Page 7 of 7 FirstFirst ... 567
Results 241 to 253 of 253
  1. #241
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    Quote Originally Posted by Schrubbe8210 View Post
    I have an upgraded fuel rail, I think the -8 is too big, 034 and IE have both told me -6 and a surge tank is good for like 1000hp.
    No, the Infinity is Mafless, runs off of a 100psi MAP sensor into the Intake mani. VE style tuning.
    I swapped out the poly 034 end links, and really havent noticed a big difference. the poly on the old end links was getting beat up.
    I just picked up a 034 battery relocation kit, and am going to put the surge tank where the battery is now. Should make for some perfect placement.
    -6an is roughly 3/8" which is the size of the stock b5 s4 lines and you can't make 1000hp on stock fuel lines in an s4 sooo (silly to measure fuel line in hp but bare with me for simplicity).
    I'd go -8an and you won't have to worry about it at all.
    Placing a surge tank closest to your lift pump (in tank) is the usual way to do things, although i dont think it really matters.
    2000 Achat S4
  2. #242
    Veteran Member Three Rings Schrubbe8210's Avatar
    Jun 16 2012
    1997 B5 A4 track car, 2017 Q7 Prem Plus
    Elm Grove, WI
    I spoke to 034 and IE at length about it. I am going to relocate the batt, and run everything in -6, that way if i need to beef up the surge to rail line, itll be right there and easy. Doesn't sound like Ill be needing more than -6, but if its a problem, itll be easy to address.
  3. #243
    Jun 16 2012
    Elm Grove, WI
    Well, everything is going well. Successfully moved the battery to the trunk, 034's kit was great. Also installed the IE surge tank in the spot where the battery was, mounted the fuel filter to the false firewall next to the surge, ran a bunch of -6 lines, and everything is kosher. Got the infinity all set up, tested and running, and then towed it over to nth moto in Minneapolis for the final tuning. They are tuning it as we speak, and mechanically everything has checked out. Can't wait to get it back!
    Also got a CD7-L and VDM just cause it looks badass.
  4. #244
    Veteran Member Four Rings thedanplasse's Avatar
    Apr 05 2016
    RI
    How many feet did you have to order to run the lines from the tank to the fuel rail?
    "Better stick to your A4 forum, peasant."
    Santorin Avant Project
    Atlas Avant Daily
  5. #245
    Jun 16 2012
    Elm Grove, WI
    I ended up needing 2 20ft sections of vibrant hose. Probably would have boight a 50ft piece if i was thinking. Its probably like 16 feet from the tank to the rail.
  6. #246
    Apr 01 2011
    B5 on jack stands
    charlotte
    when do you plan on getting it dynode again?
    powered by
    Hot Boi parts
  7. #247
    Jun 16 2012
    Elm Grove, WI
    It is at Nth Moto as we speak, they are going to dial in the tuning on the dyno this week. Should have it dynoed soon.
  8. #248
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    updates? still racing?
    IG:@steadysupreme
    Pics&Detail
  9. #249
    Jun 16 2012
    Elm Grove, WI
    Yes. Been on the track a bunch since last year. just havent posted in here. Car runs well, got some PF01 wheels and new rubber, best lap times were 2:44 at RA and 1:25 at blackhawk farms.
    Had a little hiccup with the catch can, so I installed a drain back to the oil pan, and extended the tube on the top to help with condensation of the oil, problem has disappeared. I have a local guy helping tweak it, and now I run 100oct Sunoco GT260 and it runs really well on that. Going to dial in boost control a little bit, it doesnt hit its targets as well when its hot outside, and we should be good.
    All I need is a wavetrac in the rear and ill be set.
  10. #250
    Senior Member Two Rings AudiSportDre's Avatar
    Mar 14 2020
    B5 1.8T track car (soon to come)
    Worcester, MA
    Is this still alive? Any pictures of it on the new wheels?
    2018 B9 Audi A4 P+ S-Line Quattro Mythos Black
    Stance is dumb performance is fun.
  11. #251
    Jun 16 2012
    Elm Grove, WI
    Yes. Definitely alive. Pics are a bitch to get up cause of hosting. Havent tracked it this year with the COVID, but I am hoping to get out in june. I have a wavetrac all installed in the spare rear diff I have, and I also need to get the poly bushing in the front. Was actually going to tackle that today. Ill look into linking some pictures.
  12. #252
    Senior Member Three Rings zatta's Avatar
    Sep 02 2018
    Ohio
    Anywhere else I can follow your build? Looks awesome btw, planning on tracking/auto crossing my B5 once it’s running.
  13. #253
    Jun 16 2012
    Elm Grove, WI
    I haven't really done much with the build, outside of having the tune tweaked. Got out a few times last year, it was great. My brother has a 2014 S4 he takes with me now. I will get some pictures up soon. The car has been sitting on the lift chilling lately, lol. House projects.
