Results 1 to 3 of 3
    Active Member One Ring CGramme's Avatar
    Oct 29 2014
    Atlanta GA
    lcd display functions
    I am a pretty new audi b6 owner and have searched for examples/tutorials for the lcd display in gauge cluster with no prevail. All I get when searching are guides on removing or replacing the screen/cluster. Does anyone know all the functions I can use the display for? maybe a link to a helpful site? Thank you!
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Do you not have an owners manual? The DIS, stock, will display radio and navigation info (as applicable), as well as temperature, fuel economy (instantaneous & trip average), average speed, estimated distance until empty, and trip time. If you have an automatic, it also displays the current gear, and there are a number of warnings that it will display too, such as bulb out, coolant low, coolant over temp, oil pressure low, oil low, bad oil sensor, low washer fluid level, brake pad wear indicator, and probably a few more that I'm missing.
    Oct 29 2014
    Atlanta GA
    Thank you for the info. I don't have an owners manual unfortunately. I suppose I'll end up getting or downloading a manual for the car soon. I really want to know how to change between different display information.
