Results 1 to 4 of 4
    Mar 16 2015
    new york
    2001 Audi tt 225 Quattro 1.8t Engine knock when accelerating problem HELP
    hello all i have 2001 audi tt quattro 225 and i am having a problem with the engine.... theres an engine knock ONLY when i rev the engine or when i accelerate. the noise also occurs under a load. the noise DOES NOT occur when i am at idle and also when im cruising. i am very confused and i have a video to post here as well PLEASE HELP.
    heres the link:
    https://www.youtube.com/watch?v=WcWrvAhoBM8
    i apologize in advance if i was not suppose to post on this forum about this issue. if so can anyone guide me in the right direction?
    thanks
    Veteran Member Three Rings MYFASTA4's Avatar
    Sep 03 2009
    C7 A6, A4 B7 AVANT, B8 ALLROAD & BOX-SPYDER
    Florida
    I would start by making sure there's enough oil in your engine, I am 99% sure you need a timing chain tensioner. it could also be oil pump.
    sludge in the engine can cause low oil pressure too.
    2014 S4 6MT, B&T, sport dif., MMI+
    2015 A3 8V
    2001 TT MK1-225
    Mar 16 2015
    new york
    A couple people have told me it could be a rod bearing. including the dealer is this possible, with it idling so smooth and no noise.
    Oil is good and I do not have any lights on for low oil pressure. could it still be the oil pump if there are no lights?
    Sep 03 2009
    Florida
    I guess it could be, but the other noise the engine is making is probably the chain tensioner, im just wondering if the other noise has something to do with it.
    the problem about taking this car to the dealer is that they don't see this cars all the time, people with a 10 15 year old don't take to the dealer, you might want to get a second opinion.
    2015 A3 8V
    2001 TT MK1-225
