Option 2 tends to be how you do it with a EBC since the controller is cutting pressure off to open the WG by releasing the pressure that is holding it closed. This is a dual port setup and has pressure on both top and bottom parts of the WG.
Option 1 is how a MBC and N75 valve would be setup since those allow pressure to be passed thru to open the wg at a set pressure.
