I finally had some time to install the
Homelink module, well sorta...
Here are some photos:
https://goo.gl/photos/BJf3EfkScev7ahwi9
Tools:
1. Exacto knife or similar and replacement blades.
2. Small flat screwdriver to unlock some of the connectors inside the overhead console.
3. Small plastic tool or similar to remove the black part of the overhead console.
4. A file folder and some scotch tape to make a template of the
homelink.
5. Patience.
6. Beer (optional)
Steps:
1. Remove the overhead console (the black part)
This one is easy, just pull from the back gently. I used a plastic tool but you could probably use your fingers.
2. Remove the white section of the overhead console.
This took me some time to figure out because it is firmly attached so I was looking for screws but it is only secured with 3 metal clips. I just pulled straight down by sticking my fingers in the openings on each side of the sunroof switch. The clips are holding the back of the console. The front is held by two tongues. Once the back comes down the front slides out.
3. Then I proceeded to disconnect the white part from all the connectors. Most of them you can remove with just your fingers. At least one you need a small screwdriver to push the pin in to pull it out.
4. From a file folder, I made a template of the faceplate of the
homelink so I could present it and determine where I needed to cut. I used the photos from the internet as a reference. Although it appears you have some room to move left or right (closer or away from the windshield) you definitely do not have much room to play. the thickness of the
homelink module prevents you from installing it any closer to the windshield. Mine ended up like 1/8" from touching the inside of the roof.
5. I taped the template onto the headliner and went at it using the exacto knife. I made a small hole thinking I could work my way towards the final opening, this was a mistake. The headliner is made out of fiberglass and the blade got dull in no time, furthermore making a hole in the center just removes rigidity to the whole thing making further cuts more difficult. Oh well, live and learn. After a few tries the faceplate went in with no problems.
6. I thought the order of installation was, faceplate in, then install bracket to secure the faceplate, then install the module, well nope. There is no room to install the module with the faceplate installed; the roof is right there. So you have to present the bracket in the hole from the inside along with the module, then push the faceplate in, BUT BUT first make sure the right connector is plugged in the module (you have one labeled "high" and my console says "high" on the inside). I thought I had done this but I plugged in the wrong cable into the module and there's almost no room to unplug it and once the
homelink module is installed there's no way you can remove it. So this is where I'm stuck. I did not dare to power up the whole thing to see if it would work on the fear that I would fry the whole thing. So I will try unplugging the connector using a paper clip and a telescopic mirror and some patiente.
11/4/15: After an hour or so, I managed to disconnect the wrong cable (the non-high) from the
homelink module using an "Oral Care Kit", yeap you heard that right. Using the hook and the mirror from the kit I managed to unclip the connector, pull it out and guide the new connector into the module until it clicked. Put everything back together, programmed the buttons and it worked the first time.
Tip: After I reinstalled the white section of the console I noticed how the metal clips on the sides were holding the console in place. I suggest being careful when removing the white section as these clips could bend outwards instead of flexing inwards when pulling down on the console.
