Results 1 to 11 of 11
    Account Terminated Four Rings
    Oct 15 2013
    fluctuating RPM when cruising - cold start
    i think the revs fluctuate +/- 100 RPM when cruising from a cold start with the engine still cold. TPS problem? transmission problem?
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    I thought you were banned? Or was that from VW Vortex? Could be torque converter in trans, leaking air.....
    Veteran Member Three Rings Cantalk's Avatar
    Mar 18 2012
    is a covered parking space
    Edmonton AB/Victoria BC
    Tiptronic, CVT or manual? Need more info. What speed?
    Mike
    2008 A4 Avant S-Line Sleipnir
    Mods: ST Coilovers, RS4 Sway Bar, BFI Catch Can, 640 Mod, Podi mech gauge
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Might be PCV going out...wait for the infamous whistling....
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Oct 15 2013
    Quote Originally Posted by Cantalk View Post
    tip. it can happen at any speed. i gave it an italian tune up and it seems once the engine warms up it stops.
    Mar 18 2012
    Sounds like your torque converter is on its way out. Tons of threads detailing this situation.
    Mike
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    Its the torque converter like others have said. Its not worth changing until it starts shifting hard... I just changed mine because of this and hard shifting. When it was 0˚ or below i was getting around 400 rpm fluctuations.
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    I have (what i think is this issue) as well. Cold starts only, for a few seconds, I can feel a bit of a pulse when driving (nothing big just annoys me) but according to VAGCOM my RPMs stay at 760 without fail so idk maybe I am crazy.
    So make sure you know what it is before diving into the money pit that is throwing parts at cars.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Oct 15 2013
    Quote Originally Posted by yeoj112689 View Post
    what milage does yours have? mine's at 107k. just started happening a thousand miles ago or so.
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by esandes View Post
    87k
    Senior Member Two Rings esm's Avatar
    Jan 14 2010
    Chicago, IL
    I had a thermostat failure on my car that seemed to make the problem worse, particularly in the winter. Once the stat was replaced during a recent timing belt job, the fluctuations seemed to diminish. I don't even think they are noticeable anymore during my normal warmup period, which is now really quick. My theory is that if the car isn't warming up properly (due to an old/broken thermostat), it makes the warmup cycle take longer and may contribute to slower warmup for the transmission. YMMV.
    2017 Audi Q7 3.0T Premium Plus: Vision / Cold Weather / OEM 20" 10-Spoke Wheels / Goodyear Eagle Sport All-Season Run Flats 285x45x20 / Weathertech Mats
    FORMER: 2005.5 A4 Quattro Tip / JHM Stage 2 93oct / JHM HPFP / AWE FMIC / JHM 3" Downpipe-Y adapter / JHM-Fast Intentions S4 Exhaust / RS4 RSB / Bilstein PSS9 Coils / VMR 810 19x8.5 on 245x35x19 Michelin Pilot Super Sports / Adam's AR II Slotted Rotors / Bosch Platinum Sidefire Plugs (Bosch Heat Range 5)
