Page 26 of 28 FirstFirst ... 162425262728 LastLast
Results 1,001 to 1,040 of 1108
  1. #1001
    Veteran Member Four Rings impulse's Avatar
    Mar 06 2014
    2006 B7 A4 - 2.7t Swapped. 2008 8P A3 - 3.2L VR6
    Connecticut
    And now my thread is FINALLY up to date after those massive photos dumps.
    So basically, I raced my girlfriends full bolt on stage 2 S3 and she pulled on me. I also thought that my turbos were blown because my car was smoking pretty bad, and I heard the infamous dentist drill. On top of that, my motor was leaking a decent amount of oil, probably from things i did last winter. So, I pulled the motor again to replace the turbos, and upgrade some more things. When I pulled the K04, I determined they were not the problem at all, as there was no irregularities with them and no oil in the turbine housings.
    I am upgrading to RS6 turbos with mamba wastegates, 1000cc injectors, walbro 450 fuel pump, air/fuel gauge, retune by Blake @ ET Spec and will finally get rid of the flashing “close gas cap” error!, 3 inch downpipes (currently exhaust is 3 inch down to 2.5 and then steps back up to 2.75 at my cat back), ecs lightweight power steering and alternator pulleys, rs4 throttle body, big belly intake manifold ported for 2.8 heads which I just bought a supertech valvetrain kit for.
    That being said about the 2.8 heads, they won’t be going on the car until next winter, when I also do a bottom end build. A friend came over and helped out with a leak down test. My front driver side cylinder had 70% leak down and he said he thinks it’s bad piston rings. Great. So, why swap 2.8 heads onto my current long block? I know I will lose some functionality of the intake manifold porting but it will be good for the long term. I figure if I can get it on now with the larger throttle body, I might as well get some use out of it. I also don’t want to rush a motor build this winter, and go broke trying to do so. Instead, this year I’ll focus on acquiring parts in order to build a block on the side, then pull the motor and swap it out
    Joe
    @jg_iii_
    Check out my progression thread - http://www.audizine.com/forum/showth...Picture-Heavy)
  2. #1002
    May 09 2012
    Virginia
    So why do you think you were down on power? No way that S3 should be pulling on you. What RS6 turbos are you going with?
  3. #1003
    Mar 06 2014
    Connecticut
    Quote Originally Posted by jbain2 View Post
    I don’t know, I mean it was a very close pull. I’ll text you the video. Could’ve just been the transmission, I was no lift shifting but my car really didn’t like that lol
    Joe
    @jg_iii_
  4. #1004
    Established Member Two Rings bhyrman's Avatar
    Sep 26 2014
    Vancouver, BC Canada
    Well Joe, I finally caught up with your thread again - I feel exhausted just reading about all the work you've been doing
    I didn't know you have to pull the engine to install the gauges by the steering wheel
    Now seriously, once again, the car looks amazing, the deep dish rims and the fitment, the body work turned out really great and the interior looks just amazing !!!
    And congrats to your Euro Summit Best Interior and Top 25. !!!
    Bronco
    2006 A3 2.0T FWD 6spd, Dakar Beige
    ST Coilovers // Eurodyne Stage 1 // Magnaflow Sport Catback + downpipe // EuroLED tail lights // RS grille
  5. #1005
    Mar 06 2014
    Connecticut
    Quote Originally Posted by bhyrman View Post
    Haha I’m always busy with this car being a slave, im excited for it all to come together. I need to add more photos, I’ve since put the car back together and drove it around, need to get the rest of my parts and get a re tune
    Joe
    @jg_iii_
  6. #1006
    Mar 06 2014
    Connecticut
    Acquired a full supertech valvetrain kit for my 2.8 heads that will be a part of a motor build I’m doing next winter
    Some random photos from a meet in the fall
    Installed some ECS lightweight power steering and alternator pulleys
    Joe
    @jg_iii_
  7. #1007
    Mar 06 2014
    Connecticut
    While I was out in Colorado in December my Brand new BW C5 RS6 turbos showed up to the house and my dad sent them out to Project B5 to be converted for a 2.7T with the added mamba wastegates. Super happy with the work, they installed fairly straightforward, although I had to shave one of the turbo housings down to get a banjo bolt in.
    Also my buddy Carlton aka 27Swap who makes the absolute best 2.7 swap wiring boards came over and re wired my car, now I no longer have the janky swap harness that my car used to have, and I’m praying I have AC this year since all the components are brand new.
    I also installed a Walbro 450 in tank fuel pump, and paired with the 1000 cc injectors I’ll be e85 capable. I will probably do a tune for that next winter
    Joe
    @jg_iii_
  8. #1008
    Mar 06 2014
    Connecticut
    Got a new transmission since mine was shifting kinda shitty, was only $200 so I figured “while I’m in there” like I do with everything else
    Sent the motor home, was fairly easy since I’m a pro at this point
    Joe
    @jg_iii_
  9. #1009
    Mar 06 2014
    Connecticut
    Got the parts in to fab my new downpipes, had 3 inch off the turbo which necked down to 2.5, and then I have the 2.75 cat back so I figured it was time to take out the bottleneck and get proper 3 inch downpipes
    Buttoned up the interior, love how the dual gauges look! Got the core support on, and swapped on my rotors from my A3 since I had to send one of the rotiforms back for a warranty refinish from the powder clear blemish
    Joe
    @jg_iii_
  10. #1010
    Mar 06 2014
    Connecticut
    Pinned my hood with the help of my good friend Yobe, was super necessary with the Carbon hood since my hood would basically be lifting open on the highway. Wasn’t thrilled that I needed them but I honestly don’t hate the look, and we did a really good and clean job with the install
    Joe
    @jg_iii_
  11. #1011
    Mar 06 2014
    Connecticut
    New downpipes on and the car sounds SO MUCH BETTER! I’m very excited with it and can’t wait to let it scream all year long after the re tune
    Joe
    @jg_iii_
  12. #1012
    Mar 06 2014
    Connecticut
    Closed on a house on March 5 that had a detached barn that came with the lift already installed! The drum set and other stuff was the previous owners that wasn’t out when i took the photo. Super stoked about my new workspace for my annual motor pulls, and to allow me the opportunity to part cars out too. I picked up another b7 parts car back in January and have stored it at my moms place. Bringing it to my new house on Wednesday!
    Joe
    @jg_iii_
  13. #1013
    Mar 06 2014
    Connecticut
    Dropped my car back off to my friend Slav for some paint work. Getting the hood fade redone, the rear quarters needed some work done since they bubbled up, and having some random things painted gloss black
    Joe
    @jg_iii_
  14. #1014
    Mar 06 2014
    Connecticut
    Some work on the rear quarters
    Joe
    @jg_iii_
  15. #1015
    May 09 2012
    Virginia
    Nice work! The S6 and S8 in the pics would be a welcome addition to anyone’s stable!
  16. #1016
    Mar 06 2014
    Connecticut
    Those are my friends 2 cars who’s doing the work on my a4 body
    Joe
    @jg_iii_
  17. #1017
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    Your car is just absolutely amazing. It's everything I wish I could do to my car, motor and body wise
    Sent from my SM-G996U1 using Tapatalk
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
  18. #1018
    Mar 06 2014
    Connecticut
    Quote Originally Posted by seal66 View Post
    Thanks! Much appreciated. Lots of time, money and effort went into this pig
    Joe
    @jg_iii_
  19. #1019
    Sep 26 2014
    ... and don't forget you have to pull the engine at least once a year !!
    Bronco
  20. #1020
    Mar 06 2014
    Connecticut
    I have another pull on the calendar for this winter, but I’m putting in a built motor, not putting the same one back in
    Joe
    @jg_iii_
  21. #1021
    Sep 26 2014
    Quote Originally Posted by impulse View Post
    Even more impressive !!
    Bronco
  22. #1022
    Mar 06 2014
    Connecticut
    Been a while, gonna kill myself trying to update with 4 months worth of stuff
    Hood fade all redone and much more visible, looking back I wish I did it even bigger
    Joe
    @jg_iii_
  23. #1023
    Mar 06 2014
    Connecticut
    Quarter panels with fresh paint after the rs4 conversion bubbled
    Joe
    @jg_iii_
  24. #1024
    Mar 06 2014
    Connecticut
    More paint work - had the rain tray, battery cover, grille, wiper arms, hood pins and Ecu box cover all painted gloss black, love the pop it gave them!
    Joe
    @jg_iii_
  25. #1025
    Mar 06 2014
    Connecticut
    Got the A4 all settled in at the new house!
    Joe
    @jg_iii_
  26. #1026
    Mar 06 2014
    Connecticut
    A set of photos from a local photographer - Bryan @shotsbynguyen
    Joe
    @jg_iii_
  27. #1027
    Mar 06 2014
    Connecticut
    Got my new big belly and ported intake manifold on from project B5 along with the rs4 throttle body adapter, with my new polished rs4 throttle body, as well as 034 fuel rails that I ultimately broke a few fittings off of and now they’re just sitting in a box… oops. I’ll get them on this winter
    Joe
    @jg_iii_
  28. #1028
    Mar 06 2014
    Connecticut
    Some random photos
    - wheels for wheels car show, won best interior
    - a photo with my R32 that I traded straight up for my A3 in April
    - audi dealer service shot - FINALLY got my damn ac to work after 4 years of not having it!!!!
    Joe
    @jg_iii_
  29. #1029
    Mar 06 2014
    Connecticut
    More random shots
    - got the car PPF’d from fenders forward and a full paint correction as well as ceramic coating. Was expensive, but I have to say it was 200% money well spent!
    Joe
    @jg_iii_
  30. #1030
    Mar 06 2014
    Connecticut
    Cruise from Connecticut to Virginia, sleep, then blue ridge parkway for 250 miles! What an awesome trip - we went down for alpine volks fair in Helen GA
    Joe
    @jg_iii_
  31. #1031
    Mar 06 2014
    Connecticut
    Tail of the dragon hangs - proposed to my girlfriend as well
    Joe
    @jg_iii_
  32. #1032
    Mar 06 2014
    Connecticut
    Helen, GA hangs
    Joe
    @jg_iii_
  33. #1033
    Mar 06 2014
    Connecticut
    More Helen GA, Bell Mountain, and Richard B. Russel scenic highway hangs
    Joe
    @jg_iii_
  34. #1034
    Mar 06 2014
    Connecticut
    Alpine Volks fair Audi meet, and the mutts nuts show. Some of the favorites included
    Joe
    @jg_iii_
  35. #1035
    Mar 06 2014
    Connecticut
    random photos from the trip
    Joe
    @jg_iii_
  36. #1036
    Mar 06 2014
    Connecticut
    More photo dump- new washer cap, friend gave me an oem r8 ash tray which is a super cool accessory, and some photos from my trip to maine for VAG Fair Maine
    Joe
    @jg_iii_
  37. #1037
    Mar 06 2014
    Connecticut
    VAG Fair Maine - took home first place in the B7 A4 class
    Joe
    @jg_iii_
  38. #1038
    Mar 06 2014
    Connecticut
    Impulse's Progression Thread (Picture Heavy)
    Cult classic 2021 - took home top 25 at the show!
    Joe
    @jg_iii_
  39. #1039
    Mar 06 2014
    Connecticut
    Random shots
    And now I’m current with today
    I found out that my 2.7 has low compression, which has been the case I guess all year, since I had a check engine light pop up for “random multiple misfire” and “cylinder 4 misfire”. I was KILLING myself trying to figure this out, since I have all new spark plugs, coil packs and injectors. I was troubleshooting all sorts of issues before just turning it over to my trusted shop - SpeedSport Tuning in Danbury CT. I went in and chatted with the service advisor at length about all the troubleshooting and when I notice it missing, and I guess that prompted the compression test.
    So that being said, I had already bought 2.8 heads and a whole supertech valvetrain kit as well. Today I just ordered pauter rods, mahle power pak 85.1 pistons and calico coated rod bearings. Going to drop a spare block and the heads off to the machine shop soon and get the ball rolling
    I’m shooting to have my car all done by February in hopes of taking it to EuroTripper
    Joe
    @jg_iii_
  40. #1040
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Nice pics. Beautiful car.
    Congrats on the proposal. Hope she said yes.
    Can't wait to see the 2.7/2.8 build.
    Sent from my KB2005 using Tapatalk
