http://www.cars-equipment.com/www/en...eering-wheels/
I emailed the company and these will fit the A4 B8, if you have any questions just email and ask them. The company said to put what car you have in the notes section when checking out so they can double check to get you the right stuff. They sent me my wheel with the wrong badge but they corrected the issue and sent me the correct S-Line badge.
Select Delivery FedEx Worldwide: 1-5kg, if you're in the US you will be charged extra for VAT, and you will be charged more for using Paypal over a credit card.
Just A Few Flat Bottom Wheels (There Are More):
1. http://www.cars-equipment.com/www/en...t-bottom-mfsw/
2. http://www.cars-equipment.com/www/en...bottom-mfsw-2/
3. http://www.cars-equipment.com/www/en...bottom-mfsw-7/
Airbag:
http://www.cars-equipment.com/www/en...audi-a4-a5-q5/
Bits You Need:
Torx T30
Torx T55 or M12 Triplesquare Bit
Bit Set I bought:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
B8 Install:
The airbag is removed by popping two small covers after the back to expose two Torx bolts. These are removed by the T30 bit or socket. This is easily done by having the car running and turning the wheel 90 degrees left, undo one bolt, turn to center and then 90 degrees right and repeat. Put the wheel back to center and shut the car off, no ignition on. Slide airbag out, undo plugs. Undo the center bolt with the T55 or M12 bit, before removing the wheel make sure you look for the alignment markings so you can line up the new wheel in the same spot.
Slide the new wheel on in the same position as the old one removed. Install the center bolt and tighten. Plug in the two plugs for the airbag and control system. The new airbag will push into place and clip, no bolts are required.
If you're adding paddle shifters you will need to use VCDS after the installation
VCDS:
16 - Steering Wheel
07 - Coding
Long Coding Helper
Byte 2
Bit 5 (Tiptronic Installed)
I can't believe it took me this long to find this site and the wheel options they have for a good price. Thanks dtoobin for showing me this site!
