A Few Updates: After driving around for 5 days and watching the IAT's I am seeing about a 4°F drop when steady state driving. When I first start the engine and drive until everything is up to temperature the IAT's will typically be around 6°→8°F above the ambient temperature. Once I stop a few times in traffic and things start to heat soak a little the IAT's will climb to 14°→15°F above ambient and remain pretty steady. Previous to the minor airflow mods the IAT's would stabilize around 18°→19°F above ambient. I am getting the ambient temperature from the display and the IAT's using Torque Pro.
Today I did some data logging. According to the display the ambient was 89°F. I logged the IAT's using the Motoza data logger. Unfortunately I had a few issues with my Bluetooth adapter when switching between the Torque Pro and Motoza logger and consequently I was sitting at idle on the side of the road for at least 5 minutes trying to get everything to connect. This heat soaked the intercooler by about 10°F more than I typically see. I did a 2nd gear pull from 2500→6300 RPM followed immediately by a 3rd gear pull from 4400→5800 RPM. On to the results:
In 2nd gear the IAT started at 114°F. By mid pull the IAT dropped to 111°F. At 6300 the IAT had returned to 114°F. The TyrolSport intercooler essentially held the IAT's steady.
The 3rd gear pull obviously started at 114°F. The IAT's continued to climb through the pull and maxed out at 129°F at 5800 PM for a total gain 15°F.
The Good: A 15°F gain in IAT's through a 2nd and 3rd gear pull in 89°F ambient temperatures is way beyond the capability of an OEM intercooler.
The Bad: When you are sitting still the SMIC doesn't have any airflow and consequently is probably more susceptible to heat soak than a FMIC.
For comparison here is some info on an Apikol SMIC versus the OEM SMIC. The tests were performed with the APR 1+ tuning on a B6 1.8T. There is no information on the ambient temperature for the comparison but the OEM IAT's went from 130°F→190°F whereas the Apikol went from 97°→170°F.
Clicky click®
Bottom line: For my driving needs I am happy with the performance of the TyrolSport SMIC.
