Results 1 to 21 of 21
    Sep 04 2009
    Anyone buy one of these custom built subwoofer boxs built for the B8?
    Feb 13 2004
    Silicon Valley, CA
    you probably don't want to put that on the left side as that is where the factory amp and the nav computer and some other stuff are unless you want to move all that. I build a custom one for the right side.
    Kevin - Moderator, Audizine
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Just a bit of .5 cuft of air space which is right on for the JL slim subs. I may have missed what it would cost to ship to the states.
    Lots of people move the nav there are several active threads on this right now. One in here with instructions.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Jul 16 2012
    Mid-Atlantic
    Quote Originally Posted by cspcrx View Post
    Looks like it's about $75.00.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Feb 13 2004
    Silicon Valley, CA
    Or you could save yourself a lot of work, put it on the right and have 0.9 cuft of space. See the one in my build thread in my sig.
    Jan 04 2013
    Phoenix, az
    I am waiting to see how the ones turn out from the member in TX who made them for the right amd left. I thought he said the right side would only fit an 8in sub though.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    12" or bust
    2021 Audi S4, P34 Intake
    Apr 24 2013
    Canastota, NY
    Can they fit a 12? Is on my list to do this summer
    Apr 11 2012
    this car does need a 12 unless you drive with your back seats down. 10 was just not enough, even with the OEM sub removed.
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    I have had this box in my car for the past 3 weeks and all i can say is that it's great. Great price at $175 shipped from the UK. Perfect fitment when I 3m taped my non b&o amp to the inside of the fender wall just behind the box. I need to add some murder mat to the inside of the box though to reduce vibration. 10" Jl w6v2 with Jl XD 600/1 amp I'll post pics soon
    Nov 10 2014
    Apex, NC
    size of the sub means nothing.. i've seen 10" subs out perform mediocre 12"
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by doug97gxe View Post
    Perfect world, I'd prefer one of each.
    Nov 10 2014
    Apex, NC
    2 ID Max 10's will pretty much destroy 90% of the 12's on the market
    Present:
    Sep 04 2009
    Quote Originally Posted by EHesh14 View Post
    I think the AZ community would certainly appreciate any pictures you could share. Thanks.
    Apr 11 2012
    dumping 500 watts rms into a $200 12" instead of a $130 10" worked better for me (both handled 500 watts rms), your millage may vary, especially if you buy a $500+ 10" that can handle crazy power.
    Senior Member Three Rings bruno7652's Avatar
    Dec 22 2014
    2005 Dodge Ram 1500 SB Hemi Sports Pkg
    So.Cal.
    Hello Everyone,
    I am looking for a 10" sub box for the right side of my 2013 S5, I do not want to get into warranty issues
    by relocating all of the equipment that is on the left side. I can deal with the fuse box being covered up.
    Does anyone know of a quality sub box out there? I have been looking a awhile and can not find one.
    Any help will appreciated.
    2013 S5 Phantom Black 6MT
    |Lifetime Sirius|Bilstein|AWE|Apikol|E C|JHM|BFI|CR-15|BBS|Michelin|BlackVue 750s-2CH|StopTech BBK|Roc Euro CAI|
    |034 stage II+|APR CPS|
    Aug 30 2015
    Fairbrn,Ga
    SUB BOX
    Im thinking about purchasing this box also. Are there any problems with it? How did you secure it? And you are happy with the sound?
    Nov 10 2014
    Apex, NC
    One of our forum members makes a similar box
    http://www.audizine.com/forum/showthread.php?t=631708
    Sent from my iPhone8s using Tapatalk
    Present:
    Active Member Two Rings mcintoshi's Avatar
    Oct 13 2014
    McKinney, Texas
    I just got one of these a couple weeks ago from a different vendor on eBay that was a bit cheaper. Shipped from the UK super fast and seems like a decent piece. It is a snug fit, and is held in place by the trunk lid arm. Couple things to note: (1) it is made from 1/2" MDF (2) the speaker mounting hole is 9" but can be cut a bit larger, max mounting hole size will be 9.625"(3) the recessed hole is 11.5" (4) internal airspace is .5 cuft.
    The shipping is a bit cheaper from this seller although the box is a couple bucks more.
    http://www.ebay.com/itm/Audi-A4-Cust...item2a4956309d
    2019 TT RS Coupe
    2014 Audi S4 (Sold)
    Established Member Two Rings rcz22's Avatar
    Aug 19 2015
    2014 Cherokee Overland, 2011 Ducati 848 EVO
    New Jersey
    Hey- have you been able to snap any shots of your setup?
    Oct 13 2014
    McKinney, Texas
    I have not had much time to work on the install but I was able to finish the sub enclosure mods. I removed the black carpet from the face, enlarged the speaker hole to fit a JL Audio 10TW5, added a bit of silicone to the joints, then re-covered in black vinyl and added a bit of polyfill. I snapped a couple pictures while working on it and thought I would share.
    2019 TT RS Coupe
    2014 Audi S4 (Sold)
