post, I get really hungry for my favorite fish burritos haha
    Quote Originally Posted by Fritz_S4 View Post
    You're hilarious. Yeah I'm hoping I can solve the issue with just the new module. I know the A6's had modules that would fail and cause a lot of issues so I'm hoping a new module will solve my issue.
    Quote Originally Posted by Mr. Corey View Post
    Thank you!
    So as much as I'd like to share yesterday's progress with y'all, there wasn't any haha. I kinda sorta got distracted with this:
    And this.........
    I will try and get around to it today though!
    Sep 13 2012
    Denver
    I'm so tired........ Ugh.......
    Sep 15 2013
    2017 S3
    So I wasn't able to get around to putting the ABS module in this weekend... oh well
    But I do have an update! I decided it was time for a new battery so I decided that I'd buy an Optima D51R lightweight battery and make my own relocation kit. IMHO JHM charges way too much for their kit so I went out and bought everything myself. I used some 1/0 cable to run the length of the car just to make sure there was plenty of insulation and that the cable could withstand the current. 1/0 is probably overkill but I wanted to be safe. I also bought a few terminals as well. Here are some pics.
    All-in-all, it wasn't a bad day-project. The hardest part was definitely threading that thick cable through the side trim and under the carpet to the front and snaking it out through the ECU box. It all went pretty smoothly and the car starts and runs as well as it ever has. I can't say I feel a difference or anything but I didn't expect to in the first place. I hope to be installing the ABS module some time this week if I see the ABS issue pop up again but who knows, the new battery might have solved it.
    Veteran Member Three Rings mark_ma's Avatar
    Feb 25 2015
    Denver/Colorado
    Looking good. hopefully here in the near future can see it in person
    Sep 15 2013
    2017 S3
    Quote Originally Posted by mark_ma View Post
    Yeah man, I'll try and be at the next few gtgs!
    Sep 15 2013
    2017 S3
    Oh boy you guys! It's like Christmas all over again! Look what Santa brought me!
    I ended up delaying the motor pull by a week. Hoping to start it this weekend. All I need now are JHM cam adjusters and the timing tools.
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    I love days like these. Looks like a nice spread of parts!
    How much does that battery weight? All I could find was 11kg, and wondering how accurate that is. I too cannot believe how much JHM sells the relocation kit for, everything else of theirs is spot on because of the R&D but the cables are cables, any DIYer can source the parts easily.
    Nice work so far by the way.
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Sep 15 2013
    2017 S3
    Quote Originally Posted by Gosser View Post
    Thanks! Yeah it took me like 50 minutes to unpack it all lol.
    As for the battery, It's around 25lbs, maybe a tad more. It's listed on Optima's site to be like 26.something lbs. I actually wrote up a DIY on another Audi site here where I did a cost breakdown with links on where to order stuff. It comes out to be a lot cheaper than the JHM kit so I'm really happy with how I did it
    I can't wait to get started on this big project. My engine should be running tip top afterwards
    Santa must love you. I've done something wrong apparently.
    I also did pay Santa a lot of money
    May 20 2010
    Sep 15 2013
    2017 S3
    On my lunch break right now but here's where I'm at. I removed the catback, front bumper and radiator support. I just finished disconnecting all the plumbing necessary to pull the engine (in the picture the a/c lines are still connected). I guess I'll try and unplug all the wiring this afternoon but the actual pulling of the engine and tranny will have to wait until tomorrow because all my friends are busy and no one can help me with it
    But I'm happy with my progress
    Sep 15 2013
    2017 S3
    Another quick update before tomorrow
