Results 1 to 2 of 2
Hybrid View
    Deactivated Two Rings
    Mar 16 2015
    B8.5 S5
    San Diego, CA
    Annoying limp mode
    Hi so getting the flashing PRND and P0706 (range sensor), im very sure its not the TCM.
    After i reset the MIL the limpmode goes away and the car runs perfect. I can drive the car super long distances without problem. After i turn it off and start it up again the PRND start flashing again sometimes not. Basically its very intermittent and after i reset the codes it runs fine.
    Is it true that on a B6 A4 non quattro the TCM is inside the transmission?
    And also i read up that there are 3 trans sensors, 1 under battery, 1 on top of differential, and 1 on the transmission. Im thinking theres a bad/dirty connection somewhere and its causing this fault. Literally after i reset the codes the car runs perfect!! even in limpmode once i take off its drives fine.
    Guys where should i start ? car has 82,000 miles.
    (i have a B5 S4 that had a flooded tcm under passenger carpet and it ran in limpmode, i replaced it with a new one and it ran perfect, untill i cleaned up the harness i was getting the range sensor code but the car was running perfect like this one)
    Anyways, reverse works! is this the range sensor or tcm guys?
    Feb 25 2016
    Waterbury CT
    Same problem 2006 A4 1.8 non Quattro
