Results 1 to 22 of 22
    Jul 19 2009
    Nj
    Aftermarket wheel size restrictions? B8.5
    Hey gang,
    So I tried doing a search and couldn't find anything specific to b8.5 wheel restrictions.
    In the future I want to get some nice stagered wheels like I had in my old tt..
    I've heard and read around that our cars are very limited to wheel width issues? What's the max I can go? I'm looking to do like 19x9.5 in the back and 19x8.5 in the front like my old ride (below). Am I still okay?
    I miss her 
    Thanks in advance!
    Senior Member Three Rings Li ls4's Avatar
    Jul 19 2014
    2011 s4
    Long Island
    you can fit up to a 10" wheel without having to do any crazy modifications
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    Not in anyway trying to be a smart ass but there is a sticky at the top of this section with 114 pages of specific wheel fitment information. All of the answers you are looking for can be addressed there along with tons of photos. Here is the link.......
    http://www.audizine.com/forum/showth...ent-discussion
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Jul 19 2009
    Nj
    Quote Originally Posted by Li ls4 View Post
    Yea? Ok nice. I should be good then.. Even if I where to lower it or you talking with stock ride height?
    Jul 19 2009
    Nj
    Quote Originally Posted by MVR 155 View Post
    All good. I was lazy and did a search and didn't see anything specific so I posted. I'll look through the 114 pages when I get 4hrs to do so, lol. Jk. Thanks
    Veteran Member Three Rings CaptSlow's Avatar
    Apr 18 2014
    NoVA
    10 inches wide? Really? I thought it would rub like crazy on 255
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by CaptSlow View Post
    A 10" wheel is definitely doable, but with a very limited offset range; say ET39 to ET43 or so. Even then, there is a small chance of rubbing with a 255 tire depending on alignment, height, and tire choice.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Junior Member Four Rings Jimminez's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Like others have said, 10" is fine depending on offset, camber and how low. I ran a 20x10" ET42 with 255/30R20 with no issues.
    Pic for reference on how low I was too. I had adjustable front control arms.
    Apr 18 2014
    NoVA
    I think OP was at stock height, so maybe there would be less worries with 10" wide.
    Unless someone says they're running 10.5
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    A 10.5" is out of the question for the front, but you could pull it off on the rear.
    Jul 19 2009
    Nj
    Quote Originally Posted by Jimminez View Post
    Niceeee. Ok cool 9.5 in the rear sounds just fine w/ 8.5 in the front. Thanks for the quick responses! I'll figure out wheel size and et when I find the perfect wheels :p
    Sep 30 2009
    b
    10 inches wide will likely not work on stock ride height. With that fitment you really need the camber to help tuck that wide of a wheel.
    Quote Originally Posted by jran76 View Post
    there is a guy on 10.5's (squared) over in the a4 section without anything crazy going on, actually. fender liner screws pulled, etc.
    Sep 30 2009
    b
    Quote Originally Posted by dubspeed22 View Post
    why would you stagger? pretty pointless on these cars.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    I guess technically you could do a 10.5" on the front, but it would either take a stretched tire, or some fender work. Just to clear the suspension, you would need something around an ET40, and I think that would take a 245 to even think about clearing the fender (which is way too much stretch for my taste).
    Jan 09 2008
    Winnipeg
    Like others have said, the real problem is not the width of the wheel per se, it is the offset and the tire that are going to cause the biggest problems and then throw in ride height and camber. At the end of the day there are a lot of variables that you need to consider so when one person tells you "no problem you are fine" you need to know all the specifics of their set-up.
    As you may know the brand and model of tire will play a significant role as pretty much all tires will have a different tread/shoulder profile even though they are all the same size. If you don't really care too much about the rubber you put under the car in terms of width or performance category then you probably have many more options available. Maybe you want a huge stretch or maybe you want a nice square sidewall. Unfortunately you will need to wade through the stickied thread and try to digest what is in there. But read it all and PM people with questions because I have found some people will go and say one set-up will work only to be contradicted by someone else later.
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Holy crap! Beautiful. But tell me this had to have rubbed the wheel well SOMETIMES, SOMEWHERE?!
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    May 16 2007
    Ottawa CA / DE USA
    Quote Originally Posted by stereojorge View Post
    Well I never had the car fully loaded at that height, so sure there could have been rubbing. You also do have to be aware of how turned your wheels are when hitting a bump/turning in to an elevated driveway. Under normal driving with two kids in toe with stuff in the trunk, I didn't have any issues. As mentioned, added camber and being aware that you're low, you can run an aggressive wheel and tire combo.
    Jul 19 2009
    Nj
    can you elaborate? i did in the past for more cosmetic reasons (bigger lip in the back). obv its not just a RWD car I understand that.. why is it pointless?
    Established Member Two Rings RizzoS4's Avatar
    Jun 01 2014
    Chicago burbs
    I've run 19x10 et35 and 20x10 et35 with zero issues. 20's had 255/30, 19's have 245/35. No rubbing whatsoever on 19's, even at full lock. 20's rubbed at full lock but I wasn't aligned properly. I'm bagged, but camber in rear is only -2.0 when its maxed out, so it isn't even noticeable. Not sure why people are so worried about wheel sizing, just try it!
    As for running staggered, that's dumb. It's AWD. You can still have a staggered LOOK and still have the same width all around if you do a 3-piece wheel.
    Sep 30 2009
    b
    removes practicality of rotating tires.
    you don't need staggered wheels on this car in order to achieve a flush look on all 4 corners
    resale value, staggered set-ups are not going to sell as well because of all of the following.
    No weird tire size issues to worry about.
    simply. better.
    Jul 19 2009
    Nj
    simply. better.
    Thanks! Appreciate the feedback guys and noted!
    Jan 09 2008
    Winnipeg
    Some other things to think about...
    - Different tire sizes will have different rolling diameters which will increase wear/stress in the AWD system. Even if you follow the tire specs for revs per mile, if you are not using the "measured rim" width then you are further stretch the tires you are going to affect the rolling diameter.
    - Theoretically putting more rubber in the back or increasing the rear track will also increase the rear end grip. This sounds great except for the fact that these cars already have a tendency to understeer and doing this would theoretically make it worse or more correctly it would further reduce the car's ability to rotate. I say theoretically because I have not actually put this to the test...I can't afford to buy multiple sets of wheels and tires just for the sake of science. I suspect only people that track their car would really see the effects of this where you are driving near/at the limit and vehicle dynamics are really going to come into play.
