Page 5 of 5 FirstFirst ... 345
Results 161 to 181 of 181
  1. #161
    Sep 09 2010
    2010 Audi A4 P+, 2016 GMC Sierra SLT & 2016 Jeep Trailhawk (GF's car)
    Panama City, FL
    Quote Originally Posted by Marko S View Post
    So i took a look at the coding and changed it re infiltrators suggestions but that removed the sound completely and greyed out the volume control with a "not available" message so i went back to the original coding. Right now my issue is that i only have sound from the right speakers when listening to bt and radio cuts in and out every 2 seconds. Im thinking it could be a wiring issue (i dont think i crimped the wires correctly). Might try to get a new connector and pins and redo that.
    Also my memory seats stopped working.
    Suggestions?
    Sent from my SM-G925W8 using Tapatalk
    Hmmm, did you do 3G or 3G+? In the other retrofit threads people with 3G+ the coding I told you didn't work for them butbthere was a different fix for that system. Sorry man, hope you get it worked out.
    STaSIS | Eibach | Koni | VMR | Continental | APR | H&R | Eurocode | Snow Performance | 034 | ECSTuning | Akebono | Posi-Quiet | Stoptech | Brembo | Apikol | CTS | Podi | GFB DV+ | S-Tronic Knob | FBSW | 3G MMI Retro | Color DIS Retro | Color Climate Control Retro | S-Line Conversion
  2. #162
    Senior Member Four Rings Marko S's Avatar
    Mar 03 2015
    Just wanted to update this thread. I had the wrong CANbus gateway. Swapped it out for the correct one and eveything works, no coding needed!
    2011 Audi A4 Prem+
    HPA - ECS Tuning - aFe - Eurocode - Treadstone - GFB - Milltek - PTP - DEI - Spulen - KW - Moog - Ultra Racing - CR-15 - 034 Motorsports - Brembo - EBC - Podi - Fly Designs - Audio Frog - Dynamat - Kicker - deAuto - OEM
  3. #163
    May 11 2016
    CA
    Quote Originally Posted by The Infiltrator View Post
    Hi Infiltrator,
    Thanks for all details on MMI 3G retrofit. I am having issues ie MMI buttons and screen arent turning on and had to give car to the dealer. They removed all errors, CP from gateway and coded it but found issue with radio wiring and CAN data wire brown blue wire that goes in D11 has 12V current and blocking signal from MMI unit. Audi technician suspect its from my old Bluetooth module and suggest removing old BT unit. All modules have power. Any idea on errors or whats wrong?
    VCDS logs before I gave car to dealer are here.
    Optical bus test:
    Code:
    Sunday,19,November,2017,12:13:00:33734
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 17.8.0.1 (x64)
    Data version: 20170721 DS276.2
    www.Ross-Tech.com
    Dealer/Shop Name: SelfAudi
    Control Module Part Number: 8R0 907 468 H
      Component and/or Version: GW-BEM 4CAN-M H11 0051
    Optical Bus Diagnostic : Standard
    Controller          	Electrical          	Optical
    19-CAN Gateway      	OK                  	ERROR
    5F-Information Electr.	ERROR               	ERROR
    0E-Media Player 1   	ERROR               	ERROR
    77-Telephone        	ERROR               	ERROR
    47-Sound System     	ERROR               	ERROR
    56-Radio            	ERROR               	ERROR
    37-Navigation       	ERROR               	ERROR
    0F-Digital Radio    	ERROR               	ERROR
    Code:
    Friday,24,November,2017,18:29:29:33734
    www.Ross-Tech.com
    VIN: WA1LFAFP2CA096745   License Plate:
    Mileage: 103890km-64554mi   Repair Order:
    Chassis Type: FP-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 22 36 37 3E 42 46 47 52 53
              55 56 5F 62 6D 72 77
    VIN: WA1LFAFP2CA096745   Mileage: 103890km-64554miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    20-High Beam Assist. -- Status: Cannot be reached 1100
    22-AWD -- Status: Cannot be reached 1100
    36-Seat Mem. Drvr -- Status: Malfunction 0010
    37-Navigation -- Status: Cannot be reached 1100
    3E-Media Player 4 -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: Not registered 0001
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Cannot be reached 1100
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Not registered 0001
    56-Radio -- Status: Cannot be reached 1100
    5F-Information Electr. -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Cannot be reached 1100
    Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8R0 907 115 P    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H20 0003
       Revision: E1H20---
       Coding: 0121010A290F0160
       Shop #: WSC 22155 444 131269
       ASAM Dataset: EV_ECM20TFS0118R0907115P 001004
       ROD: EV_ECM20TFS0118R0907115P.rod
       VCID: 418905D7D00A0C4EC5-8014
    No fault code found.
    Readiness: 1110 0101
    Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
       Part No SW: 8R0 927 158 T    HW: 0BK 927 156 AJ
       Component: 0BK 20TFSIUSA H16 1010
       Revision: --H16---
       Coding: 000002
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMAL551211 002020
       ROD: EV_TCMAL551211_002_AU48.rod
       VCID: 4E932EEB1154E33648-801A
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
       Component: ESP8 quattro  H06 0110
       Revision: --------    Serial number: --------------
       Coding: 121D18
       Shop #: WSC 06334 000 00000
       VCID: 458111C7CC22206EF9-8010
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 FP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H10 0602
       Revision: 00002001
       Coding: 0D854000000000000000
       Shop #: WSC 06335 000 00000
       VCID: 0305CFDF8296DE5E97-8056
       Subsystem 1 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Component: J764 ELV MLB  H40 0046
       Serial number: 2312000027470002
    1 Fault Found:
    02095 - Component Protection Active
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:24:00
    Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-3Z.clb
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01060320120161
       Coding: 64012000
       VCID: 000FC0D39380C5468A-8054
    1 Fault Found:
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:13:57
    Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
       Part No SW: 8K0 907 063 CE    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0410
       Revision: 10030001    Serial number: 00000001430823
       Coding: 260018B1053CAF010000080300001D0D0F1C460802010161000000
       VCID: 74E79C03D738E9E69E-8020
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 120222  H11 0050
       Serial number: 90243014120218201533
       Coding: 01DD13
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 20088584
       Coding: 024D25
       Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002702121181
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
    2 Faults Found:
    01500 - Bulb for Fog-Lamps; Right (L23)
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 124
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:32:00
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:14:00
    Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
       Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
       Component: AirbagVW-AU10 H45 0610
       Serial number: 003GPD907YXB
       Coding: 303633313432303030304A55304C38523053
       ASAM Dataset: EV_AirbaAU10SMEAU416 002004
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 479D1BCFFE2E327E0B-8012
       Seat occupied recognition:
       Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
       Component: BF-Gewichtss.  H02 0040
       Serial number: 5810000R1200007RW2
       Crash sensor for side airbag: driver side:
       Serial number: 6334MSME6B613842E
       Crash sensor for side airbag: front passenger side:
       Serial number: 6344MSME6C734953N
       Crash sensor for side airbag: rear: driver side:
       Serial number: 6352QSME051144664
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 6362QSME5B0D336EX
       Crash sensor for front airbag: driver side:
       Serial number: 63732SME1611347CY
       Crash sensor for front airbag: front passenger side:
       Serial number: 63832SME14111E72V
    1 Fault Found:
    13697280 - Component Protection
              U1101 00 [137] - Active
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 103892 km
                        Date: 2011.08.23
                        Time: 00:09:55
    Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
       Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372LC1001HX
       Coding: 000017
       VCID: 3D717927A4F268AEA1-8068
       Component: E221 - MFL  H03 0004
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 950 K    HW: 8R0 920 950 K
       Component: KOMBIINSTR.   H12 0261
       Revision: 00100000    Serial number: N37228X2D
       Coding: 8B1F22000300D705020000
       VCID: 3E737E2BA9F473B6B8-806A
    2 Faults Found:
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:09:55
                008 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:09:55
    Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0117
       Revision: EC000056    Serial number: 5600E10A0300BF
       Coding: 00C303
       Shop #: WSC 02391 823 56573
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790207572
    5 Faults Found:
    01324 - Control Module for All Wheel Drive (J492)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:24:36
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 13.60 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
    00461 - Control Module for Seat Memory; Passenger (J521)
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:24:40
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 13.60 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
    01044 - Control Module Incorrectly Coded
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:24:40
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 13.60 V
                        Count: 6
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:26:11
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 13.90 V
                        Count: 6
                        Text: EFB3742E00B30500
                            297420
                        Raw, Form. N/A: 000 179 005
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:26:13
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 13.90 V
                        Count: 6
                            297420
    Address 20: High Beam Assist.
    Cannot be reached
    Address 22: AWD
    Cannot be reached
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0076
       Revision: AA000000    Serial number: 00000024113305
       Coding: 00581B00000000000000
       VCID: 428B0ADBDD0C1756DC-8016
    1 Fault Found:
                000 -  -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:13:40
    Address 37: Navigation
    Cannot be reached
    Address 3E: Media Player 4
    Cannot be reached
    Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
       Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000025118450
       Coding: 011D13205E00440004
       VCID: 4D9129E71452D82E31-8018
    Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0171800429
       Coding: 01260E3A20FA749587B0053200000000
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J245EE20SKB13  H03 0220
       Serial number: 0123456789ABCDEFGHIJ
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J394EE20SKB13  H03 0220
    1 Fault Found:
    03219 - Access and Start Authorization
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:24:00
    Address 47: Sound System
    Cannot be reached
    Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
       Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000025787600
       VCID: 4C9724E3EF48D12626-8018
    Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
       Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
       Component: EPB Audi B8   H09 0100
       Revision: 00000003    Serial number: 10000000897119
       VCID: 34675C0397B8A9E65E-8060
    1 Fault Found:
    01321 - Control Module for Airbags (J234)
                013 - Check DTC Memory - MIL ON
                 Freeze Frame:
                        Fault Status: 11101101
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:15:20
                 Freeze Frame:
                        Voltage: 12.10 V
                        Count: 80
                        Speed: 0.0 km/h
                        Hex Value: 0x0273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    Address 55: Headlight Range
    Cannot be reached
    Address 56: Radio
    Cannot be reached
    Address 5F: Information Electr.
    Cannot be reached
    Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
       Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
       Component: TSG HL        H01 0506
       Revision:             Serial number: 0000025708906
       Coding: 010C13204000240004
       VCID: 43850FDFC2161E5ED7-8016
    Address 6D: Trunk Elect. (J605)       Labels: Redir Fail!
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Component: J605  Master  H52 0330
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B75773FBAE6669E9F-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Component: J756  Slave  H52 0330
       Serial number: 8R0827852B
    Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-795.clb
       Component: TSG HR        H01 0506
       Revision:             Serial number: 0000025708902
    Address 77: Telephone
    Cannot be reached
    End-------------------------(Elapsed Time: 04:12)--------------------------
  4. #164
    Sep 09 2010
    Panama City, FL
    Quote Originally Posted by andybq5 View Post
    Hi Infiltrator,
    Optical bus test:
    Code:
    www.Ross-Tech.com
    Code:
    www.Ross-Tech.com
       Revision: E1H20---
       Revision: --H16---
       Coding: 000002
       Coding: 121D18
       Revision: 00002001
    1 Fault Found:
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:24:00
       Coding: 64012000
    1 Fault Found:
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:13:57
       Coding: 01DD13
       Coding: 024D25
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 124
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:32:00
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:14:00
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 103892 km
                        Date: 2011.08.23
                        Time: 00:09:55
       Coding: 000017
    2 Faults Found:
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:09:55
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:09:55
       Coding: 00C303
    5 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:24:36
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 13.60 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:24:40
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 13.60 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:24:40
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 13.60 V
                        Count: 6
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:26:11
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 13.90 V
                        Count: 6
                            297420
                000 -  -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:26:13
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 13.90 V
                        Count: 6
                            297420
    Cannot be reached
    Address 22: AWD
    Cannot be reached
    1 Fault Found:
                000 -  -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:13:40
    Cannot be reached
    Cannot be reached
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:24:00
    Cannot be reached
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 123
                        Mileage: 103892 km
                        Time Indication: 0
                        Date: 2011.08.23
                        Time: 00:15:20
                 Freeze Frame:
                        Voltage: 12.10 V
                        Count: 80
                        Speed: 0.0 km/h
                        Hex Value: 0x0273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    Cannot be reached
    Address 56: Radio
    Cannot be reached
    Cannot be reached
    Cannot be reached
    So you pinned the wire wrong and it's still having issues? If you did a 3G swap you no longer have your old Bluetooth in the car or installed.
    And you're sure you have the correct CAN?
  5. #165
    May 11 2016
    CA
    Did you mean CAN gateway? Its a 3G+ swap and yes old bluetooth was conflicting with CAN wire and disconnected. Audi tech fixed Amp radio wiring, removed all error coded, CP from gateway but still no luck. He tried reprogramming both CAN gateways 8R0 907 468 H and 8R0 907 468 AD but display and button panel aren't powering up. What else can be wrong wrong?
  6. #166
    May 11 2016
    CA
    Great to hear all worked well.. Which gateway worked for you?
  7. #167
    Mar 03 2015
    The newest revision.
    Sent from my SM-N950W using Tapatalk
    2011 Audi A4 Prem+
  8. #168
    May 11 2016
    CA
    Can you please provide Part-number,software ID or pic of gateway? I
  9. #169
    Mar 03 2015
    http://www.audizine.com/forum/showthread.php?p=12468462
    2011 Audi A4 Prem+
  10. #170
    May 11 2016
    CA
    Thanks!! I tried with 8R0907468H and 8T0967368AE but it didnít work. So you are suggesting to use 8R0907468L? Did it require you to get component protection and reprogramming via dealer again? Which display screen part number did you use?
  11. #171
    May 11 2016
    CA
    Also how get traffic data feed? Is it possible only via active Sirius subscription ?
  12. #172
    Mar 03 2015
    I think I used the P revision for b8.5 but my kit was from a b8.5 even though I drive a b8. The important thing is if you need the extended CAN or not. I haven't tried the data feed but I believe there is an antenna in the d pillar that needs to be connected for it to work; there is a thread outlining this. I may try to pop in a SIM card to see if it works been too lazy.
    2011 Audi A4 Prem+
  13. #173
    May 11 2016
    CA
    Ok how do I know if my mmi 3g plus unit needs can extended gateway? My radio unit is from 2016 but fm radio stations are not programming and stuck on first station :( . Vagcom reports 03175 error
    Also I added siriusxm traffic subscription for 3.99 monthly and can see traffic feed!! :)
  14. #174
    Mar 03 2015
    Extended can is for memory seats, blind spot assist (and some other things can't remember specifics). When I had the wrong CG my memory seats didn't work and my radio would cut in and out.
    2011 Audi A4 Prem+
  15. #175
    May 11 2016
    CA
    No donít have blind spot alert or memory seats, would you suggest anything else to check on why my 3g plus mmi unit wonít talk to 8R0907468H Gateway ? Mmi unit 5F shows installed in gateway and active in vcds.
  16. #176
    May 11 2016
    CA
    Markos
    Today I tried a new 3GP 5F unit and button panel and all started up fine. So it was a faulty 5F unit that was messing everything up. Now I will try a tmo SIM card and get the google earth.
    Thank you for your help and tips!!
  17. #177
    Established Member Two Rings Carbonfiber2gsx's Avatar
    Aug 15 2016
    1999 Mitsubishi eclipse GSX
    Saint Joseph MO
    i have an issue with my swap and cant seem to figure it out the screen and buttons and radio all power off randomly and wont turn back on until i shut off the car and turn back on and also navigation just initializes as well as media same thing radio work and telephone works but nothing else
  18. #178
    Aug 15 2016
    Saint Joseph MO
    Any help bump
  19. #179
    Mar 03 2015
    Have you checked the CAN. Most of these issues come down to the CAN or wiring that isn't secured.
    2011 Audi A4 Prem+
  20. #180
    Aug 15 2016
    Saint Joseph MO
    yeah i swapped can out with another compatible one but not extended and had exact same issues so i went ahead and ordered the ae can and will await new results but im still wondering why its shutting off randomly i dont think thats the can however i did do a retrofit camera setup in front and back and i remember when i did logs it said couldnt reach trunk module but both cameras work just fine i dint do any coding for it to work either though
  21. #181
    Aug 15 2016
    Saint Joseph MO
    update replaced every single piece of mmi setup with brand new ones and come to find out it was a bad mmi so i now i have car in safe mode again waiting to go to dealer for cp removal and also need to do some coding it looks like cause i have no sound is all i have to do is change the 8th digit in the long coding to 1 if coming from bang and oluf?
