Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 477
  1. #161
    Nov 03 2011
    All Over!
    Update: 24th July 2015.
    I got a call from the paint shop, whilst still at work, that my valve covers were ready. So it was a bit of a crazy rush to drive there during my lunch break, to pick them up.
    I'm pleased with the finish and colour match. These will be refitted tomorrow at some point. I am going to start on the aluminium components on the engine. I figured if I buffed them to a clean state, it won't be long before they go dull again. So I have opted to paint them in the original aluminium silver once they're cleaned.
    I was also lucky to stumble upon a set of front and rear brake rotors and pads. The rears are no good to me, being for a FWD A4, with bearings, ABS rings and pads. I'll sell them on.
    However, the fronts are a bit more interesting - the rotors are D2 A8 312mm items. I just need to purchase a set of Audi A6 C5 or TT 1st gen. front caliper carriers, then they're ready to bolt up to my B5. These are temporary, as I will be running B5 RS4 360mm front rotors, with Brembo 4/6 piston calipers.
    Some pictures:
    D2 A8 312mm front rotors, and OEM B5 V6 pads:
    1986 Type 85 Audi 90 quattro
  2. #162
    Veteran Member Four Rings boomtime's Avatar
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    Looks good they came out better than I expected
    The eventual supremacy of reason.
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
  3. #163
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    Looks fantastic nolly, keen to see them fitted to that beautiful 4.2
    I have this feeling Audi would get a kick out of seeing your pelican blue beast in such good nick with a 4.2 under the hood and not to mention colour matched valve covers!
    Sent from my Nexus 5 using Tapatalk
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
  4. #164
    Nov 03 2011
    All Over!
    Update: 26th July 2015.
    I have just installed my freshly-painted valve covers, cleaned and painted some of the aluminium. I have not bothered polishing the air con compressor, as I won't be using it. The D3 A8 aircon compressor is the variable displacement type, while the B5 A4 V6 is fixed displacement with a conventional magnetic clutch. So I will be installing the B5 compressor in the same location.
    The same goes for the D3 A8's combined oil cooler and filter housing. The D3 runs a paper oil filter element, while the C5 A6/S6 is a conventional metal spin-on canister, which I prefer. More importantly, the C5 V8 A6/S6 housing integrates the right hand side engine mounting bracket, so I'm going to use one of these.
    Some pictures:
  5. #165
    Nov 03 2011
    All Over!
    Colour matched pretty well, considering the car is 15-years-old:
  6. #166
    Nov 03 2011
    All Over!
    Update: 27th July 2015.
    Today, I discovered how different the 4.2 V8 from the D3 A8 Quattro (BFM) is more different than I thought.
    It IS an 077 series V8, on the surface, it appears to have more in common with the 079 series V8 in the B6 S4, obviously without the B6's garbage multiple chains. Similar intake plenum, fuel rail, coil packs, exhaust manifolds.
    But this is where the similarities end.
    The 4.2 V8 block from the D3 A8 is actually based upon the 4.2 V8 Biturbo from the C5 RS6. The RS6 V8 has a block which is unique to it's application. At least it did until the D3 cars were produced.
    The RS6 C5 V8 has a larger block, where it bolts to the transmission bell housing, to accommodate the much larger torque converter, which is shared with the W12 Audi A8 and Volkswagen Phaeton. I spent the day comparing the RS6 and D3 V8 motors, and the rear ends are the same. Down to the casting marks on the sides of the blocks, they came from the same cast. Same bell housing bolt patterns that need some fettling to mate them to an 01E.
    I will be posting pictures as I proceed, this will be of help to someone else here who is also looking to run a BFM V8 in his B5.
  7. #167
    Apr 23 2013
    mk1 gti, mk2 scirocco, b5 a4, c5 allroad
    fonthill
    The rs6 uses a pretty big spacer to bolt to an 01E. Are you going to have enough room up front for that?
  8. #168
    Nov 03 2011
    All Over!
    Quote Originally Posted by mk1 rabbit gti View Post
    I'll have enough room, but I won't be using the adapter. I'm going a different route.
  9. #169
    Apr 23 2013
    fonthill
    Oooo do tell
  10. #170
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    This car is going to be nuts. It also amazes me how many different 4.2 V8s Audi had made in the last 15 or so years.
    Sent from my iPhone 6 using Tapatalk
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
  11. #171
    Nov 03 2011
    All Over!
    Update: 04th August, 2015.
    I ordered an engine cradle, and it arrived today. My A8 4.2 V8 has been on my engine stand. Fine for working on just the motor, but it sucks if you wish to bolt the transmission to the engine.
    I need to bolt the engine and transmission together, to sort out some of the bolts. Remember, the BFM motor shares its basic block structure with the 4.2 Biturbo from the C5 RS6, meaning some work is required for 3 bolts that don't line up with the mounting holes in an 01E 6-speed manual.
    I also purchased a scissor transmission lift, and it was delivered today too.
    Engine cradle: you can actually use it as a test rig, if you wish to run the motor out of the chassis.
    Transmission scissor lift:
  12. #172
    Nov 03 2011
    All Over!
    As I have stated previously, I have extensive experience with the 32 and 40V 077 V8 engines, including swapping them into various VAG chassis. But this motor is different. The V8 from the D3 Audi A8 continues to reveal surprises, and other unexpected attributes.
    As many may know, the 4.2 V8 40V from the C5 S6 is very different from the 4.2 V8 40V from the C5 A6. The same differences exist between the same V8 engines from the D2 S8 and A8.
    Besides the obvious differences between the standard and S cars - bigger injectors, more aggressive camshafts in the S engines, the variable intakes were also different, 3-stage in the non-S engines, dual stage in the S engines.
    Now, with the D3 V8 engines, there was no S8. Pre-2005 (FSI) the V8 engines were split into two. 3.7 and 4.2 40V. At first, the differences between the 2 engines is their capacity. This is what I also assumed. However, the differences are greater.
    The D3 A8 3.7 runs a 3-stage variable intake manifold, in much the same way as the C5 A6 / D2 A8 4.2 did. The D3 A8 4.2 is different, and the variable intake plenum is the same dual-stage unit that was fitted to the C5 / D2 S engines. This effectively means the C5 / D2 S engine ECU's can be used for the D3 4.2 V8 40V, opening up more flexible tuning options.
    I'm going to check the camshaft specification between the C5 / D3 S engines, and the 4.2 V8 40V from the D3 A8.
  13. #173
    Jun 30 2008
    Erie, Pennsylvania
    This thread is just...I mean...Pelican valve covers? Plug-and-play D3 > B5 adapter harness? Panoramic roof mod? Srsly, am I dreaming? I can't even.
    Nollywood, you win 2 Audizines. (and you're not even done yet!) I cannot imagine what other ideas you will come up with. It seems like no dream is too big. You are an inspiration to me.
  14. #174
    Nov 03 2011
    All Over!
    ^^^Thanks, Walky.
    I am inspired by Audizine, and North American B5's. Lots of awesome cars here.
  15. #175
    Nov 03 2011
    All Over!
    Update: 10th August, 2015.
    So this weekend, the remains of my 2005 D3 4.2 Quattro Sport was picked up by the junk man, and for the first time since we acquired this property, I could actually see all the walls. Lots of storage space too.
    My D3 loaded up, on it's final journey. I was surprised these guys didn't get busted by the cops when they hit the road, so much over hang, made worse by the fact their truck was NOT built for picking up cars. As the front suspension was all gone, it was a battle wrestling the shell onto the back of their truck. Uber overhang!
    And my workspace:
    Assorted engine harnesses, ranging from 2000 B5 S4, 1998 D2 S8 and 2003 B6 S4:
  16. #176
    Nov 03 2011
    All Over!
    As some of you guys may remember, I mentioned the D3 A8 BFM V8 shares cylinder block dimensions with the C5 RS6. As in it's larger at the rear, where it bolts to the transmission. Many RS6 owners who have looked into converting their cars to 01E 6-speed have also had issues when it comes to a bolt-in solution.
    After examining the rear of my D2 S8 AHC motor (32V) and comparing it with my D3 A8 BFM (40V), bar the starter motor hoop, the BFM block is no larger. What the RS6, and D3 A8 engines have is an extra set of holes to mount to the much larger Tiptronic bell housing. These holes are on the outside of the ones that would usually accept an 01E. The 32V S8 motor also has these extra holes, though they are not used in an S8 with Tip.
    I am going to bolt my 01E to the BFM engine, using the 5 bolts holes that DO match, then drill and tap the extra holes.
    The BFM flexi plate, like the C5 RS6 is larger than the regular 30/40V items, so the starter motor will not work on an S4 B5 / 40V flywheel. I have ordered an S6 C5 starter motor. I am going to make a template from my 32V block, then drill / machine the starter motor area on my D3 4.2 V8.
    Starter motor should be here sometime this week.
    The three holes in the upper oil pan do not mate to the 01E either, so I am constructing an adapting bracket, not to be confused with an adapter plate that is commonly used for manual swaps in the C5 RS6, but also has the added disadvantage of pushing the big V8 further forward than I'd like.
    I will take pictures of the process.
  17. #177
    Apr 23 2013
    fonthill
    I didn't know there was material there to drill/tap new holes.
    Love to see some pics when your done
  18. #178
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    It's the type of thing you need to have both engines out of the car side by side to find this out.
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
  19. #179
    Nov 03 2011
    All Over!
    I spoke to a shop that has made me one-off Carbon Fibre parts in the past. I would like to get the front and rear top engine covers made out of the good stuff.
    Just waiting on pricing.
  20. #180
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Oh fuck those valve covers are nice.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
  21. #181
    Nov 03 2011
    All Over!
    Quote Originally Posted by King_ View Post
    Thanks man.
  22. #182
    Apr 23 2013
    fonthill
    http://www.relakhq.com/Engine-Covers-ECB6S4.htm
    S4 carbon covers if that helps
  23. #183
    Nov 03 2011
    All Over!
    Thanks man. I'm not really sure if these will fit. The rear cover looks similar to mine though.
  24. #184
    Nov 03 2011
    All Over!
    Update: 27th August, 2015.
    My apologies for my lack of regular updates, been super busy with work and even more exams.
    I placed an order for a single-mass steel flywheel. I could have saved myself a stack of dough, and used my original 2.8 30V flywheel, with an OEM 2.8 clutch, but I opted not to do so for a number of reasons.
    Being a dual-mass unit, the original flywheel is designed for smoothness and comfort, absorbing vibration. Unfortunately, this design is not built for high-torque application, and it can't be resurfaced - at least not by many shops. It is also insanely heavy for what it is. Worse of all, using the 2.8 30V flywheel will limit me to running a 2.4/2.8 30V clutch, which I would rather not do.
    The steel flywheel I have ordered is specific to the 4.2 V8 40V, and designed to run a B5 S4 / RS4 clutch. Unlike the B5 S4 / RS4 though, it does NOT require the S4's engine-to-transmission spacer to provide clearance between the clutch pressure plate and bell housing, being dome 11mm slimmer. This should be with me by Saturday.
    My D2 S8 ECU also arrived on the 24th August, I'll be sending it off to get the immobiliser defeated.
    I know the 2.8 V6 30V twin catalytic converters and combined downpipes are a direct bolt-on fitment to the 4.2 V8 40V motor. But they will strangle performance, due to their bore size and the surface area the catalysts provide. I'm contemplating purchasing a pair of stainless 200 cell race catalysts from Germany. I can then have the rest of the exhaust system built from the CATS rearwards.
    I'll post pictures soon.
  25. #185
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    Coming together nicely will you be using a street disc or race disc for the clutch?
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
  26. #186
    Active Member Two Rings roc-quattro's Avatar
    Apr 13 2015
    Rochester, NY
    This thread is insanely informative regarding the nuances of the b5 4.2 swap. The specifics of the numerous 4.2 v8 engines, both relative to one another and in context of the b5 platform, are hard/impossible to find unless someone has had the opportunity to stare at a few engines, transmissions, and harnesses. Thanks Nollywood for being a one-person R&D department for this kind of swap!
    Please keep the excellent write-ups and photos coming (particularly the details of the various bell housings and 01E interfacing).
  27. #187
    Veteran Member Four Rings bhusted's Avatar
    Sep 11 2011
    B5 A4 4.2L V8
    Kirkland, WA
    Does using the 01E without the spacer pose an issue with the drive shaft? 11mm isn't a lot, but I don't think that there is that much fore-aft movement in the CV joint at the transmission.
    | B5 4.2L V8 Quattro | Tein S-Tech | O.Z. Ultraleggera 18x8 | Stabila Course 22mm rear swaybar | Agency Power WRX swaybar links | S4 front brakes | A8 rear brakes | FX-R HID projector retrofit | Fog projector retrofit | RS4 Grill |Aero wipers |
  28. #188
    Nov 03 2011
    All Over!
    Quote Originally Posted by bhusted View Post
    No issues whatsoever. Losing the 11mm spacer only moves the engine rearwards, the transmission position remains the same.
    I've never used the spacer in any of my V8 into B5 swaps.
  29. #189
    Nov 03 2011
    All Over!
    Quote Originally Posted by roc-quattro View Post
    Thanks man.
  30. #190
    Nov 03 2011
    All Over!
    Quote Originally Posted by boomtime View Post
    Street clutch for this car. Non-paddle either, as they chew up flywheels real bad.
  31. #191
    Nov 03 2011
    All Over!
    Update: 29th August, 2015.
    I have been considering different exhaust options for B5 420-R. My original V6 30V exhaust system WILL bolt up to the V8 40V. But...it will be restrictive, as the bore size of 2.25" is undersized for a V engine above 3.0L. It will also not sound as good, a flat-sounding V8 is not cool!
    So I ended up purchasing a B5 S4 stainless 2.5" system with twin 3" tips. This is a CAT-back system, so I also purchased B6 S4 stainless steel downpipes. These are CAT-deletes, but I have the option of purchasing a pair of 200 CPSI sport CAT's to weld in, if I so choose. The downpipes are coming in from Germany.
    Some pictures. Note, these are the original advert pictures.
    B6 S4 stainless steel downpipes:
    B5 S4 stainless steel CAT-back system:
  32. #192
    Nov 03 2011
    All Over!
    I'm currently eying a pair of Magnaflow 59956 metallic 200 CPSI sport catalysts.
  33. #193
    Senior Member Three Rings JJ.'s Avatar
    May 22 2012
    Netherlands
    I love your builds :D Amazing work man!!
    I also have a small question haha, is the gaugeplate of an a4 b5 the same colour as the rs4 b5?
    You have both right, would you mind comparing them?
    Instagram: jj_dw
  34. #194
    Nov 03 2011
    All Over!
    Quote Originally Posted by JJ. View Post
    Thanks man!
    Are you referring to the instrument cluster dials?
  35. #195
    May 22 2012
    Netherlands
    Thanks man!
    Yes I am :)
    Instagram: jj_dw
  36. #196
    Registered User Four Rings UroTuning's Avatar
    Aug 23 2007
    Tampa Bay, FL
    I love the color of the car!! Nice choice. Can't wait to see this thing up and running!
  37. #197
    Nov 03 2011
    All Over!
    Yes I am :)
    I'm not 100% sure. The RS4 cluster dials look kind of darker, and I believe they are. I don't have a set for a B5 RS4. I've got clusters for facelift B5, facelift B5 S4 and a C5 RS6, and they're all different shades, with the S4 being the lightest (grey).
  38. #198
    Nov 03 2011
    All Over!
    Quote Originally Posted by Stefn@UroTuning View Post
    Cheers mate!
  39. #199
    Nov 03 2011
    All Over!
    Update: 03rd September, 2015.
    So my exhaust system turned up today.
    Quite a well-made system. As I mentioned previously, the downpipes are for the B6/7 S4. Trying to test fit one to my BFM manifold highlighted another difference.
    The BFM manifolds have the studs slightly wider apart. This could be resolved by slotting the holes on the B6 S4 downpipe collars, but there was a more obvious difference.
    The D3 4.2 V8 manifolds have conventional stainless steel laminate gaskets. The B6 S4 manifolds have integral domed fire rings, and of course the downpipes have flared ends to match. It will be easy enough to weld in a pair 2.8 30V downpipe ends to the B6 pipes, but I can't really be bothered to do this, when an easier solution lies within reach.
    Buy a pair of B6/7 exhaust manifolds. Which is what I'm doing. I did consider pulling the trigger on a set of tubular headers, but I don't want to run into fitment issues on a street car. I might go the tubular route though on my DTM car.
    Pictures!
  40. #200
    Nov 03 2011
    All Over!
    I've just pulled the trigger on a pair of B6 S4 exhaust manifolds. They should be winging their way down to me pretty soon.
