Page 6 of 6 FirstFirst ... 456
Results 201 to 235 of 235
  1. #201
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    Lensch09 2016 S4 Build
    You WILL need a dremmel to remove the one-time use clamp from the "T" fitting on the drivers side. No clue why Audi used that. A bit ridiculous.
    Cut the stock line on the drivers sided per AMS
    Stock heat exchanger compared to the AMS unit
    New exchanger mounted up
    You may need to slightly bend this bracket on the AMS kit. My guess is that it potentially becomes dis-figured during the welding process. Not a huge deal
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
  2. #202
    Feb 20 2004
    I had some help from a few buddies over having a few beers during this
    AMS recommends mounting the relay and fuse holder to the firewall using a nut and bolt through pre-drilled holes. I have a CR-15 cross member that blocks access/space to utilize those predrilled holes.
    We had to improvise.
    There is a sensor on the second firewall (maybe a YAW sensor?) that we mounted the relay underneath, then mounted the fuse holder to a different previously factory installed mounting point utilizing a plastic "speed nut." Looks pretty decent.
    Pigtail to grab a signal from the factory pump installed
    Where we ran the wiring down to the AMS reservoir/pump
    Starting to run the wiring down to the factory pump
    Previously:
  3. #203
    Feb 20 2004
    Everything is all wired up. Filled with coolant now, too. I'd guess that capacity increased by 1.25-1.5 gallons over stock.
    We put the car back down on the ground to complete the bleeding process. This is important as I can see a guy having problems if the rear is down and the front is up (the exchanger sits high when the car is at this angle).
    Bleeding the system. Heater on full bore, reservoir weeps first, then the exchanger, then the two supercharger bleeders.
    New fuel line and wiring looks great (it's hard to see, which was the point)!
    Previously:
  4. #204
    Feb 20 2004
    Next morning, after drinking some beers the previous night, decided to put the bumper cover back on today.
    New fuel line and wiring on passenger side
    New wiring on drivers side
    Overall, the car seems to run smoother (definitely the new plugs with a consistent gap). Car also seems to feel snappier up top, too (probably also the plugs).
    There's one last Wednesday left for test and tune at Sac raceway. Hopefully I can get in an 11 second pass. If no, there's still a bit more left in it once GIAC releases their dual pulley file for the B8.5
    We also tried to test fit one of my wheels onto the JHM S5 to see if the 382mm BBK could be in my future. 19" is just enough of a wheel diameter to house those brakes. Unfortunately, the offset of my wheels did not clear the caliper (a 5mm spacer would put me HARD into the front fenders). Not looking to change wheels/fitment for a brake setup at this time, so we'll have to figure something out later.
    Stay tuned!
    -DL
    Previously:
  5. #205
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Where did you grab the B8 hard lines for the cooling? I have a heat exchanger coming on a B8.5 and I'm urging to fund the best way to install a similar exchanger and all the fittings needed.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
  6. #206
    Feb 20 2004
    Quote Originally Posted by cjw View Post
    You've gotta be careful with that. If you run the B8 headlines, you will also need B8 softlines. If you run the B8.5 hard lines, you will need softlines specifically for the B8.5
    AMS sells the hardlines with their kit (included). This is also why their kit is more expensive for the B8.5.
    Previously:
  7. #207
    Aug 11 2015
    Alberta
    So I'm better just using soft house then?
  8. #208
    Feb 20 2004
    If you bought a kit for the B8.5, you will need to reuse your hardlines (assuming you are in a B8.5).
    If you bought a kit for a B8, you will need B8 hard lines (again, assuming you own a B8.5).
    Previously:
  9. #209
    Feb 20 2004
    Well, we confirmed today that my car does not have the "HiRev" file from GIAC. My car had been topping out between 6,700 and 6,800 (pulling throttle and fuel).
    Going to get reflashed here soon with the HiRev file (which I understand gives me the full 7,200).
    Feeling better and better everyday that this car will hit the 11s, this year. Definitely once the B8.5 DP file is released!
    -DL
    Previously:
  10. #210
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Quote Originally Posted by Lensch09 View Post
    -DL
    You'll get the 11's. If you can manage a 1.7x 60, you should be able to squeeze out a nice time with your setup. I remember Auditude went 11.80s@117 with a giac stage 2 tune on the stock clutch a while back. Haven't seen any MT cars run on race gas since his pass. Good luck!
  11. #211
    Apr 05 2016
    Portland, OR
    Not sure exactly what you are saying here so I will add a bit more.
    B8.5 hard tubing both exit on the drivers side as the OE heat exchanger was redesigned.
    B8 hard tubing has an exit on each side. (You can see this in the picture above)
    If you are installing an aftermarket HX with the exception of the Forge kit I would recommend grabbing the B8 tubing for a cleaner run.
    You will likely need to pickup some additional tubing from the automotive store but it is nothing special.
    I just took a piece of my OE tubing in to the store with me and had them match it to one of their spools they had in the back.
    There is a decent chance I will be installing a PLM kit with B8 tubing and a reservoir to divorce the loop sometime in the next month or two if you wanted to wait.
    If you want the B8 tubing here is a link for it on ECS: https://www.ecstuning.com/Audi-B8_S4...ger/ES1598497/
    You can find used ones for about half of this if you're crafty
    Geoff
  12. #212
    Feb 20 2004
    Quote Originally Posted by whiped View Post
    Yeah, you probably did a better job of explaining it than I did. I was trying to explain that the softline (rubber) plumbing between the different hardline versions will be different. In my opinion, an aftermarket HE install is cleaner with the B8 hardlines.
    -DL
    Previously:
  13. #213
    Feb 20 2004
    Got the car retuned today with the high-rev file at IPB Autosport in Sacramento. Thank you to Ron at IPB and Seth at GIAC.
    Initial impressions is that the car is QUICKER! Those extra 600 or so revs in the "fun area" helped ALOT.
    Won't get a chance to go back to the strip until probably the first or second week of the new year. I've gotta be hunting down 11s!
    Oh, and also had a bombtastic brunch with the old lady
    Today was a good day.
    Stay tuned!
    -DL
    Previously:
  14. #214
    Feb 20 2004
    Well folks, I've moved into the stage where I will start ditching the "pretty wheels" when I go to the track. New trackers weigh in at 42ish per corner. Haven't weighed my pretty shoes yet, but I'm guessing 55+ per corner.
    Hunting for 11s and another .5 MPH+ in trap to snag the 6 speed MT record (until someone bests it, enter APR in 2 weeks?).
    18X8.5" Ultraleggeras on 245 PSS compared with AG 9.5"on 255/265 XL DWs.
    Reason: car will not pull less than 1.8# (with multiple drivers including world record-holder drivers from JHM). Outta the hole with 1.8# + 92 1/8 is low for a 26 MPH long end car.
    Consistent 25+ backhalf car...
    Stay tuned folks! Keep pushing this platform!
    -DL
    Previously:
  15. #215
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    are those numbers with 93 or 104?
    any word on GIAC's dual pulley file? i thought i read that you had been in touch with them...
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
  16. #216
    Feb 20 2004
    Quote Originally Posted by KRp220 View Post
    104. Full weight (including spare and tools) probably 50 lbs of gear for work.
    Still waiting for GIAC to publicly release their DP file. Getting irritated with the wait... Hopefully soon.
    -DL
    Previously:
  17. #217
    Feb 20 2004
    Lensch09 - 2016 Daytona Grey B8.5 S4 Build (6MT)
    Project to get rid of some of the drone is underway.
    Noico 80mil under the spare tire carpet (can't even tell it's there) and Dyanamat Extreme on both sides of the rear deck.
    Also going to do some Noico 80mil under the rear bench.
    Hopefully takes away some the drone that the AWE track makes.
    Previously:
  18. #218
    Veteran Member Four Rings Akrion's Avatar
    Dec 24 2010
    Good stuff :). Reminds me a lot about my build. Had porbably 90% of the performance upgrades you did on a quick glance.
    Enjoy!
  19. #219
    Senior Member Three Rings MS203's Avatar
    Apr 09 2011
    '15 S4
    Newport Beach, California
    Awesome Lensch. I'm very curious to hear your update as to if this worked well or not. I also have the Track and would do this in a heartbeat, provided you find out that it can somewhat alleviate the drone. Great idea.
    –Matt
    2015 S4: Brilliant Black, hardwired V1, Roc Euro intake, H&R Street Coilovers, CR-15, SPC Adjustable Upper Control Arms, 034 Rear Sway Bar w/ Moog Endlinks, 034 Rear Subframe Mount Inserts, AG M510's 19x9.5 on Michelin PS4S (255/35/19), AWE Track w/ 102mm diamond black tips, Chipwerke Pro-S.
  20. #220
    Senior Member Two Rings Michigan_Rings's Avatar
    Oct 18 2015
    2015 Monsoon Gray A3
    Florida
    Awesome, can you please add more pics of the final product? I want to enhance my project. Thanks!
    2013 S4 P+ | Estoril Blue | DSG | Lunar Nappa | MMI | Full ADS| Sports Diff | CR-15 | AWE Touring 102 MM | Kohlefaser Luft-Technik Intake | 034 Mounts & Inserts | Gloss Gunmetal TSW Bathurst 19x9.5 ET 39
    2015 Audi A3 P+ | MMI |
  21. #221
    Senior Member Two Rings m1k3d3's Avatar
    Jan 31 2017
    Philly
    Just read through the entire thread.. Great build.
    Glad to hear that there are some 6MT owners at there still pushing this platform.
    2015 S4 Sepang Blue | 6MT | Tech | B&O | Leather | Carbon Atlas | Black Optics | Sport Diff
    ECS Kohlefaser Luft-Technik | Bilstein PSS10 | ECS 10 & 12.5 mm spacers | USP Stainless Steel Clutch Line | Suntek CXP 35% | 034 Drivetrain Mounts | RS4 Grille
  22. #222
    Feb 20 2004
    Quote Originally Posted by Michigan_Rings View Post
    Final product didn't work well (doesn't stick to liner). I'm going to have to go back to the drawing board and re-think. I'm thinking applying the product under the rubberized cargo-mat might work? Try that next.
    DL
    Previously:
  23. #223
    Feb 20 2004
    Ran the light weight wheels at the JHM BBQ on the new GIAC DP tune, couldn't seem to keep traction. 60' definitely lacks on the 245 cross-sections. Didn't even bother to toy with tire-pressures with that track-prep.
    Ran multiple 11.9x at 118ish
    Probably going to put them back up for sale, or throw on slicks.
    Previously:
  24. #224
    Feb 20 2004
    Back on wider wheels and tires now. Car absolutely loves it.
    Ran it once decently, shut it down, and went home. Seeping water pump and a previously popped SC belt had me concerned about driving home 87 miles.
    Rear bench and passenger seat pulled. Spare, tools, work equipment (2 laptops, presentation tools, suits and shoes), and fuel put me at 3850 for race weight (without me in the car, I weigh 226). Driving the 99 sucks when you worry about flats (3 replaced tires and 1 windshield per year, for me)
    Ran the 19X9.5 wheels, too. They obviously hook better than the light weight OZ
    DA was around 400 on your typical Sac Raceway prep (not great). It is an NHRA track though, so this is legit.
    I'm thinking 11.5s or better are possible on negative DAs (sure wish I could get those -1500 ones), a ported blower, and slicks, I think!
    -DL
    Previously:
  25. #225
    Feb 20 2004
    Next mod, brakes. Got a great deal on low mileage ECS rotors from a buddy who upgraded to bigger stuff. Adding in Hawk HOS 5.0 pads.
    Gonna stay on the wider wheels... car just won't hook up on 18s.
    Previously:
  26. #226
    Feb 20 2004
    Been too busy with work, girlfriend, prepping for GMAT, golf, new niece, more golf, racing to update this thread.
    Recent shenanigans
    Photos before beer/Stanley cup session
    "Pretty" helmet is now retired. Too old to race with that one.
    Previously:
  27. #227
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 13 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    Nice build clean car
  28. #228
    Feb 20 2004
    ECS LW rotors are now installed along with Hawk HPS 5.0 pads. Feels pretty much the same with my driving style. But, less weight, and less dust!
    Previously:
  29. #229
    Veteran Member Three Rings FromRagsToS4's Avatar
    Jan 23 2017
    Idaho
    I wonder how much the weight savings will affect your 1/4 times or traps.
    2014 S4 Premium Plus/Glacier White Metallic/6spd Manual/Sports Diff/Adaptive Damping Suspension/Black Napa Leather/19" Peelers/B&O Sound/MMI-Navi/Side Assist/Carbon Atlas Inlays
  30. #230
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by FromRagsToS4 View Post
    I am not sure. My times last weekend were done with an extra 100lbs or so in the trunk as I was going to visit my folks afterward.
    Even with the extra weight, I was still running consistently faster than I had the following time out.
    100 lbs < 1000' DA, can't conclude anything else
    Geoff
  31. #231
    Feb 20 2004
    I know, right? These guys running in -500 to -1000 DAs a few months ago posting great times stating DA had nothing to do with anything.... Yesh, yeah right. When I ran the 11.7, it was 400 DA. I would imagine the drop from 1400 to 400 would be just as significant as the drop from 400 to -500 (pending traction isn't an issue, which I have sorted out, now).
    I'm not going back to the track until October or November. I know better, and I know how much mine falls off when the temps climb. To me, it's not worth the stress on the car trying to re-set a record with a high DA.
    -DL
    Previously:
  32. #232
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    DL
    I made some 3d printed caps to clip into the holes in the trunk (on a b8.5 s5). if you have access to a 3d printer, i can send you over the file.
    2013 B8.5 S5 - Dual Pulley 189mm/57mm. EPL E85 Dual Pulley/DSG flash. Autotech HPFP. APR B8 Heat Exchanger. Injen Intake. Deleted Mufflers. 034 Street Motor Mounts. 034 Driveline Mount Inserts. KW HAS + H&R F:20mm/R:25mm wheel spacers. S6 Brake Conversion
  33. #233
    Jan 19 2018
    Redondo Beach, CA
    Came here for the yellow fog light overlays...
  34. #234
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by tpowers012 View Post
    https://www.lamin-x.com/Audi-S4-13-1...rs-p/a131y.htm
    Probably, not positive.
    Geoff
  35. #235
    Feb 20 2004
    I made my own.
    Did a few more things to the car, just haven't been on here much. Biggest thing was probably the metal Beck/Arnley slave... Seemed to help alot (and fix my failing stock unit).
    PSA: If you're planning on removing your stainless slave line more than once in it's life-time, make sure you have the replacement o-rings readily available.
    -DL
    Previously:
