Results 1 to 22 of 22
    Junior Member Two Rings
    Jul 10 2013
    Memphis, TN
    auto start/stop function disable
    Has anyone had any luck disabling or at least defaulting to off the start/stop function? I have a 2016 A6 and want to have the system defaulted to the off position or permanently disabled. I have tried to disable the system threw vag-com by deselecting it in numerous control modules but the system still remains active.
    Thanks,
    Established Member Two Rings neddy191's Avatar
    Dec 30 2014
    NC
    On my 2016 S6 I pressed the button on the dash (the A with the circle around it under the sim card slot) a few days after taking delivery and have left it on ever since. It stays on. I'm personally not a fan of start/stop.
    2016 S6 (Daytona Gray)
    Jul 10 2013
    Memphis, TN
    Quote Originally Posted by neddy191 View Post
    That is what i was hoping would happen but mine seems to default back to the on position once the ignition is cycled.
    Aug 14 2019
    Tampa
    2018 S6... I just push the button and it stays off.
    Established Member Two Rings bryanb8's Avatar
    Apr 10 2018
    NorCal
    This is exactly what I did with mine. I actually tested it last night to make sure it still worked....turned it right back off. Hope you can figure out OP how to leave it off. Maybe just the S models have the ability to leave it off and remembers it.
    Current: 2018 S6 Prestige - Glacier White Metallic/Black, S tronic, Valcona Leather, Bang & Olufsen, S Sport Package, Driver Assistance Package, 20" Black Optic Package, Carbon Atlas Inlays, Audi Beam Rings
    Former: 2014 S5 Premium Plus - Glacier White Metallic/Black, S tronic, Nappa Leather, Sports Differential, B&O, Carbon Atlas, Side Assist, MMI Nav Plus Package, 19" 5 seg Peelers, SC badges, all weather package
    Jan 10 2017
    CA
    Quote Originally Posted by bryanb8 View Post
    That is correct, but then you have the ugly yellow light on all the time. So if you invert the function it is off all the time with the light off.
    2016 Daytona Gray S7. Black optics + sport pkg. Stage 3, eurocode stuff, cosmetic stuff.
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    Quote Originally Posted by kpriv View Post
    that is brilliant!
    2016 S6 - sport - optx- atlas - AE nardo
    Aug 14 2019
    Tampa
    Yep, thats what I did. Now if there was a way to turn invert the blind spot assist led by the drivers side mirror.....
    Jul 02 2019
    clearwater florida
    Quote Originally Posted by DK2392 View Post
    a small piece of black elec tape.......
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Odd, on my old A6 I pushed the button before driving it off the showroom floor and never had to press it again.
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Deactivated Three Rings
    Apr 30 2014
    Stockholm/Sweden
    I had the stop function when I opened my door and the engine stopped running. I disabled it with VAG but I don't know if its possible to disable start/stop function...
    May 16 2010
    Germany
    Stg 09
    Login 20113
    Adaption channel 34 reading
    a) worth of adaption channel 34 reduce by 4 (effected Bit 2 to 0) = SSA per default after each ignition on to off
    or
    b) add to worth of adaption channel 34 the worth 32 (effected Bit 5 to 1) = SSA with memory-function
    and/or
    c) add to worth of adaption channel 34 the worth 64 (effected Bit 6 to 1) = SSA with inverted display
    Senior Member Three Rings SpeedETC's Avatar
    Oct 29 2007
    2004 JHM SCed Audi S4 (gone), 2004 VW Touareg (gone), 2000 Audi A4 (gone)
    Poquonock
    Quote Originally Posted by DVE View Post
    Stg 09
    Login 20113
    or
    and/or
    Just did this on a 2016 A7... It works!! Thanks!!
    Jun 14 2007
    2000 S4
    Connecticut
    Stg 09
    Login 20113
    or
    and/or
    To those who have tried this and have had luck... If I want option B, which I would assume most people do, is it simply changing the value in bit 34 from 20 to 52? Trying to disect this post, think that has to be right, but want to confirm before doing it. Already tried using the CAN gateway dropdown, but that didn't do the trick.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by AudiSportB5S4 View Post
    Quoting myself here, but this indeed worked on my 2016. Central Electric, login with security code, adaptation channel 34 change value from 20 to 52 (for option B as outlined above). I’m sure the others would work as well, I don’t personally mind the yellow light for now :)
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    On my 2015 once you turn it off, it stays off
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Senior Member Four Rings eyeloveteeth's Avatar
    Jan 07 2015
    weed wacker, lawn mower, some tools, air compressor
    NoVA
    when the car is in 4 cyl mode, my exhaust is actually louder
    Established Member Two Rings BMcD-RS4's Avatar
    Oct 29 2009
    Chicago Suburbs
    Quote Originally Posted by eyeloveteeth View Post
    How do you tell when it's in 4 cylinder mode?? I'm typically in Individual or Dynamic so not sure how much deactivation I get.
    Bruce
    2016 Daytona Gray Pearl S7 - 21" Black Optic and Sport Pkgs.
    2016 Ford Expedition Platinum
    2015 Q5 Hybrid
    2012 Havana Black A7 Prestige - gone
    2008 Sprint Blue RS4 - gone
    2006 LeMans Blue Z06 - gone
    Jan 07 2015
    NoVA
    Quote Originally Posted by BMcD-RS4 View Post
    you can definitely feel it for one. Also there is this split second when you are at a complete stop at a light, if you look for it, you can feel it. I do not believe it will ever activate in dynamic mode.
    Veteran Member Four Rings Xtek's Avatar
    Jun 09 2013
    If you go to consumption mode in the DIS you'll see the bar go green.
    - Chad
    2014 S6 Estoril Blue - APR Stage 1, AWE Exhaust
    I have USB HEX+CAN VAG-COM cable, if you need mods let me know.
    Oct 29 2009
    Chicago Suburbs
    Thanks for the update guys. The only time I could tell is at speed on the highway if you speed up a bit to overtake you feel a slight lag. But I like that 27 MPG!!
    Bruce
    2015 Q5 Hybrid
