Results 1 to 34 of 34
    Feb 20 2014
    Rochester, New York
    H&R coilovers installed - max hight in rear and min hight in front - FTG 25.5 all 4
    I installed a set of H&R coilovers last weekend and in order to reach a level FTG measureme, the rear springs are at the max of the recommended adjustable range and the fronts are at the opposit extreme.
    I would like to have a 1/4 inch forward rake, any suggestions?
    Thanks.
    Veteran Member Three Rings CloseEncounters's Avatar
    Mar 04 2012
    2020 Navarro Blue SQ5, 2019 Black Q5 Prestige & Cannondale 27.5 'Beast of the East' MB.
    Tucson, AZ
    WOW!! I'm facing the exact issue on my '12 A4 Avant after installing H&R Street Performance Coils last week. I did some research and I'm now thinking the only option may be fabricating a 1/4" thick spacer from aluminum or stiff rubber that can be installed 'on top of' the rear springs. I initially considered placing them 'under' the adjustment fixtures which sits in the lower control arms but this would have them siting too far up in the holes on the lower arms.
    Stay tuned... I'm not loving that reverse rake look but the ride and handling are just awesome.
    Dec 21 2013
    Portland/OR
    You could contact H&R. They likely have springs with matching spring rate that are taller to fit your rear perches. That's what I did with my RSS+ setup. Probably run you $150.
    Feb 20 2014
    Rochester, New York
    Good to know I am not alone- The ride is great so that is a plus.
    I have seen spacers around, I'll have to go back and do some more research. In the interim I will contact H&R to check out the longer spring option.
    Thanks for the feedback
    Jun 13 2014
    Albany, NY
    How was the install itself? Did you run into any issues or have any advice on what not to do? I'm about to tackle this project Sunday if I can get some garage time.
    Mar 04 2012
    Tucson, AZ
    Quote Originally Posted by BKE View Post
    Would love to know also if H&R offers a longer spring or offers any solution on getting that extra 1/4" height.
    Quote Originally Posted by MakeYourLuck View Post
    Fronts are straight forward but the rear spring are easier to remove and install using Motorcycle shock spring compressors which are smaller as there is so little room to work in that location. Great if you can get a lift as it makes the job so much easier. Also...many folks have an alignment done right after installation but I opted to drive the car for about 100 miles (some over uneven roads) to help everything settle. Let us know how it goes.
    Last edited by CloseEncounters; 04-10-2015 at 10:26 AM. Reason: Meant drove 100 miles before alignment not 1000
    Jun 13 2014
    Albany, NY
    Ok great, Did you use any DIY posts for reference or was it pretty straight forward?
    Feb 06 2015
    Pictures??
    19’ Audi RS5 SB H&R VTF Has Kit|034 Motorsport|ECS Tuning
    Nov 29 2013
    Silver Spring, MD
    Quote Originally Posted by CloseEncounters View Post
    +1. Wish I had known that it rode so low (front and back) at the highest setting with no room to adjust up. The ride/harshness is actually fine (for me). But, the low setting and some occasional binding noises coupled with the fact that H&R customer service wasn't that great to deal with, makes me think I should've spent a little more and gotten the Bilsteins. Just my two cents.
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Feb 20 2014
    Rochester, New York
    I spent more time on each corner and I was able to squeeze a few millimeters here and there to a very nice finish; and still within the recomended operating range. I love it. The alignment went better than expected, aggressive but palatable.
    Summer shoes and a bath tomorrow then I'll post a picture.
    Jun 13 2014
    Albany, NY
    Any camber issues on the alignment?
    Feb 20 2014
    Rochester, New York
    No, 1.5 in the front and 1.6 in the back.
    Feb 20 2014
    Rochester, New York
    I am with ptper at this point; 23" front and rear and no room for adjustment. ECS was worthless in their support. Off they will come and on to KW or Bilstein. What a shame.
    Feb 20 2014
    Rochester, New York
    All, does anyone know the hight of a compressed installed rear H&R spring?
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Does anyone have rubbing with H&R coils? Installimg mine in a week
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Jun 13 2014
    Albany, NY
    I did mine over the weekend and so far don't have any real issues that have come up. The rears I set at the max which ended up being about perfect for where I wanted them to sit after settling. so that might take minor adjusting and the fronts I started out at the max, and it was 2" taller than the rear so I dropped it 3/4" and have put on about 200 miles on them so far. Waiting to settle down and see where it lands.
    Feb 20 2014
    Rochester, New York
    I have some rubbing in the right rear with a a full tank, 4 passengers and a big bump. That is with a rear FTG of 23".
    I am also running 19x9.5 w/ 265-35 PSS tires.
    On a related note; H&R are champs in my book, they are sending a set of new rear springs that they have bench tested and taller rear perches so I can reach the desired ride hight. Excellent customer service!
    Nov 29 2013
    Silver Spring, MD
    Good to hear! Hope they turn out well for you. Please post pics with the new height, if possible.
    Apr 27 2014
    United States
    Are you currently at max height and experiencing the rubbing you mentioned?
    435I 6MT - Daily
    Feb 20 2014
    Rochester, New York
    Quote Originally Posted by B8 S4 View Post
    Yes, but that is the issue I am working through with H&R. Specifically, the rear is max hight and the front is at minimum hight.
    Jun 13 2014
    Albany, NY
    You only rub when your car is fully loaded though? I guess that's not terrible although it would be nice to not have to worry about rubbing. Your significantly lower FTG than I am though. With my rears maxed out I'm at about 25.5. That's odd
    Apr 27 2014
    United States
    How do you know what H&Rs recomended height range is for the springs? Is it just as far as you could adjust them or is there a marking or something else?
    435I 6MT - Daily
    Feb 20 2014
    Rochester, New York
    you are where I want to be (25.5). I measured the spring fully weighted by the car and it was 5.25", Ryan at H&R mentioned that was a problem, so he bench tested a new set and sent them to me; He feels the springs alone will fix the issue.
    Feb 20 2014
    Rochester, New York
    How do you know what H&Rs recommended height range is for the springs? Is it just as far as you could adjust them or is there a marking or something else?
    there isn't a marking on the spring perch; they provide a measurement range to stay within and where to get that measurement, max is 45mm in the rear. I don't have the notes in front of me to provide the remainder of the details.
    They do note a drop range of ~1 to ~2 inches.
    Apr 27 2014
    United States
    45 mm from what? I was just trying to set my wheels to flush of the fenders, is this in recomended range? Possibly a finger or 2 higher
    435I 6MT - Daily
    Feb 20 2014
    Rochester, New York
    J
    It appears I cannot post attachments, the perch has an adjustment range of 35 to 45 millimeters, which should translate into a drop between 1 and 2.2 inches.
    Does that translate into the 1-2 finger gap you desire? Not sure. Measure your stock hight and subtract an inch and that is your starting point.
    Jun 13 2014
    Albany, NY
    After re adjusting last night for about an hour and a half ha, I have the rears maxed out to reach 25.5 and the fronts at about 25.75. I def heard a couple rubs this morning when cornering hard, which sucks but I love the look. Might need to do sways? Idk
    Feb 20 2014
    Rochester, New York
    I have the AK and the full USS sways and end links, it will help. Also, there is an option of a taller perch in the rear for up to 15 mm more space.
    Senior Member Two Rings Ek9max's Avatar
    Feb 14 2015
    Calgary/Alberta/Canada
    Ugh me too...... I really wish I saw this thread before. I installed mine today. Same probblem. I don't know how so many people are satifided with these coilovers...... This over sight on the part of H&R makes them "junk" IMO.
    But ride wise they are exactly what I wanted. Stock like ride.
    Jun 13 2014
    Albany, NY
    Ha I need to get a taller spring or something. After a few weeks of driving it's just too low. If I have someone in the back I rub on anything more than a crack in the road.
    Jun 13 2014
    Albany, NY
    What was the fix? Did H&R send new springs to you for free? Do I need to speak to someone directly and have certain info on hand for them like serial numbers and such?
    Feb 14 2015
    I called H&r directly yesterday. I even mentioned that they are helping somebody else on the forum. The guy basically told me to go F myself and deal with it.
    Jun 13 2014
    Albany, NY
    Well that's exciting.
    Veteran Member Four Rings PitchS4's Avatar
    May 14 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    I will probably get flamed for this but I purchased a large washer and put it under the rear rubber spring perch.
    Gave me .25 inches of lift in the rear. My H&R OEs were dead level and I wanted a bit of rake. 15k+ miles and no issues at all. I did remove the stone guards when I did it and had to trim the alignment nipple off the rubber perch.
    Obviously, do this at your own risk :) I looked into other lower perches from other models with the parts guy (who probably now hates me) but couldn't get the answer I was looking for and this was an inexpensive option. I didn't even need to remove the rear spring to install them I just used compressors and slid them in.
    *EDIT* I just remembered they sent me an extra set (their shipping got messed up and they overnighted me a set while the other was lost in shipping - I had paid for 3 day because I wanted them by the weekend) if someone wants them for 20 shipped. Here is my original order:
    (2) ASTM F436 FLAT WASHER 2" ZINC PLATED - DrillSpot 0156050 ASTM F436 FLAT WASHER 2" ZINC PLATED $18.12
    Shipping & Handling (Standard) : $7.48
    Total: $25.60
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
