Results 1 to 20 of 20
    Aug 28 2013
    belleville nj
    Fuel rail pressure too high cel
    So i got a cel for "fuel rail pressure too high" p0088 and "cold start fuel pressure performance" p053F.
    I changed the fuel pressure sensor on the rail and the regulator sensor and nothing still getting a code. I don't know where else to check from here. Anyone have prior experience with this?
    Veteran Member Three Rings vacsimile's Avatar
    Nov 15 2008
    2004 Audi S4, 1991 Nissan D21, 2001 GTi VR6
    Outer Space
    What kind of car? I've seen this before on a chain-driven 2.0T and it was because the intake camshaft is out of time. You'll have to pull the front timing chain cover to check timing. If it's the belt-driven 2.0T I have no idea.
    Also, charge the battery on your phone
    Aug 28 2013
    belleville nj
    2009 b8 a4 chain driven
    Aug 28 2013
    belleville nj
    And i just had my valve cover gasket changed so it makes sense because they need to release tension in the timing chain to do this job
    Jul 10 2012
    buffalo
    why would a valve cover gasket have anything to do with your timing chain tension?
    1995 camaro with taurus SHO engine
    2001 audi a8 gutted because race car
    2009 chevy express 2500 duramax built 4L85E trans and tuned for around 400hp
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
    Aug 28 2013
    belleville nj
    On the b8 the only way to safely raise the valve cover off u need to release pressure on the cams so u open the timing chain cover and release pressure on the tensioner and raise the valve cover so the car wont jump timing
    Nov 15 2008
    Outer Space
    Did you ever get this fixed?
    Aug 28 2013
    belleville nj
    No did all fuel sensors and hpfp and cam follower we r going to change the fuel injectors and see what happens we checked timing and it was fine
    Nov 15 2008
    Outer Space
    How did you check the timing?
    Aug 28 2013
    belleville nj
    My mechanic did he is an audi specialist and i also did logs and its correct
    Nov 15 2008
    Outer Space
    Ha well I guess your specialist can just keep throwing parts at it until it gets fixed then. After the injectors you'll be doing the low side fuel pump, then the fuel pump control module, then the ECM. I doubt any of these will fix your problem.
    I'm telling you bro, it's timing. Put the crank in time and measure between the marks on the cams. It should be 125-127mm. If it's outside that range, timing is off. When the intake cam gets one tooth off it won't set a timing fault or run very bad.
    I happen to be an Audi specialist, too.
    Aug 28 2013
    belleville nj
    Ok I'm going to have them check it again
    Aug 28 2013
    belleville nj
    Just to be sure this is a 2009 audi a4 b8 tfsi and also how can i check the timing do i just take the cover off and do it from there or ? Please explain if possible because i told my mechanic and he swears it isn't the timing so i wanna be there when we recheck it
    Nov 15 2008
    Outer Space
    Yeah, pull the upper timing chain cover and put the engine at TDC. There are two marks on the crank pulley and when the engine is at TDC one mark will point to 12 o'clock and the other will be at around 5 o'clock. The 5 o'clock mark needs to line up with a tiny triangle that's cast into the lower timing chain cover. That mark is super hard to find and you'll probably have to feel for it.
    Once that is done look at the cam sprockets, they should have marks on them pointing upwards. The exhaust cam has a triangle cast into the sprocket and the intake cam had a line drawn on the cam adjuster sprocket. If these aren't pointing up you are on the wrong stroke so turn the engine over one more time and line up the crank pulley again.
    Once the marks on the cams are pointing upwards take a tape measure and measure directly between the marks, the spec is 126mm +\- 1 mm.
    There may be marks on the valve cover also but these aren't there from the factory and you can't go by these. They were made by a mechanic at some point to use as a guide.
    Aug 28 2013
    belleville nj
    Problem solved timing was a hair off
    Senior Member Three Rings Sharper_Image's Avatar
    Mar 21 2013
    Warwick, RI
    2009 A4 2.0 tfsi. Don't mean to bring this thread back from the dead but im also getting the P0088. Recently had the engine rebuilt after the timing chain tensioner failed. Sent the head out to get refurbished, pistons and rods was replaced. I assembled everything myself, i tripple checked everything. Car runs fine smooth idle no misfire no other codes and after reading this post i went ahead and check the timming again and everything was within spec. Fuel pressure sensor was also replaced on the fuel rail.
    Nogaro Blue B7 2.7T swap SLine 6spd manual | K04 Stage 3 | DTM bumper conversion | Air lift V2 | 19" Peelers
    Brilliant Black B8.5 | SQ5 | Red interior | Bone stock |
    Estoril Blue C7 S6 | IE Stage I ECU | IE TCU tune | AWE Track | 034 lowering links | 20x10.5 |
    B8.5 S5 Gone
    B8 Avant Gone
    C7 A7 11.3 @ 120 Gone
    Mar 21 2013
    Warwick, RI
    Bump anyone?
    B8.5 S5 Gone
    B8 Avant Gone
    Feb 03 2020
    New Hampshire
    Now I was looking thru my obdeleven the other day and noticed I have a p0088 code but don’t have a cel car has 77k 2014 a4 2.0t tfsi I keep hearing it could be timing it could be the fuel pump and so on yet again I don’t have a cel so not really sure if it’s a problem or not dropping the car off after the holidays to see what’s wrong with it if anything
    Junior Member Two Rings
    May 11 2020
    Chicago
    Quote Originally Posted by Dirtyeuro87 View Post
    Same issue here on my 2014, did you ever find out what was causing the p0088? Mine seems to pop on in cold weather here in Chicago
    Dec 09 2021
    Washington
    I’m having the exact same issue. Rebuilt motor, timing, and all fuel and ignition addressed and still having this code, only thing I haven’t don’t is the fuel pressure regulator. I do have a stage one tune but have noticed the code is intermittent and only misfires under wide open throttle, maybe 2-3 misfires
