Results 441 to 480 of 1108
Threaded View
    Veteran Member Four Rings impulse's Avatar
    Mar 06 2014
    2006 B7 A4 - 2.7t Swapped. 2008 8P A3 - 3.2L VR6
    Connecticut
    Impulse's Progression Thread (Picture Heavy)
    Hi everyone, here's a short intro:
    I have owned 2 B7 A4's; the black and the crimson red. No, it is not the black car repainted. I sold that one for various reasons and bought the maroon one, mainly because the body was clean and because it was better maintained and had less owners (the black car had 5 prior, this one had 2).
    Feel free to follow on Instagram for more frequent updates! @jg_iii_
    Here's some features that the car received:
    Nick's Car Blog - http://nickscarblog.com/featured-rid...win-turbo-swap
    Brilliant Motorworks - http://brilliantmotorworks.us/media-joe-b7-a4.html
    Here's my full mod list. I will try to stay on top of updating this...
    Interior:
    - NW Crafted Reupholstered Interior - seats, door cards, and more
    - Black Suede Wrapped Headliner
    - Custom Rear Deck by Draggin Style Customs
    - Custom Trunk by Draggin Style Customs
    - ProSport Evo Boost Gauge
    - ProSport Evo Air/Fuel Gauge
    - Sport Shifter Kit
    - CF Steering Wheel
    - CF Dash End Caps
    - CF Front Door Inserts
    - CF Rear Door Inserts
    - CF RS4 Trim
    - CF Oh-S#!t handles
    - CF Sunroof Grab Handle
    - Android Head Unit
    - RS4 Pedals
    - Full LED Interior lights
    Exterior
    - Widened Quarterpanels with custom vents
    - Full respray in Crimson Red Metallic
    - DTM Front Bumper with added side CF vents and extended upper body line
    - RS6 Modded Grille
    - CF Grille Trim
    - CF Front and Back Rings
    - DTM/RS4 Modded Fog Grilles
    - Custom Bumper DRL
    - CF OEM DTM Front Lip
    - RS4 Side Skirts
    - CF DenJam Side Skirts
    - Balogh Body Worx CF Rear Bumper Spats
    - CF B Pillars
    - CF Rear Window Triangle
    - RS4 CF Mirrors
    - Siebon CF Hood with paint fade
    - Aerocatch Hood Pins
    - Euro RS4 Trunk Lid
    - CF Rear Bumper Trim
    - CF Diffuser Overlay
    - 25th Anniversary DTM Rear Bumper with extended body lines
    - JOM LED Tail Lights
    - 20% Window Tint sides, 50% windshield tint
    Engine Bay Aesthetic:
    - Zealous MFG Beauty Hardware
    - CF B5 RS4 OEM Engine Covers
    - CF Side Engine Cover
    - CF 034 Intake Heat Shield
    - R8 Oil Cap
    - R8 Coolant Cap
    - R8 Power Steering Cap
    - ECS Billet Washer Cap
    - ECS Billet Brake Cap
    - ECS Aluminum Dip Stick
    - Powdercoated Charge Piping and Valve Covers
    Performance:
    - 2.7t Swap
    - Built 2.8 Heads w/ Ferrea Valvetrain, +1 Valves, 2.8 Intake Cams
    - Built Bottom End w/ Pauter Rods, Mahle 81.5mm Pistons, 2.7 Crank
    - ARP Main Studs
    - ARP Head Studs
    - ET Spec Tune
    - Borg Warner RS6 Turbos with Mamba Wastegates
    - B5 RS4 Y Pipe
    - 85mm 034 MAF
    - 1000cc Bosch EV14 Injectors
    - Walbro 450 Fuel Pump
    - Forge 007 Diverter Valves
    - ProjectB5 Big Belly Ported Intake Manifold
    - RS4 Throttle Body
    - 034 RS4 Throttle Body Boot
    - Evolution Racewerks Side Mount Intercoolers
    - THE-Tuner Cast Exhaust Manifolds
    - 3 Inch Custom Catless Downpipes
    - JHM Non-Res 2.75 Cat Back RS4 Exhaust
    - Ringer Racing Stage 4 Clutch
    - 034 Motorsports Lightweight Flywheel
    - 034 Billet Fuel Rail Kit
    - Various 034 Motorsports Silicon Hoses
    - 034 Motorsports FSI Coil Pack Conversion
    - 034 Motorsports X34 CF Intake
    - 034 Solid Aluminum Motor Mounts
    - 034 Motorsports Poly Snub Mount
    - 034 Motorsports Density Line Transmission Mount
    - 034 Motorsports Metal Bi Pipes
    - JHM Trio Shifter Kit
    - Fluidampr Crank Pulley
    - ECS Lightweight Alternator and Power Steering Pulleys
    - 034 Spider Hose
    - JXB Driveshaft Carrier
    - USP Metal Slave Cylinder
    Suspension:
    - Airlift Performance Front and Rear bags
    - Airlift Performance 3P Management, dual 444c compressors
    - Bilistine shocks
    - Hotchkiss 35mm front sway bar
    - Hotchkiss 29mm rear sway bar
    - Verkline Poly Bushings in all Rear Control Arms
    - Powdercoated Subframes Front and Back
    - Verkline Solid Subframe Bushings
    - B7 S4 Power Steering Rack
    Brakes:
    - Front:
    - 18Z Brembo Cayenne Calipers - 6 Piston
    - 345mm Adams Rotors
    - Hawk HPS Pads
    - Brembo Stainless Steel Hoses
    - Rear:
    - Brembo Cayenne Calipers - 4 Piston
    - 330mm Adams Rotors
    - Hawk HPS Pads
    - Vosh Mods Bracket
    - Wilwood Parking Caliper
    Wheels:
    - BBS LM 3 Piece
    - Front: 18x10 et20, Hankook Ventus V-12 Evo 2 245/35/18
    - Rear: 18x10.5 et17, Hankook Ventus V-12 Evo 2 255/35/18
    New car:
    Old Car:
    Joe
    @jg_iii_
    Check out my progression thread - http://www.audizine.com/forum/showth...Picture-Heavy)
